Fuel selector or two check valves?
Old June 30th 05, 02:10 PM
For that application, would not full-aperture ball valves be
appropriate?
Yup. I use one in my Jodel now; they work fine, but a weak point
appears to be the o-ring around the shaft. The ball and teflon seats
work OK. Watch that you don't get a really poor quality Asian unit;
there's a wide range of stuff from good to pretty lousy out there.
Badly cut pipe threads and all.
Dan
Old July 1st 05, 12:21 AM
Blueskies
"Rob Turk" wrote in message news:SN6we.366$in3.124@amstwist00...
Instead of using a left/right fuel selector, could I use two check valves and connect the two tanks into a single
feed?
[LTANK]---|-----T-----|-----[RTANK]
Where | and | are the check valves and 'T' is a T-connector towards the header tank.
The check valves prevent fuel moving from one tank to the other. Any pro's, con's or thoughts?
Rob
What is the pressure drop through the valve and the cracking pressure of the valve? Pretty hard to have 'matched'
valves, so one will most likely flow freer...
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
Weatherhead fuel valves? Yosimite Sam Home Built 2 February 14th 04 12:21 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 07:48 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
