I am working off dim memories here, but ISTR that Klaus had vibration
problems with an experimental (in the deepest sense of the word) 3-bladed prop and that he recommended 2-blades only for the EZ series aircraft. Many pushers now use 3 bladed composite props. The most popular for the 180 HP and up crowd is the Catto Prop, maple laminate core with 25 to 36 layers of fiberglass over the wood with a 1/2" aluminum mounting plate embedded on one side. He makes them for 100 to 600 HP engines. They are known to be bullet proof. The lower power pushers use 2 blades because they can get away with it and they are much cheaper than 3 bladed fixed pitch props. The higher the engine HP the more blade you need. A two bladed prop on a 200 HP engine is just to long for a pusher, so 3 blades are required. Scott |
The prop in question is an old style Performance Prop. It does have
many laminations. About 24 I think, I have one hanging from the roof of my study. Its safest there. They no longer wrap the out portion of the blade as it has caused problems. If its gonna break it will right there. Scott Corky Scott wrote: On Tue, 28 Jun 2005 18:52:56 -0700, Ron Wanttaja wrote: Hi Ron, I wonder what the evidence is that it was a bird strike? I don't see any blood and guts anywhere. I noticed that, too. Something else could have gone through the blade, but I don't know if a bolt or nut would do this kind of damage. The guy may have cleaned it off already.... Ron Wanttaja Here's another couple of data points: The prop appears to be made from a solid blank, not laminated from numerous strips. I read a long time ago that the props on the EZ type aircraft run in such turbulence that it's recommended they use wooden props only. The turbulence is unavoidable in that it's the result of the prop passing through the lift created by the trailing edge of the wing. There also may be exhaust pulses to whap through as well. That's why the EZ's have that characteristic buzz when they fly by. In fact all pushers seem to sound that way. Wooden props are supposed to **DAMPEN** vibration. Interestingly, the only part of the information suggesting a bird strike is the title. Nothing in the storyline claims that or suggests it. It certainly isn't impossible for birds to be at 9,500, just a lot less likely than closer to the ground. It isn't migration time... Corky Scott |
Corky
The pusher prop/engine on the 0-2/337 didn't have any problems that I was ever aware of. Nothing in Pilots Handbook. Aluminum props on both front and rear engines. Rear prop was in wing turblance, exhaust, etc. Biggest problem was on gravel strips and nicks. Big John `````````````````````````````````````````````````` `````````````````````````````````````````````````` ```````` On Wed, 29 Jun 2005 10:50:48 -0400, Corky Scott wrote: On Tue, 28 Jun 2005 18:52:56 -0700, Ron Wanttaja wrote: Hi Ron, I wonder what the evidence is that it was a bird strike? I don't see any blood and guts anywhere. I noticed that, too. Something else could have gone through the blade, but I don't know if a bolt or nut would do this kind of damage. The guy may have cleaned it off already.... Ron Wanttaja Here's another couple of data points: The prop appears to be made from a solid blank, not laminated from numerous strips. I read a long time ago that the props on the EZ type aircraft run in such turbulence that it's recommended they use wooden props only. The turbulence is unavoidable in that it's the result of the prop passing through the lift created by the trailing edge of the wing. There also may be exhaust pulses to whap through as well. That's why the EZ's have that characteristic buzz when they fly by. In fact all pushers seem to sound that way. Wooden props are supposed to **DAMPEN** vibration. Interestingly, the only part of the information suggesting a bird strike is the title. Nothing in the storyline claims that or suggests it. It certainly isn't impossible for birds to be at 9,500, just a lot less likely than closer to the ground. It isn't migration time... Corky Scott |
Tankers and strike packages (Was: EA-18G vs ES-3) | [email protected] | Naval Aviation | 0 | December 9th 04 11:11 AM |
SWRFI Pirep.. (long) | Dave S | Home Built | 20 | May 21st 04 03:02 PM |
Hamas Leader Rantisi Killed by Israeli Strike on Car | Dav1936531 | Military Aviation | 13 | April 21st 04 07:04 PM |
Joint Strike Fighter focus sparks concern | Otis Willie | Military Aviation | 0 | March 19th 04 09:19 PM |
Simpy One of Many Stories of a Time Not So Long Ago | Badwater Bill | Home Built | 40 | March 16th 04 06:35 PM |
