tuned ground plane
Old November 26th 04, 02:54 PM
Robert Bonomi
Jim Weir wrote:
Yes, my stupid. w is a full wavelength.
HOWEVER, the assumed frequency is MHz. (megahertz), not mHz (millihertz) if we
are going to get picky.
Life was *so* much simpler when you could just call it 'megacycles', and use
'mc' as the abbreviation, and everybody knew what you meant. grin
The 'computers' world doesn't help much, either. Where storage 'scaling' uses
upper or lower case, depending on whether it is a 'power of two' factor or a
'power of 10' factor. I can never remember which is to be used for which..
*sigh*
Old November 27th 04, 05:35 PM
Ron Natalie
Frequency is measured in cycles, not cubits, bushels or yards.
Hertz rents cars.
There once was a woman named Mavis,
who thought kilohertz was depravis,
If number one wasn't enough,
and number two tried hard enough,
Kilohertz would soon become kiloavis.
Old November 27th 04, 06:09 PM
if we
use
Hertz rents cars.
Technically, frequency is measured in cycles per unit of time. A Hertz is
defined as 1 cycle per second. The term megacycles is incomplete due to the
lack of a time element. By the way, when did the ARRL officially accept the
Hertz terminology?
H Wayne Paul
W7ADK
Narrow Foil Strips for Ground Plane Dennis Mountains Home Built 22 August 29th 04 01:09 AM
Antenna ground plane and coax grounding G. Fred McCutchen Home Built 2 August 8th 04 12:27 PM
A Good Story Badwater Bill Home Built 15 September 3rd 03 03:00 PM
Ground plane Frank Home Built 5 July 25th 03 11:52 PM
Antenna Ground Plane Grounding Fastglasair Home Built 1 July 8th 03 05:21 PM
