![]() Anton wrote: wrote Have you ever taken a car and fitted a much larger engine to it? Read up.Before that 2.8 V6, engine vas 1.6 4-cyl. OK, good then. A lot of times people ask questions like this and don't really have the slightest idea what they're getting into. Clearly you have a little more experience. Have you ever worked with turbine engines before? (Obviously not, based on your questions) No.I prefer NA engines.Even now.I'm interested in turbines as engines, not like add on to piston engines. Yeah, I know, I mean "gas turbine engines," not turbo/supecharged engines. In order to succeed, you first need to turn your turbochargers into a turbine engine. Before you can even begin to think about doing this you need to learn how turbines work. Then you can begin laying out a plan. I know principles, after all, I'm studying railway traffic, and we have many mechanical courses. Well, when you asked, "what is a compressor," I wondered. That is like asking a piston mechanic, "what is a cylinder?" This is a project that would probably keep you busy for 5 years if you work part-time. You mean on locomotive turbine into car, or just plain turbocharger converting to gas turbine?If is this last, then you must se what people on intrent have made for month or less with scrap turbocharges from local junkyard. Are they generating useful power, or just making a lot of noise? Making noise is easy, making power takes engineering skill. That's what will take you time. Are they skilled mechanics doing their second or third project, or a first-time experimenter just like you? I'll bet the second time you do this, you will do it a lot faster than the first. As for how much power it puts out, who knows? There's a ton of variables in there. I'd suspect a few hundred horsepower, maybe more, quite likely less. It will probably turn out heavier than an equivalent piston engine, and thus the car will actually go slower. Why?That doesn't mean that it must be like you said. Well, let's look at it this way. Teams of engineers, with literally billions of dollars to spend, build turbines that put out maybe 800 horsepower (and of course a lot larger too). Of course, you don't have to worry about safety or reliability, so your job is easier that way, but you're also working with inferior materials and knowledge (not meant as criticism, just fact). You may be able to get 500, 700, 1000HP out of a turbine but my guess is that your turbine will end up weighing a LOT. Weight is not the first concern when building parts that go on locomotives- durability and low maintenance cost matter a lot more. The result is that heavier, cheaper materials are used and often overbuilt (adding more weight). Weight is your enemy. If my car has the same power as yours, and mine is heavier, then your will be faster. Simple physics. How cool will that be? Why that tone?I mean, what is so wrong if I ask something like this Sorry, I'm not trying to be discouraging, just realistic. If you think you can build a turbine in a few months that will make your car go super-fast, you're probably going to be disappointed. If you're ready to spend a couple of years in the shop, building, testing, fixing, building, fixing, testing, then you just may be able to get something pretty cool. Hey, really, I wish you the best of luck. I hope it works. Best, -cwk. |
![]() "Anton" wrote in message ... "Keith W" wrote Yes, its been done with the turbo's for road vehicles http://www.channel4.com/science/micr...ges/jet_racer/ diary_team02.html Hmm...That text is little bit confusing, in fact I don't really understand what are they talking about...They have said much, but still, nothing.Only some story from that race. Sure BUT it would be a very complex build as you'd need to build a compressor stage and burner cans and then couple the high revving turbine to the transmission. I know.High revs can be solved with reductor.Now, I need more information about compressor stage and burner cans ![]() Then visit a library I presume that all this could fit to a car, for example Ford Cortina, or something like that. Its been done so its possible. How strong must be, I mean how much thrust could turbocharger from car produce?Could I make a one man vehicle from that? Thrust is meaningless unless you intend making a jet powered car. Given enough time and money you can build anything and gas turbine cars have been built. The real question is why ? I know that gas turbine cars have been built, but the real question is, have they been built in private garages? ![]() Why? Why do people climb on mountains, why do people surf, why do people like diving..? ![]() I hope you understand what am I aiming for.I want to have a first gas turbine powered car in Croatia. ![]() ![]() No Jet powered streetrace car...Hmm...Nice... ( like Homer Simpson would said ) ![]() First learn a little about engineering Such a vehicle is likely to be unreliable and extremely inefficient in using fuel and probably could not be certified for road use. That isn't my intention at all.I want to make that car, not for daily use, but for streetrace, for example, why not?That would be a show... ![]() And almost certainly illegal. A better approach may be a hybrid using a small gas turbine running at constant speed to charge a battery for an electrically driven vehicle. If I wanted to do that, I would go on some 1.4 liter diesel engine, which can I buy almost everywhere and make electric car. ![]() Indeed Keith ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
"Keith W" wrote
Then visit a library OK. Its been done so its possible. Good... Thrust is meaningless unless you intend making a jet powered car. Yes, I know, mea culpa, I mixed some things.My intention is to make traction car, not thrust. No Why not? First learn a little about engineering Like I said post before, I know mechanical engineering, but I haven't never been interested in turbines.I'm working all by myself on my car.Ask me anything about piston engines and I'll tell you. And almost certainly illegal. Look, I don't know where you from, but trust me, it's legal, here it is.I don't know for you and your country. Indeed Yes? |
Look, I don't know where you from, but trust me, it's legal, here it is.I don't know for you and your country. Wow, Anton. I'm impressed! You were a lot more polite than most people would be after receiving such a snotty, rude reply. Good luck in your project. Rich S. |
The UK's APT (Advanced Passenger Train) of the 1970s used 6 gas
turbines to power it. Never made it into service. pics of one of the turbines. http://www.apt-e.org/index/apt73.htm David |
![]() wrote in message ups.com... The UK's APT (Advanced Passenger Train) of the 1970s used 6 gas turbines to power it. Never made it into service. pics of one of the turbines. http://www.apt-e.org/index/apt73.htm David That was only the experimental version, the prototype and production versions were intended to be electrically hauled. The BoBo power car design was used to build a new locomotive, the Class 91 capable of 140mph, which pulls the Inter City 225 on the East Coast main line today. Keith ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
You're right - but it was still the nicest of the APTs! would look
state of the art, even today.The protype had a few things batting against it - one of which was that the turbines were built by Leyland ....this was around the same time they were churning out Princesses/Ambassadors and Allegros... David |
Before the 1963 Chrysler gas turbine car was the Rover JET-1:
http://news.bbc.co.uk/onthisday/hi/d...00/2516271.stm Rob |
B-17 with claimed gas turbine engine, WW2:
http://www.de220.com/Strange%20Stuff/TEST-80G419784.jpg Rob p.s. What was the engine? |
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power | TurbineMini Richard | Rotorcraft | 2 | January 28th 09 07:50 PM |
Locomotive turbine conversion? | Anton | Home Built | 34 | July 20th 05 02:42 PM |
Rick Stitt, Joe Rinke, Rinke Aerospace, BJ Schram, Mini 500, Turbine, Helicopter, Kit | TurbineMini Richard | Rotorcraft | 2 | January 24th 04 01:15 AM |
Mini 500, Helicycle, Turbine, Joe Rinke, Rinke Aerospace, Rick Stitt, Conversion, Kit | TurbineMini Richard | Rotorcraft | 0 | January 15th 04 11:48 PM |
TRUTH OF THE MINI-500 TURBINE CONVERSION | Dennis Chitwood | Rotorcraft | 10 | January 7th 04 05:33 PM |
