Smitty wrote: When I get to my panel, which isn't going to be soon, I'll probably do it on the mill. But for those who don't have access to a machine shop, I wonder why you're talking about hole saws and fly cutters. Don't the Greenlee type punches work pretty well? You only need a small pilot hole and a couple of wrenches. I much prefer the fly cutter, as the Greenlee punches take a lot of torque and may leave the panel warped in places. If you turn the fly cutter slow enough and use a good aluminum cutting fluid, it works well and safely. -- Remove _'s from email address to talk to me. |
wrote in message oups.com... I need to cut a panel to mount one 3.125" and one 2.25" What size hole saws do I use? Do I use smaller sizes, say 2.125" for 2.25" and 3" for 3.125"? Thanks. I have done this several ways. Hole saws - messy, fly cutters - dangerous if not clamped VERY well and still messy, and milling machines - neat but hard to get access. The best way is to get the whole panel laser cut and then anodized black after test fitting the instruments. Not all instruments are exactly 2.250 or 3.125 so specify the holes a few thou oversize. I did it this way for my new glider panel. The results were very neat and not expensive at all. If you really want to cut the metal yourself, make a tool/fixture out of high density composite particle board - I think it's called MDX or something like that. Forstner bits cut very neat 2.250 and 3.125 holes in the MDX tooling. Mount the panel blank to the tool and rout the panel with tungsten router bits with ball bearing guides. Cut undersize instrument holes in the panel with a hole saw or fly cutter and finish with the router. Make or buy a drill guide for the instrument screw holes. BTW, I've never had countersunk instrument screw holes all come out perfectly. At least a couple were slightly out of alignment putting stress on the instrument cases. The last time around I used black button head Allen screws in oversize holes which look as nice as the countersunk variety and allowed for some misalignment. Bill Daniels Do a neat job - after all, you are going to be looking at the thing for a long time. Bill Daniels |
Using a laser cutter changes the temper of the aluminum along the edges
of the cut. Perhaps not a big deal in a instrument panel, if it isn't structural, but it is on a wing rib or other structural part. A waterjet cutter can do the same thing, but you don't have to worry about the temper. It will leave a slight burr, but nothing that can't be dealed with simply. John |
On Mon, 11 Jul 2005 08:34:50 -0500, John T
wrote: Using a laser cutter changes the temper of the aluminum along the edges of the cut. Perhaps not a big deal in a instrument panel, if it isn't structural, but it is on a wing rib or other structural part. A waterjet cutter can do the same thing, but you don't have to worry about the temper. It will leave a slight burr, but nothing that can't be dealed with simply. A plasma torch properly set up can cut a hole in thin metal without scorching the adjacent paint, but it takes a good set up and lots of practice. They are fast. this would not be my choice for a first timer. I've cut sheets of white painted "barn metal" with a smaller self contained unit. After being used to a torch (not on barn metal), it took a bit of practice to get used to the speed (moving fast enough) to do a good job. If the paint started to feather, or discolor along the edge of the cut I knew I was moving too slow. On a panel you'd want to build a fixture to move the tip in a circle, or use a wood template. Wood works just fine as the plasma will, or should be at least a quarter to half inch away from it. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com John |
I prefer not to anodize anything on the airplane. Anodizing forms a VERY
hard insulating film that you have to spot-face down to the aluminum to make an electrical connection. I prefer to powder coat, which is nearly as tough under operating conditions but not nearly as difficult to get an electrical connection. Jim The best way is to get the whole panel laser cut and then anodized black after test fitting the instruments. |
On Mon, 11 Jul 2005 08:55:14 -0700, "RST Engineering"
wrote: I prefer not to anodize anything on the airplane. Anodizing forms a VERY hard insulating film that you have to spot-face down to the aluminum to make an electrical connection. I prefer to powder coat, which is nearly as tough under operating conditions but not nearly as difficult to get an electrical connection. Jim Another point against anodizing is that it increases the notch sensitivity of already notch sensitive aluminum. This is far more significant with hard anodizing than with decorative, but that aluminum oxide will crack then concentrate the stress in the crack. Powder coat has its problems too, and they are aluminum grade, product and process dependent. All the processes I know actually "melt" a powder on the surface. The temperatures of some powder processes are above safe operating (change of properties) temperatures of some heat treated aluminum alloys. I use "some" because I don't know details. The best way is to get the whole panel laser cut and then anodized black after test fitting the instruments. George |
Most laser machines don't like aluminum. It's too shinny, and can reflect back into the lens. Look into water jet instead. |
"LCT Paintball" wrote in message news:7ExAe.145539$x96.83501@attbi_s72... The best way is to get the whole panel laser cut and then anodized black Most laser machines don't like aluminum. It's too shinny, and can reflect back into the lens. Look into water jet instead. My panel was .125" 6061 and I got it laser cut for $70 including material. I never use the panel for an electrical ground, running ground wires to each electrical device instead so decorative black anodize worked out beautifully. Bill Daniels |
| Thread Tools | |
| Display Modes | |
| Are All Batteries Created Equal? (Does Size Matter?) | [email protected] | Soaring | 4 | July 17th 05 03:04 PM |
| DIGGING A DEEPER HOLE | Cribsheet | Piloting | 3 | December 10th 04 01:00 AM |
| Oil Temperature sending unit | Corky Scott | Home Built | 2 | October 19th 04 01:58 AM |
| Finding vent hole in wing skin | Martin Eiler | Soaring | 7 | November 21st 03 02:44 PM |
| Fairing question... | Tina Marie | Home Built | 5 | July 16th 03 01:18 AM |
