#11
"Longworth" wrote in message
ups.com... Trip to Michigan and Illinois, June 29 - July 4, 2005 Rick & Hai Longworth Thanks for the write-up. Fun to ride along vicariously. ![]() One minor nit... [...] It was very straightforward - overtop the Cory NDB and outbound to a procedure turn then almost straight in to the NDB just short of the runway, MAP = 2400 feet. and... [...] Checking the Jamestown ATIS for and altimeter setting, we heard "ceiling 500"! I glanced back at the NDB approach on my lapboard. MAP 653 feet! I believe you meant to write "MDA" rather than "MAP". The "missed approach point" is a particular point along the approach, and is where you initiate your missed approach procedure if you are not in a position to land. The "minimum descent altitude" is the lowest altitude you may descend to while flying a non-precision approach. You may or may not be at the MDA when arriving at the MAP, but you'll still be required to initiate your missed approach procedure even if higher than the MDA. Likewise, you may wind up descending to the MDA well before arriving at the MAP. On a precision approach, the MAP is defined as an altitude, but that altitude is called the "decision height", not the MDA. Pete |
![]() Pete, You are right. It was a typo. Rick meant MDA not MAP. Hai |
![]() "Longworth" wrote in message oups.com... That was what I thought until the ATC admonished us for turning too soon. Well, if you were actually cleared direct to WEARD and not via the Dutchess Four Departure then you didn't turn too soon and ATC was wrong to admonish you. |
Great report, Rick, Thanks. As a slightly pre-solo student who intends
to pursue an IFR rating next, this was a great introduction to what I can expect. Longworth wrote: Trip to Michigan and Illinois, June 29 - July 4, 2005 Rick & Hai Longworth *snip* |
Longworth wrote:
Trip to Michigan and Illinois, June 29 - July 4, 2005 Rick & Hai Longworth she decided to call them speed bumps. I became a little anxious when Detroit had not addressed us for 10 minutes or so. I wanted to be sure we were not forgotten so I requested to be back on track for Muskegon. The controller, with as much patience as he could muster, replied that that was what he intended. "Yes sir", I said, realizing I had been a bit foolish to think he had actually dropped an IFR flight plan on the floor. I felt like a real novice, to put it mildly! I've had controllers send me on a vector and then forget I was there. It never hurts to ask. Localizer, Hai slowed to 90 knots to give herself plenty of time to relax and mentally prepare for the approach. Muskegon came back with a request for "at least 110 knots". Hai quickly added power, and with the descent angle still in, we shot up to 110 knots, then 130 knots, then 140 knots! I fly out of a very busy reliver airport full of jet traffic. When asked I will keep cruise speed up to the FAF, but then all bets are off. If ceilings are 800' or more then I've got plenty of wiggle room and I'll keep the speed up, but if it's low, I'll fly the speed that I want to. This is also pretty easy to manage in a 172 because you cruise at 100 and fly the ILS at 75 and you can lose 25 knots in under 30 seconds. If you're in something like a Bo or Mooney then you may be looking to lose 50 knots and doing so will take more planning. Bottom line is that it's ATC's job to keep the G-V off your tail once you're inside the approach gate. Best, -cwk. |
![]() wrote in message oups.com... I fly out of a very busy reliver airport full of jet traffic. When asked I will keep cruise speed up to the FAF, but then all bets are off. If ceilings are 800' or more then I've got plenty of wiggle room and I'll keep the speed up, but if it's low, I'll fly the speed that I want to. This is also pretty easy to manage in a 172 because you cruise at 100 and fly the ILS at 75 and you can lose 25 knots in under 30 seconds. If you're in something like a Bo or Mooney then you may be looking to lose 50 knots and doing so will take more planning. Bottom line is that it's ATC's job to keep the G-V off your tail once you're inside the approach gate. A sure way to do that is to put you behind the G-V. |
Steven P. McNicoll wrote:
wrote in message oups.com... I fly out of a very busy reliver airport full of jet traffic. When asked I will keep cruise speed up to the FAF, but then all bets are off. If ceilings are 800' or more then I've got plenty of wiggle room and I'll keep the speed up, but if it's low, I'll fly the speed that I want to. This is also pretty easy to manage in a 172 because you cruise at 100 and fly the ILS at 75 and you can lose 25 knots in under 30 seconds. If you're in something like a Bo or Mooney then you may be looking to lose 50 knots and doing so will take more planning. Bottom line is that it's ATC's job to keep the G-V off your tail once you're inside the approach gate. A sure way to do that is to put you behind the G-V. Yup. At my home field there's plenty of times I've gotten vectored around "while we land a few jets." Cost of doing business. |
Cross country to Canada | JJS | Piloting | 40 | May 18th 05 02:03 AM |
Cross country in the 1-34 | mat Redsell | Soaring | 3 | October 22nd 04 04:56 PM |
Cross Country the main focus of soaring? | mat Redsell | Soaring | 77 | October 18th 04 10:40 PM |
US cross country flight | S Narayan | Instrument Flight Rules | 0 | January 7th 04 02:58 PM |
US cross country flight | S Narayan | Piloting | 0 | January 7th 04 02:58 PM |
