Noise reduction
Old July 23rd 05, 05:18 PM
Roger
On Fri, 15 Jul 2005 14:43:17 GMT, "Michael Pilla"
"Corky Scott" wrote in message
On Fri, 15 Jul 2005 02:20:37 GMT, David Findlay
I'm in the early stages of the homebuilding disease :-P and still don't
know exactly what I want to build, just that I want to build something.
I'm interested to know what people have done in their aircraft to reduce
the interior noise level? Can such noise insulation be added to plan or
kit built aircraft without too much difficulty? Is it possible to reach
car or commercial airline jet noise levels in a homebuilt? Thanks,
David
There's a LOT you can do to reduce noise in the cockpit. Most of it
has to do with proper use of insulating materials but there are other
things like taking extreme care in sealing things like doors and
windows. Using double panes in the side windows will help. Using a
thicker plexiglass for the windshield makes a difference and adds
value in bird strike protection. Putting an effective muffler on the
engine will help too. All this costs money and adds weight.
It's not a home built, but I have a 1/2" windshield, 1/4" side
windows, and lots of insulation in the Deb. It has a 260 HP IO-470N
which is almost always running 2400 except at take off where it's 2700
RPM.
The biggest change came from going to a 3-blade prop.
I was doing turns on a point and the guys on the ground said it
sounded much like a turboprop with very little noise.
It is still loud inside, but not nearly as bad as it was with the
2-blade prop.
BTW, with the sound proofing along with the thick windows flying in
torrential rain barely produces a noticeable sound. Doing the same in
the Old Cherokee 180 was almost deafening.
I've never ridden in a small prop plane where I didn't feel more
comfortable while wearing a head set. I actually find the noise very
distracting. Of course there are many small planes in which I haven't
ridden so there may be some out there that are quiet inside, but I'd
be surprised.
www.rogerhalstead.com
SNIP
Corky
While building my RV-4, experienced builder/flyers strongly recommended that
I add very lightweight angle aluminum stiffeners along the long expanses of
unsupported aluminum sheet. These very thin strips of right-angle aluminum
stiffeners are intended to reduce the oil-canning and reduces noise from the
slipstream drumming along the sheet metal expanses.
Michael Pilla
Small plane noise is destroying my life Robert Morien General Aviation 5 December 1st 04 05:01 PM
Cherokee Strobe Noise Jonathan Goodish Owning 20 November 2nd 04 02:42 AM
Funny noise update Peter Duniho Piloting 1 July 1st 04 02:58 PM
Ear plugs and noise filtering Top Spin Piloting 12 January 16th 04 04:52 AM
Prop noise vs. engine noise Morgans Piloting 8 December 24th 03 03:24 AM
