#11
"Kyle Boatright" wrote: Good analysis. One thing you might try is running the model again at 6 or 8 seconds to complete the roll? This would be would be representative for many GA aircraft, which have roll rates of ~45 degrees/second? I imagine it would make a huge difference in the vertical velocity at the end of the roll. Thanks for reaction (I'm always a bit worried when I'm calculating something outside my personal experience). Results for a 6 sec roll are at: http://www.stanford.edu/~siegman/one_g_roll_6_sec.html As expected, a lot less altitude loss and downward velocity buildup. Also, most of us who do rolls in aircraft with non-inverted systems begin the roll with a pull-up to a 20 degree (or so) climb. In my case (RV-6), I pull 1.5 G's to the 20 degree upline, roll at more or less 1 G, and pull out at 1.5 G's when the roll is complete without any net altitude loss... KB I'll run this when I get a few minutes to do it. Or, if anyone has access to Mathematica (a truly great software program, but expensive unless you can get an academic discount), I'll be glad to send the original notebook. |
I really liked your analysis, but offer the following.
If we fly coordinated -- that is, use the rudder to keep the ball centered our degrees of freedom are ailerons to control rate of bank, elevators to control pitch (pulling the nose up, or pushing it down) and throttle/flaps to control acceleration/deceleration. Someone pointed out if the airplane was allowed to accelerate downward at 1 G, the 1 G roll could be accomplished by simply pulling back on the yoke hard enough to cause 1 G acceleration in the pitch direction while a coordinated roll was flown. This is different than a constant velocity model, but also works. Thanks for crunching the numbers! |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | June 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | April 1st 04 08:27 AM |
Baby Bush will be Closing Airports in California to VFR Flight Again | Larry Dighera | Piloting | 119 | March 13th 04 02:56 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | March 1st 04 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | February 1st 04 07:27 AM |
