VOR Check question
Old July 22nd 05, 08:47 PM
Guillermo
if you go to the AIM: 1-19-1, d. 1.
(b) Aircraft using GPS navigation equipment under IFR must be equipped with
an approved and operational alternate means of navigation appropriate to the
flight.
So basically you MUST be able to complete the flight without GPS, so you'll
probably need a VOR (checked) to be able to comply with that.
"Michael 182" wrote in message
I was told by an avionics guy that if a plane has VOR's they must be
accurate to file IFR, even if I file /G.
FAR 91.171 says "(a) No person may operate a civil aircraft under IFR
using
the VOR system of radio navigation unless the VOR equipment of that
aircraft..."
I'm not debating the logic of having VOR's that are accurate, and I'm
getting mine adjusted - but it seems to me if my means of navigation is an
IFR certified GPS I do not have a legal responsibility to pass the VOR
check. Am I right?
Michael
Old July 23rd 05, 05:30 PM
Brien K. Meehan
If you use the VOR for IFR navigation, 91.205(d)(2) makes 91.171 apply
to you.
.... but (contrary to popular belief) there is no requirement under Part
91 (or Part 135) that says you have to have a VOR receiver to fly IFR.
So, assuming you don't use it, you're right.
Old July 23rd 05, 06:53 PM
to you.
It's an indirect regulatory requirement because by FAA policy the primary
means of IFR navigation in the NAS is by VOR.
Old July 24th 05, 02:01 AM
Brien K. Meehan
Whoever told you it's an indirect regulartory issue was making it up.
Old July 24th 05, 02:22 AM
Well, okay, but I work with this stuff all the time.
Here is from the current FAA Order 8260.19C:
l. Dual Minimums. Enter dual minimums, when authorized. Do not publish
dual minimums unless a 60-foot operational advantage is obtained or a
reduction in visibility can be achieved. To avoid proliferation of dual
minimums, *all IFR aircraft are assumed to have at least one VOR
receiver*. Dual minimums based on a stepdown fix combined with local and
remote altimeter settings could result in four sets of minimums. When two
remote sources are used, treat the source resulting in lower minimums as
the "LOCAL" altimeter setting source in the following paragraphs.
Document only two sets of minimums. The combinations authorized are
minimums with and without a stepdown fix; or minimums with local and
remote altimeter settings.
The words between the asteriks are reflective of FAA Class I navigation
policy, which is a requirement to be a part of ICAO.
And, from the FAA's Instrument Procedures Hanbook (available in Summit's
Aviation Reference Library):
In the broad concept of air navigation, there are two major categories
of navigational operations consisting of Class I navigation and Class II
navigation. Class I navigation is any en route flight operation conducted
in controlled or uncontrolled airspace that is entirely within
operational service volumes of ICAO standard NAVAIDs (VOR, VOR/DME, NDB).
Class II navigation is any en route operation that is not categorized as
Class I navigation and includes any operation or portion of an operation
that takes place outside the operational service volumes of ICAO standard
NAVAIDs. For example, your aircraft equipped only with VORs conducts
Class II navigation when your flight operates in an area outside the
operational service volumes of federal VORs/DMEs. Class II navigation
does not automatically require the use of long-range, specialized
navigational systems if special navigational techniques are used to
supplement conventional NAVAIDs. Class II navigation includes
transoceanic operations and operations in desolate and remote land areas
such as the Arctic. The primary types of specialized navigational systems
approved for Class II operations include inertial navigation system
(INS), OMEGA, Doppler, and global positioning system (GPS). Figure 4-15
provides several examples of Class I and II navigation.
Old July 24th 05, 05:43 AM
Brien K. Meehan
Ah, cool, thank you very, VERY much for posting those references.
The FAA's policy subject to ICAO membership doesn't make it regulatory,
as the ICAO is a standards organization and holds no sovereignty. If a
DOT organinzation outside the FAA, or a department outside the DOT,
adopted those ICAO standards as regulatory, then the FAA would assume
an indirect regulatory role - even so, the equipment requirement would
be arguable (the equipment assumption is for the purpose of determining
minima, not actual navigation, and regulatory equipment requirements
are otherwise very precise). But, as far as I know, this is not the
case.
The second part describes Class I and Class II navigation, but doesn't
spell out an equipment requirement either. On the contrary, it says
that you don't automatically need equipment appropriate for the
corresponding class of navigation.
Old July 26th 05, 04:58 PM
Steven P. McNicoll
wrote in message ...
That doesn't mean you understand it.
FAA Order 8260.19C places no regulatory requirements upon pilots or the
operation of aircraft.
How are you doing with that reference for the timing tables on NACO charts
being IAS?
Old July 31st 05, 06:28 PM
Steven P. McNicoll
Prior to a recent discussion in this forum you believed the speeds in the
timing tables of NACO charts were IAS. Anybody that worked with this stuff
all the time would have known they were ground speed. It appears you're a
fibber.
Old July 27th 05, 05:08 PM
Clay
Remember.
ALL FAR's are written to violate the pilot.
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
