#11
Chuck,
Thanks. I'll give them a call. Mike On Sat, 23 Jul 2005 22:24:09 GMT, Mike Spera wrote: Tired of the ugly bow tie yokes (and the repetitive inspections). Anyone have 2 ram's horn 1.125" yokes for sale? Piper P/N 79276-00V. Thanks, Mike Mike, I've been trying to replace the bow-tie yokes in my Cherokee 180 since I bought it almost a year ago. You shouldn't have too much trouble finding some for 1 & 1/8th inch shafts -- I've found two or three used parts places that had them. Try Stan at Faeth Aircraft Salvage 916-368-1832. He had a pair and offered them to me for $150 a piece. My only problem is my Cherokee has the older 3/4 inch shafts. Only place that I found with the 3/4 inch shaft yokes wanted $995 EACH! I thanked him and let him know that he shouldn't hold them for me... Recently, I ran across someone selling Cherokee parts on eBay who told me he can get 3/4 inch shaft yokes for $300 each with a 337 for approval. I suspect that means a field approval which I'm not interested in trying for. I've had a couple DERs and IAs tell me the FAA informed them any incoming 337 will sit in an in-basket for at least 90 days before being looked at. And of course, 9/10s of the FAA people are so obsessed with covering their butts -- they won't approve water to put out a fire. So, unless its an approved, PMAed, or STCed part -- I'm not interested. Good luck Mike. And send a post back if you want the names of the other companies. Like I said -- they all had 1 & 1/8 shafts, so they're no use to me... Chuck |
Chuck wrote:
Good luck Mike. And send a post back if you want the names of the other companies. Like I said -- they all had 1 & 1/8 shafts, so they're no use to me... You should be able to sleeve the larger yokes down to 3/4". George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
On Mon, 01 Aug 2005 03:05:56 GMT, George Patterson
wrote: Chuck wrote: Good luck Mike. And send a post back if you want the names of the other companies. Like I said -- they all had 1 & 1/8 shafts, so they're no use to me... You should be able to sleeve the larger yokes down to 3/4". George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. Hi George, You're probably right -- sleeving the inside of the 1&1/8 yokes to fit my 3/4 inch shafts shouldn't be too difficult a challenge. But doing that would require a 337 Field Approval. And that's what I'm trying to avoid. As I mentioned, several IAs and DEs have told me that a Field Approval -- it if can be obtained at all -- will take at least six months. One DE in Austin told me he's had a 337 pending for 14 months for a simple GPS antenna mount on the top the cabin. What a joke. So, I'll go on a while looking for certified 3/4 inch yokes I can put on without a Field Approval. And if I can't find that -- I'll go the Field Approval route. Chuck |
Chuck wrote:
: As I mentioned, several IAs and DEs have told me that a Field Approval : -- it if can be obtained at all -- will take at least six months. One : DE in Austin told me he's had a 337 pending for 14 months for a simple : GPS antenna mount on the top the cabin. What a joke. There we go... "The FAA: Keeping the world safe for bureaucracy" Between that and the CYA seemingly required for absolutely everything in aviation, it's basically impossible/unaffordable to do anything. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() O.K. I bought a couple of units from Faeth. Slight problem. One has a reported bent shaft and the other has "bad chrome" on the shaft. Has anyone swapped the wheels themselves from bowtie to ram's horn (same shaft size)? There appears to be a special pin in the bow ties and they also look to be epoxied on. Is removal from the shaft even approved? Or is this a "factory only" one-time operation that cannot be repeated? How are the ram's horn wheels secured? Do you have to destroy the bowtie to get it off? Anyone swapped the control wheels only? Thanks, Mike Chuck wrote: Good luck Mike. And send a post back if you want the names of the other companies. Like I said -- they all had 1 & 1/8 shafts, so they're no use to me... You should be able to sleeve the larger yokes down to 3/4". George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
Shafts???? I thought you were only replacing the yokes -- why spend
the extra cash on the shafts? Well, if you do need the shafts -- you can get the on with the chrome problem re-chromed. If you can't find a finishing shop around, see any competent gunsmith. Don't let him talk you into any of the newer, fancy coatings/finishes. You need to replace the chrome with the same so its still "factory". And as far as replacing them -- I can't help there. Haven't found any 3/4 inch shaft yokes yet -- so have no idea the magnitude of the job. Good luck Mike. And let us know how it goes... Chuck On Wed, 03 Aug 2005 02:14:29 GMT, Mike Spera wrote: O.K. I bought a couple of units from Faeth. Slight problem. One has a reported bent shaft and the other has "bad chrome" on the shaft. Has anyone swapped the wheels themselves from bowtie to ram's horn (same shaft size)? There appears to be a special pin in the bow ties and they also look to be epoxied on. Is removal from the shaft even approved? Or is this a "factory only" one-time operation that cannot be repeated? How are the ram's horn wheels secured? Do you have to destroy the bowtie to get it off? Anyone swapped the control wheels only? Thanks, Mike Chuck wrote: Good luck Mike. And send a post back if you want the names of the other companies. Like I said -- they all had 1 & 1/8 shafts, so they're no use to me... You should be able to sleeve the larger yokes down to 3/4". George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
Well, I would like to replace the yokes only and use the shafts I have
in there already because they are in perfect condition. The shafts attached to the yokes from the recycler are both shot. My original question still stands: can you remove the yokes from their shafts and remount them. If so, I can swap the yokes I just bought with the shafts in the plane that are now attached to the original bow ties. As I said, the bow ties look to be pinned and epoxied. The aluminum ram horns I just bought look to be pinned and possibly sweated on or pressed on. Is there an approved procedure to remove and remount these yokes??????? What is the "pin" that is used. It does not look like any AN hardware I have ever seen. If I can indeed swap them, I will send the ram's horns out for recoating. If I cannot remove/remount the ram's horns, I will return them to the recycler because they will be junk. Thanks, Mike Chuck wrote: Shafts???? I thought you were only replacing the yokes -- why spend the extra cash on the shafts? Well, if you do need the shafts -- you can get the on with the chrome problem re-chromed. If you can't find a finishing shop around, see any competent gunsmith. Don't let him talk you into any of the newer, fancy coatings/finishes. You need to replace the chrome with the same so its still "factory". And as far as replacing them -- I can't help there. Haven't found any 3/4 inch shaft yokes yet -- so have no idea the magnitude of the job. Good luck Mike. And let us know how it goes... Chuck On Wed, 03 Aug 2005 02:14:29 GMT, Mike Spera wrote: O.K. I bought a couple of units from Faeth. Slight problem. One has a reported bent shaft and the other has "bad chrome" on the shaft. Has anyone swapped the wheels themselves from bowtie to ram's horn (same shaft size)? There appears to be a special pin in the bow ties and they also look to be epoxied on. Is removal from the shaft even approved? Or is this a "factory only" one-time operation that cannot be repeated? How are the ram's horn wheels secured? Do you have to destroy the bowtie to get it off? Anyone swapped the control wheels only? Thanks, Mike Chuck wrote: Good luck Mike. And send a post back if you want the names of the other companies. Like I said -- they all had 1 & 1/8 shafts, so they're no use to me... You should be able to sleeve the larger yokes down to 3/4". George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Tactical Air Control Party Airmen Help Ground Forces | Otis Willie | Military Aviation | 0 | January 22nd 04 02:20 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
