Thanks.... I'll hunt them up at OSH tomorrow (hopefully)
Jim "Michael" wrote in message oups.com... Jim Burns wrote: Could you elaborate more on the Zeftronics system and it's components? I believe that the regulators on our Aztec need adjustment as our left alternator has a larger draw on it than the right. Unfortunately, I know nothing about their alternator system - only the generator system. I've been told that adjusting them isn't particularly fun and would be interested in the Zeftronics system should we find adjusting the regulators does not solve our output imbalance. I'm familiar with the process. I've never seen anyone get it right except by luck. The mechanical regulators don't act the same with the caps on as they do with the caps off. Michael |
Have had a 1960 PA23-250 for almost 10 years now, love it. Two years ago switched from the generators to the InterAv alternator kit. Feel it was the right decision and am pleased with the results. Reasons for switch: 1) Generators do NOT put out any charging current below a certain RPM, in our case it took 1700 RPM to get any appreciable output, they were calling us the AzJet because we were blowing over the 172s behind us in order to keep the battery up. 2) My partner called me several times to come jump start the plane, he would forget to turn off all unneeded lights and radios while taxiing back and the battery would run down. 3) Went through the trouble about 5 years ago to get the generators overhauled, new regulators and balancing relay, still had balance and charging problems. After the conversion: 1) alternators put out good current at idle, radios operate just fine with engines idling. 2) End of dead battery problems, no more dead battery when opening up the plane. 3) I can taxi around without blowing the 172s all over the place. 4) So far (find some wood) have not had a balancing or charging problem. 5) Generator whine (feedback through intercom) is gone, radio sound is noticeably cleaner. Notes to pay attention to: 1) make sure the black ring (the diode holder) on the back of the alternator does not contact anything, has plenty of clearance around it, else it grounds out through the diode holder and will burn out the alternator. 2) Use the old regulator mount on the aft side of the firewall to mount the new regulator assembly to, stays cooler and cleaner, much neater wiring installation. 3) Absolutely replace the output wires with a #4 guage wire up to the fuselage juction block. 4) Use a #4 guage wire to fabricate the ground bonding wire, make absolutely sure the bonding straps on each side of the engine case to the engine mounts are clean and in good condition. 5) Add an additional ground wire from the regulator to the alternator (solved a balance problem). 6) weigh and track all parts coming off and going on, including wires pulled and installed for form 337 weight and balance changes. (Hint: weigh the wire spool before and after you run it, in order to get accurate weight of what was installed.) I am an A&P in the D.C area, my I.A. and Balto FSDO were watching over my shoulders, the more meticulous I was, the happier FSDO got, and signed off the 337 on the spot. Good Luck -- AztecN867DC Powered by www.flight.org |
| Thread Tools | |
| Display Modes | |
| WTB: Piper Aztec C | Jim Burns | Aviation Marketplace | 0 | July 20th 04 08:38 PM |
| Piper Aztec and/or Apache owner groups? | Ronnie D. Hughes | Owning | 3 | April 1st 04 08:00 PM |
| Piper Aztec F Model Dual Hydraulics(1976-1981) STC | Keith | Owning | 4 | February 12th 04 05:52 AM |
| Piper Aztec F Model Dual Hydraulics(1976-1981) STC | Keith | Piloting | 0 | February 11th 04 11:49 AM |
| Piper Aztec handling qualities | John McFarlane | Owning | 1 | October 3rd 03 05:11 PM |
