#11
I just spent 5 years chasing down a similar intermitant problem in my
Mooney. Turned out to be that the alternator had worn the back bearing out of the alternator's case and was causing movement of the shaft against the back of the case. As it torqued under load it would sometimes lose contact. -Robert |
Also, how do you KNOW you have a problem; besides, that is. a flakey
LV warning? Put a DVM on the bus for a flight ************************************************** ************************** B I N G O ! Actually, one of those analog voltmeters from the auto store that you plug into the cigarette lighter should be in everyone's airplane... Also, does your GPS show voltage? The Garmin 295 does, and perhaps others... denny |
Thanks for all the advise folks. If I check the voltage at the
cigarette lighter - any idea what it should be? What voltage would cause the warning light to illuminate? (12,11, 10?). I am going out to work on the plane tonight (first the ground straps then go fly with a voltmeter). I'll let y'all know how it turns out... |
With the engine at ~2000 rpm, the system voltage should be 13.6 to 14.2
volts, depending upon the state of battery charge... denny |
Thanks for the info. By the way, you said the 295 has a voltage field?
Any idea how I get it to display? (I thought only the 296 had that field). |
I have a 1978 M20J Mooney that has been doing exactly that for 15 years.
When I first got the plane it started doing that intermitent flashing. I changed out the voltage regulator twice and the alternator once to no avail. I was then told by someone who should know that it was probably some kind of a phase poblem that was not serious, and that when it happens, just check to be sure the the alternator is charging normally and if it is don't worry about it. He seemed to feel that it would probably go away eventually or get bad enough that it could be tracked down. In fifteen years it has done neither. Sometimes it will go for months without flashing, and then it will sometimes flash for a while on almost every trip. It has long since stopped bugging me and I now just consider it to be a harmless quirk of my bird. Only once in the time that I have had the plane was the warning real and it that case a check of the ampmeter immediately indicated that the alternator was not charging. (the alternator field ground wire had broken.) Incidently, the plane was based at LZU for about a year when I first bought it. However, I am no longer in the Atlanta area. Don I don't know whether this will make you feel better or not. wrote in message oups.com... Can anybody help me diagnose this problem? Just bought my new (to me) 1978 Mooney 201, flew it back from Kansas City to Atlanta, no problem. Flew to Richmond, VA - again no problem. Leaving RIC for Atlanta, the low voltage light started flashing. Didn't want to carry on IFR so stopped into Danville. Left the plane there, and the mechanic removed the altinator and tested it (all ok) and replaced the voltage regulator with a new one. All ok (charging 13.9 volts). Started the plane, the altinator gauge was showing a charge, and took off. About 30 mins into the flight again the low voltage started flashing. By the time I had checked all the CB's it stopped. Then about an hour later it started again. I tried pulling the Alt Field CB and resetting, no joy. It continued to flash untill I was in the pattern at LZU. So, now - what next? Bad Diodes on the Altinator breaking down at altitude?(I was at 8000'), loose altinator belt? (unlikely - it had just been reinstalled). Over voltage on the Altinator causing the Voltage reg to drop off line, and I didn't wait long enough when I reset the Alt-Field circuit breaker? Bad ground straps?? Any and all thoughts welcomed at this point - this is the worst kind of problem to hunt down. Thanks Ian |
Donald Royer wrote: It has long since stopped bugging me and I now just consider it to be a harmless quirk of my bird. Only once in the time that I have had the plane was the warning real and it that case a check of the ampmeter immediately indicated that the alternator was not charging. (the alternator field ground wire had broken.) Incidently, the plane was based at LZU for about a year when I first bought it. However, I am no longer in the Atlanta area. You can never have too many field grounds. I have 3 on my Mooney. They don't cost much and its an easy back up to make. People spend thousands on back up vac systems but sometimes miss the opportunity to spend 5 minutes putting an extra ground wire from the alternator to the frame. -Robert |
Umm, doh , you are right, it is the 296 not the 295... Good thing I
have sharp eyes on the list to keep me honest... Too many GPS to keep track of... Currently I have a 395 and a 296 mounted in the Apache... Recently sold a 295 and a 100 (do I like Garmin GPS or what?)... My first one was the ProNav 100, the factory's, one and only, demonstrator which I pried out of the hands of their CEO on the closing day of the show at 4PM - I ran out of the commercial building, stuffed it into my Super Viking and used it to navigate back to Michigan... From that flight on, I was sold on the benefits of GPS... Garmin later bought them out to get into the GPS business and named it the Garmin GPS 100... denny |
"Denny" wrote, "... Currently I have a 395 and a 296 mounted in the
Apache..." What is a 395? |
Thanks, I think, Don!
I don't like the idea of an intermittant flashing warning light. But for now, I have put an in-line digital volt meter in the cigarette lighter, and will be able to keep an eye on the voltage. I am probably going to replace the battery and alternator, just to be safe, and of course recheck all the grounds, and perhaps try to check the wiring to the warning panel. But if that doesn't stop it, then, I hope I get to the point that it doesn't bother me! Thanks to everyone for the input! Ian "Donald Royer" wrote in message link.net... I have a 1978 M20J Mooney that has been doing exactly that for 15 years. When I first got the plane it started doing that intermitent flashing. I changed out the voltage regulator twice and the alternator once to no avail. I was then told by someone who should know that it was probably some kind of a phase poblem that was not serious, and that when it happens, just check to be sure the the alternator is charging normally and if it is don't worry about it. He seemed to feel that it would probably go away eventually or get bad enough that it could be tracked down. In fifteen years it has done neither. Sometimes it will go for months without flashing, and then it will sometimes flash for a while on almost every trip. It has long since stopped bugging me and I now just consider it to be a harmless quirk of my bird. Only once in the time that I have had the plane was the warning real and it that case a check of the ampmeter immediately indicated that the alternator was not charging. (the alternator field ground wire had broken.) Incidently, the plane was based at LZU for about a year when I first bought it. However, I am no longer in the Atlanta area. Don I don't know whether this will make you feel better or not. wrote in message oups.com... Can anybody help me diagnose this problem? Just bought my new (to me) 1978 Mooney 201, flew it back from Kansas City to Atlanta, no problem. Flew to Richmond, VA - again no problem. Leaving RIC for Atlanta, the low voltage light started flashing. Didn't want to carry on IFR so stopped into Danville. Left the plane there, and the mechanic removed the altinator and tested it (all ok) and replaced the voltage regulator with a new one. All ok (charging 13.9 volts). Started the plane, the altinator gauge was showing a charge, and took off. About 30 mins into the flight again the low voltage started flashing. By the time I had checked all the CB's it stopped. Then about an hour later it started again. I tried pulling the Alt Field CB and resetting, no joy. It continued to flash untill I was in the pattern at LZU. So, now - what next? Bad Diodes on the Altinator breaking down at altitude?(I was at 8000'), loose altinator belt? (unlikely - it had just been reinstalled). Over voltage on the Altinator causing the Voltage reg to drop off line, and I didn't wait long enough when I reset the Alt-Field circuit breaker? Bad ground straps?? Any and all thoughts welcomed at this point - this is the worst kind of problem to hunt down. Thanks Ian |
| Thread Tools | |
| Display Modes | |
| Landing a Mooney | Jon Kraus | Owning | 42 | November 16th 04 08:00 PM |
| Landing a Mooney | iain_hutchison | Piloting | 0 | November 4th 04 03:38 PM |
| Mooney M20 K on Grass ? | Andrew Boyd | Owning | 0 | August 13th 04 04:00 PM |
| Loading luggage in other than Mooney | Robert M. Gary | Piloting | 21 | June 28th 04 07:23 PM |
| Anyone have experience with InterAv alternator | flyer | Home Built | 6 | October 19th 03 04:24 AM |
