Minden: Best part of season for XC flights?
Old August 4th 05, 04:05 PM
JJ Sinclair
Paul,
Check your CG on the LS-7, bet its about 50% of allowable range. Most
standard class ships should be flown around 85%. A nose heavy ship will
require constant tugging on the pole and lead you to believe it wants
to be flown faster.
Consider adding some weight under the horizontal stab, but be sure and
remove it after your flight, so as to not give the next club pilot an
unexpected thrill. Consider adding a tail tank so each club pilot can
trim the ship to his/her weight, but once again, remember to dump the
tail tank after your flight.
Luck,
JJ
Old August 4th 05, 07:41 PM
Lars Peder Hansen
Flavio Formosa has written an excellent report on the LS7:
http://www.segelflug.de/tests/LS7-WL/LS7-WL.html
Lars Peder
"Paul" wrote in message
Thanks for your input Stefan. Perhaps I should have explained why I
asked. I am a relatively new pilot, about 240 hours and about that many
flights in last 4 years. I have been flying club LS7 (with winglets)
for a fair portion of that time. Last season I have found my self
thermalling faster then I should - often at around 60 knots. Not a good
way to improve one's cross country flying. Do not get me wrong, I do
blame the plane, I am sure the fault is entirely mine. I was just
seeking an input from an experienced pilot.
Paul
Stefan wrote:
Paul wrote:
I know this is of topic but I would like your opinion on LS-7.
Flyability, climbing ability, speed to fly in thermals.
If you're looking at that last half point of L/D, then it has some draw
backs. It punishes lazy flying, you mustn't fly it too slowly, it looses
in turbulence. But if you're looking for feeling, exact and light
controls, for a plane which reads your thoughts and immediately tells
you every thermal, in a word for the pure joy of flight, then I don't
know a better plane than the LS7.
I'm talking of the version with winglets here. If yours doesn't have
winglets, then add them, the conversion is well worth the cost!
Stefan
Old August 4th 05, 09:19 PM
John Galloway
Paul,
I think you might possibly be thermalling the LS7 too
fast because it sits very nose high in thermals - disconcertingly
so if you are not used to a slippery glider with such
a low angle of wing incidence. There are few gliders
as nose high as the LS7 at slower speeds - the Discus
2 is similar.
John Galloway
At 12:06 04 August 2005, Paul wrote:
Hi John
Thanks for your reply John, I have explained why I
asked, in a reply to
Stefan couple of posts above so I will not repeat my
self here. Clearly
both of you regard it highly in terms of flyability.
I was just
wondering if my 'need for speed' and hence a crisper
controls might have
been somehow related to the aircraft. I am happy to
sit on 45knots in a
Puch in any thermal, but ending up at 60knots in the
LS.
Paul
John Sinclair wrote:
At 07:06 03 August 2005, Paul wrote:
Hi John
on LS-7.
Thank you
Paul
Hi Paul,
Being in the repair business, I have owned a bunch
of sailplanes over the years, acquiring most of them
after they met with misfortune at the hands of their
previous owners. I have been pleasently surprised
at
the performance of many ships that have been branded
'unworthy' by the racing hotshots. The LS-7 falls
into
this category, sweet flying machine. Can't really
find
much in the way of a fault. The wing is smaller than
its predecessor (105 sq. / ft. VS 113 on the LS-4)
so, it might have a bit more trouble working that
one
knot turbulent thermal, but other than that, I can't
fault the old girl.
BTW, the Genesis-2 also falls into this category,
she's
another 'secret weapon', cruised right with those
18
meter hotshots at Montague last week. I'm thinking
about installing a CG shifter. Anybody have any real
proof they work? I'm convinced CG shifting doesn't
work on conventional sailplanes, but am wondering
on
this flying wing thing?
JJ
19th of June, 1993 was the magic day for me, 1011.52
Km and 1000K badge #225, all thermals in an LS-7 &
a full load of water,
Old August 5th 05, 08:46 AM
Paul
Thanks Lars, I have now read it, indeed it is an excellent report.
Paul
Lars Peder
Old August 5th 05, 08:56 AM
Paul
JJ Sinclair wrote:
Paul,
to be flown faster.
Hi John
Yes, I am close to 105 kg with a chute, so the CG would be well forward.
I did fly it with 3l of water in the tail tank on the advise of a very
experienced instructor, whilst I thought it handled better, I was still
ending up too fast. Anyway I have now spent most of the winter (in a
different glider) forcing my self to thermal slowly, so hopefully it
will pay dividends , once the summer gets going.
Cheers
Paul
Old August 5th 05, 01:42 PM
Paul
Yes John, I am aware of that one and I am sure it does not help .
cheers
Paul
John Galloway wrote:
Paul,
2 is similar.
John Galloway
Radio outage at ZLA grounds flights A Guy Called Tyketto Piloting 0 September 15th 04 06:56 AM
Stiffness of finished Carbon Fiber part RKT Home Built 3 April 8th 04 03:00 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 01:14 PM
how I map my flights Snowbird Instrument Flight Rules 10 December 1st 03 12:26 AM
Proposed new flightseeing rule C J Campbell Home Built 56 November 10th 03 06:40 PM
