#11
Isn't that what he said?
Andy |
"Andy" wrote
Isn't that what he said? Nope! Bob |
ORVAL FAIRAIRN wrote:
In the US, all you need is three takeoffs and landings at night within the past 90 days to be qualified at night -- no IFR, "night rating," etc. to carry passengers; if you go on your own, you don't even need that. --Sylvain |
Bob Moore wrote: ORVAL FAIRAIRN wrote In the US, all you need is three takeoffs and landings at night within the past 90 days to be qualified at night -- no IFR, "night rating," etc. I don't think so, Orval.... (b) Night takeoff and landing experience. (1) Except as provided in paragraph (e) of this section, no person may act as pilot in command of an aircraft CARRYING PASSENGERS during the period beginning 1 hour after sunset and ending 1 hour before sunrise, unless within the preceding 90 days that person has made at least three takeoffs and three landings to a full stop during the period beginning 1 hour after sunset and ending 1 hour before sunrise, and— (i) That person acted as sole manipulator of the flight controls; and (ii) The required takeoffs and landings were performed in an aircraft of the same category, class, and type (if a type rating is required). Isn't that what I said (abbreviated)? |
Isn't that what I said (abbreviated)? Nope! Your post implied that to be night current, one needs the takeoffs and landings....not true, I can fly solo at night with no requirements other than the initial certification requirements. There was no mention of pax in your post. Bob Moore |
Bob Moore wrote: ORVAL FAIRAIRN wrote Isn't that what I said (abbreviated)? Nope! Your post implied that to be night current, one needs the takeoffs and landings....not true, I can fly solo at night with no requirements other than the initial certification requirements. There was no mention of pax in your post. Bob Moore I guess that is true -- after all, that is what I have to do to get night current again. But, we don't have any "night rating" over here -- thank God! |
Are you kidding? Have you ever tried to find an ANO reference for anything?
I can't make heads or tails out of that silly document. You're much more technically correct that I intended to be. I was only trying to point out the original poster was in error about the IMC rating. Shawn "Peter" wrote in message ... "ShawnD2112" wrote You need an IMC rating to fly in IMC but it doesn't give you the full priveleges of an IR (Class A use, for instance). It is merely to teach you to fly in marginal weather. Do you have an ANO reference for the last sentence of the above? The IFR privileges of the UK IMC Rating are essentially those of the JAA IR, but limited to the UK, no Class A, and 1800m min vis. Everything else is an opinion; fair enough but it's just that. One can do perfectly safe fully-IFR flights, in solid IMC, with its privileges. Just like the full IR, it needs currency and a suitable aircraft and these cost serious time and money. Unfortunately it's no good outside the UK, for IFR. Its possession removes the UK PPL *VFR* requirement to be in sight of surface and that removal is valid everywhere where they have not added the "must be in sight of surface" requirement to the ICAO PPL (got that in writing from the CAA). |
On Thu, 11 Aug 2005 7:08:08 +0100, ShawnD2112 wrote
(in message ) : Are you kidding? Have you ever tried to find an ANO reference for anything? I can't make heads or tails out of that silly document. You're much more technically correct that I intended to be. I was only trying to point out the original poster was in error about the IMC rating. If you are referring to my post at 9:02 yesterday, then please go back and read it again - I did NOT mention IMC rating or flying in IMC, only IFR ! IFR is not the same as IMC, you can easily fly IFR in VMC. I wrote : Not to mention that in the UK a basic PPL with no ratings can fly IFR, and only needs a Night Qualification to fly at night. I understand that elsewhere, any night flying (as here) is IFR, and IFR is not allowed without a full IR. Hence even night flying requires an IR outside the UK. In hindsite I suppose I should qualify that statement as "Hence even night flying requires an IR IN MANY COUNTRIES outside the UK." since I am aware that the UK is not the only place that allows night flight without an IR. |
Good point. I'll read more closely next time.
Shawn "Simon Hobson" wrote in message et... On Thu, 11 Aug 2005 7:08:08 +0100, ShawnD2112 wrote (in message ) : Are you kidding? Have you ever tried to find an ANO reference for anything? I can't make heads or tails out of that silly document. You're much more technically correct that I intended to be. I was only trying to point out the original poster was in error about the IMC rating. If you are referring to my post at 9:02 yesterday, then please go back and read it again - I did NOT mention IMC rating or flying in IMC, only IFR ! IFR is not the same as IMC, you can easily fly IFR in VMC. I wrote : Not to mention that in the UK a basic PPL with no ratings can fly IFR, and only needs a Night Qualification to fly at night. I understand that elsewhere, any night flying (as here) is IFR, and IFR is not allowed without a full IR. Hence even night flying requires an IR outside the UK. In hindsite I suppose I should qualify that statement as "Hence even night flying requires an IR IN MANY COUNTRIES outside the UK." since I am aware that the UK is not the only place that allows night flight without an IR. |
On Thu, 11 Aug 2005 06:08:08 GMT, "ShawnD2112"
wrote: Are you kidding? Have you ever tried to find an ANO reference for anything? I can't make heads or tails out of that silly document. You're much more technically correct that I intended to be. I was only trying to point out the original poster was in error about the IMC rating. Shawn "Peter" wrote in message .. . "ShawnD2112" wrote You need an IMC rating to fly in IMC but it doesn't give you the full priveleges of an IR (Class A use, for instance). It is merely to teach you to fly in marginal weather. Do you have an ANO reference for the last sentence of the above? The IFR privileges of the UK IMC Rating are essentially those of the JAA IR, but limited to the UK, no Class A, and 1800m min vis. Everything else is an opinion; fair enough but it's just that. One can do perfectly safe fully-IFR flights, in solid IMC, with its privileges. Just like the full IR, it needs currency and a suitable aircraft and these cost serious time and money. Unfortunately it's no good outside the UK, for IFR. Its possession removes the UK PPL *VFR* requirement to be in sight of surface and that removal is valid everywhere where they have not added the "must be in sight of surface" requirement to the ICAO PPL (got that in writing from the CAA). If you look at the ANO under Schedule 8 it gives the PPL privileges of an IMC and Night Rating: http://www.legislation.hmso.gov.uk/s...0/20001562.htm As for Operating Mimima this is in the AIP under Aerodromes General AD-1. In particular from section AD 1-1-6: http://www.ais.org.uk/aes/pubs/aip/p...omes/30101.PDF As noted previously you may only wish to "fly in marginal weather" but you can legally fly "fully-IFR flights, in solid IMC". The CAA may wish to stress it's only to get you out of trouble but that is only their recommendation. I have an IMC rating and usually file IFR on longer flights in the UK, especially as flights over the Cairngorm Mountains are rarely blue skies! Sometimes I can get on top at FL70 to FL10. If only I could use the IMC rating when on holiday.. David |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
