Cri-Cri Jet
Old August 15th 05, 08:42 PM
Roger wrote:
On Fri, 12 Aug 2005 20:51:20 -0500, Darrel Toepfer
Roger wrote:
Hmmmm at 30 GPH per side, (those little engines use a lot of fuel)
That's about 5 minutes total . Yah outta be able to make some where
around 5,000 to 10,000 feet before flame out. Gas is needed for
climb, but optional for landing.
Wow, that RC/B52 had 8 of them... Seems excessive, without going back to
research it on the manufacters website for a looksee...
I didn't see this line back in the thread so here's some shots of the
twin engine Kri Kri http://www.amtjets.com/gallery_real_plain.html
The larger engine uses 22.5 ounces of fuel per minute, or 1,350 per
hour. That at roughly 6# per gallon that is 14 GPH. (The add said
they had improved efficiency ) Go to http://www.amtjets.com
and select specifications. The fuel consumption is near the bottom
of the chart.
That works out to be 28 per hour or a whole 10 minutes with 5 gallons
on board.
www.rogerhalstead.com
28 lbs/hour......or am i missing something, but 28 lbs/hour gives you
almost a full hour with 2 pound researves.......I also believe those
fuel flow figures to be at max thrust.......anyone know
Old August 20th 05, 06:55 PM
Darrel Toepfer wrote:
Montblack wrote:
("Darrel Toepfer" wrote)
Does the twin-jet Cri-Cri still exist or does someone need to build
one to get the Guiness mistake fixed?
Light Sport Pilot has the restrictions of no turbines and no twins,
however, Part 103 has no such restrictions - but 103 does have the fuel
limit of 5 gallons, speed limit of 63 mph and the weight limit of 254
lbs. Safety equipment can be added above and beyond the 254 limit
...like how about another 5 gallons of fuel please - for safety!
http://www.ultralighthomepage.com/FAR.part103.html
FAR Part 103:
Guiness World Record smallest jet, only cares about it being a "jet" and
"162 kg" max weight...
Now if you actually want to fly it (apparently Yawn doesn't), then you
can do the FAA paperwork for what classification you desire...
I will contribute to the cause, that has the current record holder
replaced...
There appear to be new contenders:
http://www.priceless420.com/Pr081905planepractice1.jpg
FF
Old August 20th 05, 09:00 PM
Anthony W
I'll bet those fly at least as well as wuan's bd5.
Tony
Old August 20th 05, 09:44 PM
Roger
On Sat, 20 Aug 2005 20:00:12 GMT, Anthony W
Yah, but will the landing gear hold together through rotation?
Tony
Old August 21st 05, 04:49 PM
Darrel Toepfer
I'm sure zzzoom could roll, loop and spin them...
Old August 21st 05, 06:25 PM
Anthony W
Well, spin anyway...
Old September 2nd 05, 10:39 PM
Juan Jimenez
"Darrel Toepfer" wrote in message
Nope. The Cri-cri is _longer_ than the BD-5J. That's why the BD-5J has held
the record for more than 25 years.
Old September 3rd 05, 05:12 AM
Darrel Toepfer
I think they need to reconsider by using weight and surface area...
Old September 3rd 05, 11:43 AM
enewbold enewbold is offline
Junior Member
First recorded activity by AviationBanter: Sep 2005
There's a Yahoo group that has a large number of members who either build or fly the Cri Cri. They probably could tell you how many are flying in the US:
http://groups.yahoo.com/group/CriCri/
