#11
Click the mic and turn the lights on.
On 14 Aug 2005 07:54:47 -0700, Doug wrote:
Click the mic and turn the lights on. Doug, No PCL per Duat. Allen |
On Sun, 14 Aug 2005 10:46:09 -0500, A Lieberman
wrote: On 14 Aug 2005 07:54:47 -0700, Doug wrote: Click the mic and turn the lights on. Doug, No PCL per Duat. Allen PCL on 122.8 per the Jepp approach chart Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
wrote in message ...
The reason I ask about the phone is because you could have opted to cancel IFR and then do whatever you wanted to do to get in and land. In the absence of radio or phone contact, can you unilaterally cancel IFR and inform ATC after you land? --Gary |
Go MISSED! It is descending below the MDA like this that caused the
Gulfstream crash at Aspen. Trying to "stuff it in" they discovered the visibility blocked the runway and they CRASHED and DIED. |
![]() Gary Drescher wrote: wrote in message ... The reason I ask about the phone is because you could have opted to cancel IFR and then do whatever you wanted to do to get in and land. In the absence of radio or phone contact, can you unilaterally cancel IFR and inform ATC after you land? --Gary For non-commercial operations I don't see why not. But, it's not clean and someone may say it was wrong to hold the airspace when you had "cancelled" as a state of mind. Or, some might argue that a cancellation does not take effect until ATC acknowledges its receipt. Murky waters but I suspect the not-for-hire pilot would prevail in any enforcement proceeding. It's more of an issue of ATC policy as opposed to regulations, per se. |
Gary Drescher wrote: wrote in message ... The reason I ask about the phone is because you could have opted to cancel IFR and then do whatever you wanted to do to get in and land. In the absence of radio or phone contact, can you unilaterally cancel IFR and inform ATC after you land? --Gary For non-commercial operations I don't see why not. But, it's not clean and someone may say it was wrong to hold the airspace when you had "cancelled" as a state of mind. But if the alternative were to not cancel at all, then the airspace would be just as held-up. Or, some might argue that a cancellation does not take effect until ATC acknowledges its receipt. Yup, that's what I'm unsure about. Also, if you did cancel unilaterally, would you then squawk 1200 in case ATC still had radar contact? --Gary |
wrote in message ... The reason I ask about the phone is because you could have opted to cancel IFR and then do whatever you wanted to do to get in and land. In the absence of radio or phone contact, can you unilaterally cancel IFR and inform ATC after you land? How do you "unilaterally" cancel IFR? Matt |
![]() Doug wrote: Go MISSED! It is descending below the MDA like this that caused the Gulfstream crash at Aspen. Trying to "stuff it in" they discovered the visibility blocked the runway and they CRASHED and DIED. That was a night approach into an airport that is marginally (at best) an IFR airport. And, it was a jet airplane. A single-engine light aircraft going to a relatively flat-land CAT A/B only airport in the daytime, and with pretty good weather is a very different set of circumstances than what happened at Aspen. |
![]() Gary Drescher wrote: wrote in message ... The reason I ask about the phone is because you could have opted to cancel IFR and then do whatever you wanted to do to get in and land. In the absence of radio or phone contact, can you unilaterally cancel IFR and inform ATC after you land? No. |
ASW19b best descent rate on approach (full airbrakes) | Robert Sharpe | Soaring | 1 | April 30th 05 11:41 AM |
descent below minimums | hsm | Instrument Flight Rules | 82 | January 11th 05 06:33 PM |
BRS and descent rate | Roger Long | Piloting | 21 | May 7th 04 05:34 PM |
Avoiding Shock Cooling in Quick Descent | O. Sami Saydjari | Owning | 32 | January 21st 04 04:32 AM |
Minimum rate of climb or descent | Aaron Kahn | Instrument Flight Rules | 3 | July 25th 03 03:22 PM |
