I have a 296. The terrain feature is nice. If you have the money get the 396
I tested one and it is incredible. "Ronald Gardner" wrote in message ... As a new PPL your call to Flight Service should negate need for weather. Try finding a used Garmin 295 on ebay. Not sure what they now go for but with the new stuff out the prices should have dropped. I picked one up on a great deal several years ago and I think it is great for PPL VFR. With the yoke mount it does not cover up a large portion of instrument panel, but because it is close to you the smaller screen is fine. Ron Gardner Jase Vanover wrote: Background... newly minted PPL, looking to ease navigation via GPS. I actually find it cool to navigate via maps, compass and timepiece, but I realize there is a lot more capability out there. I'll be renting for awhile, so portability is important. I've done the standard research (including searching prior posts on this newsgroup), but still have a few questions that remain unanswered. The Garmin 396 looks pretty awesome. I don't know if I'll fly enough to warrant the Wx subscription, but I have a healthy respect for weather and so lean towards it for the additional security. The only downside I see in the 396 is screen size. I like what I've seen of the Avmap (Jay... figure I can count on your endorsement here, based on reading past postings). I think all it's missing vs. the 396 is weather. Would be interesting to know if anyone has heard if this will be a soft upgrade in the future. Also, I believe the Avmap is direct powered from the plane, and I don't know if and how this will be possible on rental aircraft. Any insight? I've also run into the Flight Cheetah in my searches, though haven't found much talk about it on the newsgroups. It seems to have everything, but I hesitate to be a "test pilot" being a neophyte at flying to start with. I won't say cost isn't an issue, but I have room enough to spare to pretty much get whatever portable is best. I welcome any and all advice on the issue. Thank you to all in advance. |
Jase Vanover wrote:
Also, I believe the Avmap is direct powered from the plane, and I don't know if and how this will be possible on rental aircraft. Any insight? As a practical matter, I think the Garmin 396 will require ship's power as well. It has rechargables that recharge from your 12 v. outlet. Dave |
Dave Butler wrote:
Jase Vanover wrote: Also, I believe the Avmap is direct powered from the plane, and I don't know if and how this will be possible on rental aircraft. Any insight? As a practical matter, I think the Garmin 396 will require ship's power as well. It has rechargables that recharge from your 12 v. outlet. Dave The AvMap EKP-IV has backup battery capability to run the unit for about an hour after loss of power. You supply your own AA rechargeables. In normal use it's powered via the auxillary power receptacle a.k.a. cigar lighter. One thing I have noted about my EKP-IV is that it produces radio noise on the aviation frequencies. |
![]() "10Squared" wrote One thing I have noted about my EKP-IV is that it produces radio noise on the aviation frequencies. Hard to believe that an aviation GPS would cause problems with your aviation radios. Does it make noise on the batteries and the power converter? Power converters are often the source of much RF noise. I also would be interested in hearing from other EKP-IV owners, to see if they experience these problems, also. If not, it could be a problem with you radio installation. -- Jim in NC |
"10Squared" wrote
One thing I have noted about my EKP-IV is that it produces radio noise on the aviation frequencies. Morgans wrote: Hard to believe that an aviation GPS would cause problems with your aviation radios. Does it make noise on the batteries and the power converter? Power converters are often the source of much RF noise. I also would be interested in hearing from other EKP-IV owners, to see if they experience these problems, also. If not, it could be a problem with you radio installation. It is a tablet computer with a gps receiver. The power supply, processor clock and display driver are all sources of RF noise. |
Morgans wrote:
"10Squared" wrote One thing I have noted about my EKP-IV is that it produces radio noise on the aviation frequencies. Hard to believe that an aviation GPS would cause problems with your aviation radios. Yeah, that was my reaction. I noticed on my Icom IC-A23 handheld that I was getting static on 122.8. I turned the squelch up all the way and that didn't help. Turned off the AvMap and that cured the problem. Proximity to the unit was a factor, but I haven't done any additional tests to quantify the amount of interference or the specific sources of interference (power cable, antenna, or cpu). Does it make noise on the batteries and the power converter? Power converters are often the source of much RF noise. Not sure what you mean by power converter. There is a power cord for DC power from the aircraft to the GPS. However, since the batteries are for emergency use the only practical configuration is with the unit powered by the aircraft power supply. I also would be interested in hearing from other EKP-IV owners, to see if they experience these problems, also. If not, it could be a problem with you radio installation. Me too. And note too, AvMap Navigation has turned off their web forum on their website. |
Repeat after me. A handheld is NOT an aircraft radio. Devices tested to
work with "normal" aircraft radios may or may not work with handhelds. The designer did not intend the antenna of the radio to be less than a meter from the device he tested. A handheld is NOT an aircraft radio. Most of them do NOT have the noise suppression capability OR the filtering of an aircraft radio. Jim "10Squared" wrote in message .. . Morgans wrote: Yeah, that was my reaction. I noticed on my Icom IC-A23 handheld that I was getting static on 122.8. |
![]() Morgans wrote: "10Squared" wrote ... Power converters are often the source of much RF noise. Yes. One of our cell phone rechargers wipes out the AM radio in the car. The noise is especially noticeable when tuned to a weak station near the bottom of the dial. |
Dave wrote:
As a practical matter, I think the Garmin 396 will require ship's power as well. It has rechargables that recharge from your 12 v. outlet. Certainly it would be most convenient to plug it in if that's available. But with a rated battery life of 5 - 15 hours depending on backlight use it appears to be usable in rental planes without a suitable outlet, especially if one brings along an extra charged battery pack. OTOH, the one hour battery life on the Avmap seems designed as an emergency backup in the event of an electrical power failure. |
In article .com,
"peter" wrote: As a practical matter, I think the Garmin 396 will require ship's power as well. It has rechargables that recharge from your 12 v. outlet. Certainly it would be most convenient to plug it in if that's available. But with a rated battery life of 5 - 15 hours depending on backlight use it appears to be usable in rental planes without a suitable outlet, especially if one brings along an extra charged battery pack. OTOH, the one hour battery life on the Avmap seems designed as an emergency backup in the event of an electrical power failure. Folks seem to be reporting battery life quite a bit less than 5 hours when using XM on the 396. And, do you really want to shut down the GPS in flight, change a battery, and power it back up again? Doesn't seem too practical to me. I suspect that you would see much better battery life on the 396 if you did not use the XM features. JKG |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
