PLANE FLIES FOR TWO HOURS WITH WING MISSING
Old August 20th 05, 05:36 PM
Thats a turbine, i have worked on one and you can tell because of how
large the exast is and the prop is feathered like a turbine, single
engine recipes don't feather all the way.
Drew Dalgleish wrote:
Doesn't look like a turboprop though. Those look like normal stacks
to me.
www.rogerhalstead.com
Looks to me that the prop is fully feathered. Would that not indicate
that it's a turbine?
Old August 20th 05, 05:40 PM
Missing a few feet of wing in the pictures, for sure, but
that doesn't mean that it happened in flight, nor that it flew that
way. I've seen similar pictures of aircraft damaged that way on the
ground by trucks or other aircraft, or even by bad landings in strong
crosswinds. Even taxying too close to a signpost at excessive speed
could do it. The end of the wing is badly mashed and would present huge
drag and really serious controllability problems.
Let's see:
Mashed left wingtip, massive drag requiring all the
rudder he has, maybe not enough at that.
Loss of lift from mashed wing section (disturbed airflow)
requiring extra lift from aileron, which itself is a third gone
Loss of lift because part of wing is missing, meaning
more aileron required. Those ailerons simply can't make up the
difference.
And nobody noticed. Right.
The engine is probably a Soloy conversion, more
common on 206s. An Allison turbine set up to drive a prop.
Dan
Old August 20th 05, 10:21 PM
Roger
On Sat, 20 Aug 2005 16:11:05 GMT, (Drew
to me.
I'd think so. I missed that photo.
Old August 21st 05, 03:09 AM
Harry K
Flyingmonk wrote:
Harry K wrote:
pics look like it would and I don't think that is 5 1/2 ft missing), If you look closely at pic 100-0491, the first picture, you will see that about 3' of the aileron is missing and the wing tip extension accounts for the other 2-1/2' .
Bryan
Yeah, I guess you're right. My fist impression was that the if it were
5 1/2' the entire wing would be excessively wrong. Nope, doing a quick
scale job on the right wing makes it only about 15 or 16 ft long. That
yields just under 1/3 of the wing gone. Yeah, right it flew that way
and noone noticed.
Harry K
Old August 21st 05, 04:42 AM
So...even though the missing parts were found on the ground in Ireland,
where the flight departed, and the aircraft landed in Jersey missing
them, you somehow don't believe it happened???
So. You believe everything you read on the Internet? Just because
it's in the paper, or because someone published this "article" on the
'net, doesn't make it true. I'm tired of being sucked into 'net hoaxes.
I'm a pilot and an aircraft mechanic. I'm really having
trouble believing this one.
Dan
Old August 21st 05, 08:55 PM
Rich Ahrens
hoaxes.
Well, a Pinckneyville attendee (who prefers to remain nameless) knows
the pilot on the flight and has shared information with me, so yes, I
believe it happened. Of course that won't convince you, but since you
don't my source yourself, his posting here wouldn't do any good either.
I'm guessing that even reports from the IAA or AAIB wouldn't persuade you.
I'm a pilot and an aircraft mechanic. I'm really having trouble
believing this one.
And I'm part-owner of a 182 which hit a tree on a missed approach,
ripping off the left wing tip and crushing the leading edge of the left
wing from the strut out to what was left, among other damage. The folks
on board flew it back from Duluth to Minneapolis in that condition at
night. They damned well knew something was wrong, and I'm sure the 210
crew must have as well - that part smells of ass-covering. But it flew,
and I believe the 210 did as well. The evidence is incontrovertible.
Here's that 210 in happier times, for anyone interested:
http://www.pacnetair.com/aircraft.html
Old August 21st 05, 09:14 PM
Wrong. A respectably-published report would convince me. I'll
wait until someone points it out.
The pictures look like it had STD'd fiberglass wing extensions
or Flint tip tanks, and if so, that may be all that's missing, not part
of the actual wing structure. And not five feet. Whacking off wing
structure will often damage the wing root structure as well, causing
much more serious damage.
Dan
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 03:52 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
