Soundwaves Boost Wing Lift
Old August 21st 05, 09:16 PM
There is one other significant fact not mentioned. Turbulent drag,
basically a fluid flow is highly unstable. There is the classical
statement of the butterfly in Japan causing a hurricane in the Gulf.
This represents the control of chaos. Stalling represents the complete
breakdown of laminar flow. So it will not only improve stall
performance, it will (potentially) reduce fuel consumption. Turbulent
drag is caused by vorices in an unstable fluid flow. Fewer vortices =
more kilometers, fewer liters.
Old September 5th 05, 02:37 AM
Jim Rodgers
Makes one wonder what the technique could do for prop performance. Any
thoughts?
" wrote in message
Here's some news that recently came out:
http://www.newscientist.com/article.ns?id=dn7867
http://abc.net.au/science/news/stories/s1439827.htm
Apparently, soundwaves can help airflow stay near the wing and increase
lift. This can help smaller aircraft to avoid stalling at lower
airspeeds. Is this a technology that could be usefully applied to
existing small aircraft? Or would it require some totally new design
thinking?
Old September 5th 05, 03:58 AM
ORVAL FAIRAIRN
thoughts?
" wrote in message
thinking?
It would be really difficult to mount the equipment inside a prop's
blades!
Old September 5th 05, 04:18 PM
I don't see why not. Chips have been fired out of guns. Shells are now
intelligent. The chips would go into the hub and there would be a
printed circuit on the prop. No I don't see anything impossible.
Old September 5th 05, 02:12 PM
niceguy
Why not add a canard to all small A/C?
" wrote in message
thinking?
Old September 5th 05, 10:21 PM
Consider a propeller.
Transmission of vibration from the engine mechanicals and torque pulses
must produce tremendous vibrations in every propeller. These vibrations
must produce similar effects as these soundwaves. Maybe this is why
propeller blades seem to be able to tolerate higher angle of attack
before stalling than wings.
Who does flight plans? Michael 182 Piloting 158 July 4th 05 02:50 AM
Lift Query Avril Poisson General Aviation 8 April 21st 05 07:50 PM
Tamed by the Tailwheel [email protected] Piloting 84 January 18th 05 04:08 PM
A Level 1 AOA clarification Ramapriya Piloting 64 January 9th 05 01:19 AM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
