#11
"Scott" wrote in message
... I think it's the other way around...what can a Maule do that a Scott 3200 can't do? SHIMMEY! Years ago we put a Maule pneumatic on our Cessna 140 to replace the hard rubber tire Scott 2000. Never could get the Maule to work well, so we went back to the Scott. Amen to that! Rich "Sold the Maule on eBay" S. |
On Wed, 24 Aug 2005 09:00:29 -0400, " jls" wrote:
"Scott" wrote in message ... I think it's the other way around...what can a Maule do that a Scott 3200 can't do? SHIMMEY! Years ago we put a Maule pneumatic on our Cessna 140 to replace the hard rubber tire Scott 2000. Never could get the Maule to work well, so we went back to the Scott. The other thing that is nice on the 3200 is dual forks. That just HAS to be better than a single fork in rough field operations... Scott, I have seen those Scott forks bend, warp, crack, break and be re-welded. Knock on wood, but I have never seen that big brawny fork on a Maule crack or break. I have never had a Maule shimmy on my aircraft, but have fixed a Cub's Maule that shimmied because the tailsprings had been improperly installed and the wheel was mis-rigged. One of the Fly Baby crowd put together a paper on the care and feeding of Maule tailwheels: http://www.bowersflybaby.com/tech/Maule_Tailwheel.pdf He recommends dissimilar springs to discourage shimmy, and says that binding or looseness in the assembly itself encourages it. Myself, I haven't had a problem. Ron Wanttaja |
![]() "Ron Wanttaja" wrote in message ... On Wed, 24 Aug 2005 09:00:29 -0400, " jls" wrote: "Scott" wrote in message ... I think it's the other way around...what can a Maule do that a Scott 3200 can't do? SHIMMEY! Years ago we put a Maule pneumatic on our Cessna 140 to replace the hard rubber tire Scott 2000. Never could get the Maule to work well, so we went back to the Scott. The other thing that is nice on the 3200 is dual forks. That just HAS to be better than a single fork in rough field operations... Scott, I have seen those Scott forks bend, warp, crack, break and be re-welded. Knock on wood, but I have never seen that big brawny fork on a Maule crack or break. I have never had a Maule shimmy on my aircraft, but have fixed a Cub's Maule that shimmied because the tailsprings had been improperly installed and the wheel was mis-rigged. One of the Fly Baby crowd put together a paper on the care and feeding of Maule tailwheels: http://www.bowersflybaby.com/tech/Maule_Tailwheel.pdf He recommends dissimilar springs to discourage shimmy, and says that binding or looseness in the assembly itself encourages it. Myself, I haven't had a problem. Ron Wanttaja Excellent site, Ron. Just what you need --- the vertical shaft tilted 15 to 20 deg. forward, compression (not tension) springs with asymmetrical recoils, the assembly rigged true at the leaf springs so there's no lateral tilt of the wheel, and no slop in the leaf springs or chains. If there's no slop in the wheel assembly you won't get any shimmy. In 20 years I never had a shimmy. Last time I was at Clemson I watched a Skybolt land on the paved runway. He should have landed in the grass. The aircraft had a Scott 3200 on it. The shimmy was so violent it was awesome. But then he probably just had a rigging problem. |
WoW! That's not a Taylorcraft, that's SPACESHIP 2
![]() That sounds like it could be a fun ride!! Scott BTW, a friend just got back from ferrying a VG'd two-ten to Wasilla, AK. He said on the destination airport was an old Taylorcraft with a two-hundred horsepower Lycoming on the nose. jls wrote: |
to 20 deg. forward, Here goes the old debate again. Are we talking the top of the pivot axis tipped forward? Every tailwheel shimmy I had was partly due to that, and replacing the tailspring or whatever to get the axis vertical or tipped back a little stopped the shimmy. It's the same effect as a bent caster on a shopping cart: bent back, it will shimmy. Now I know that there are some aircraft manufacturers that specify the axis tipped forward, and I don't know why. The Scott we bought recently was to replace a shimmying Scott. We had replaced everything else related to the tailwheel, had the axis fixed and everything, and it still would not stop. It turns out that the bronze bushing in the fork wears out, and Scott doesn't sell that part separately; have to buy the whole fork, which costs a big bundle. To avoid any further fooling around, we replaced the entire assembly and the shimmy went away immediately. Dan |
![]() wrote in message ups.com... Excellent site, Ron. Just what you need --- the vertical shaft tilted 15 to 20 deg. forward, Here goes the old debate again. Are we talking the top of the pivot axis tipped forward? Every tailwheel shimmy I had was partly due to that, and replacing the tailspring or whatever to get the axis vertical or tipped back a little stopped the shimmy. It's the same effect as a bent caster on a shopping cart: bent back, it will shimmy. Now I know that there are some aircraft manufacturers that specify the axis tipped forward, and I don't know why. The Scott we bought recently was to replace a shimmying Scott. We had replaced everything else related to the tailwheel, had the axis fixed and everything, and it still would not stop. It turns out that the bronze bushing in the fork wears out, and Scott doesn't sell that part separately; have to buy the whole fork, which costs a big bundle. To avoid any further fooling around, we replaced the entire assembly and the shimmy went away immediately. Dan Well, I don't tip it quite as much and see them work fine when not tipped. The more tipped the greater stress on the bushing, of course. Then when it wallows out you get shimmy invariably. Paying big bucks for that fork assembly is a little painful, isn't it? How much was it and where did you buy it? I know somebody who needs one very badly. He shoulda had a Maule. |
![]() One of the Fly Baby crowd put together a paper on the care and feeding of Maule tailwheels: http://www.bowersflybaby.com/tech/Maule_Tailwheel.pdf He recommends dissimilar springs to discourage shimmy, and says that binding or looseness in the assembly itself encourages it. Myself, I haven't had a problem. Ron Wanttaja I have the 6" Maul on my Jungster II. To cure the uneven tire wear I replaced the Maul wheel with one of the ones ASS sells for the homebuilt tailwheel unit. It has a metal hub and has less tendency to run over. You can frequently get the same wheel at a industrial wheel supplier. Check your axle size as they come in two different bores. Ed Sullivan |
On Wed, 24 Aug 2005 08:49:57 -0400, " jls"
wrote: "IAN DONALDSON" wrote in message ... G'day Well I have never seen a Maule wheel before. That is something to consider. How do you consider that the Maule would be better than the Scott, apart from the cost? Regards Ian I should have kept the Maule a secret because now everybody will want one and Maule will go up on them like they have on the Scott. Anyway, I have a Maule pneumatic swiveller on a Super Cub and it is very robust and easy to repair and to grease. Plus parts for it are cheap and readily available. I put a new non-pneumatic swivelling Maule tailwheel on my Taylorcraft ten years ago, and hung up the old Maule non-swiveller, and it has performed flawlessly. People who have trouble with Maules,other than from just ordinary wear and tear, usually let them go without grease. And then the tire will wear unevenly and not caster correctly if your tail-springs aren't shimmed for book geometry. You can see the exploded view of parts of this tailwheel at the ACS link attached to my earlier reply. It is very easy to maintain and repair, tapered roller bearings and all. OTOH, I do like a Scott and see its many virtues, but for the money I'll go Maule any old day. $1500 for a new 3200 is for suckers. Sure is - I got mine 3 years ago on E-Bay - never installed but several years old, for $275. Last night I talked to a friend who paid $75 for a used Scott 3200 a decade or so ago and (being adept with the lathe and milling machine) rebuilt it for use on a Marquart Charger. I told him he stole it. He said that although it had been a good tailwheel it didn't impress him all that much. I'll have to see what tailwheel he's using on his latest taildragger homebuilt. I'll bet you a dollar it ain't a Scott. |
G'day
Thanks for your considered response. I have never seen the Maule tail wheel, but I will have to get out to the local airfield and see what the taildragger people are using. I should have kept the Maule a secret because now everybody will want one and Maule will go up on them like they have on the Scott. OTOH, I do like a Scott and see its many virtues, but for the money I'll go Maule any old day. $1500 for a new 3200 is for suckers. I agree that the cost of a new Scott is extreme! Last night I talked to a friend who paid $75 for a used Scott 3200 a decade or so ago and (being adept with the lathe and milling machine) rebuilt it I would also like a "project wheel if one turned up! regards In Donaldson |
Scott 3200 tail wheel | IAN DONALDSON | Home Built | 1 | August 8th 05 01:58 AM |
Tailwheel units on ebay | Victor Bravo | Home Built | 1 | July 24th 05 09:47 AM |
Wally Scott inducted into TX Hall of Fame | [email protected] | Soaring | 0 | June 25th 05 04:27 AM |
SCOTT RITTER SAYS U.S. PLANS JUNE ATTACK ON IRAN | [email protected] | Naval Aviation | 1 | February 22nd 05 05:06 PM |
Advice on flying Pitts with Haigh Locking Tailwheel | Ditch | Home Built | 19 | January 4th 04 10:18 PM |
