Electronic horizon?
Old August 26th 05, 07:29 PM
Stefan
bumper wrote:
While I respect your opinion, I'd
like to know what data you're basing it on.
It is generally considered a bad idea to have two instruments which look
the same but have a different meaning. It will work fine as long as
there is no stress present, but the moment there is additional stress,
chances are that the human system breaks down. For illustration, read
the accident report at http://www.bfu.admin.ch/common/pdf/1781_e,
especially paragraph 1.18.2. (Agreed, things were much more complex and
there were many more factors involved, but I think the report is very
enlightning anyway.)
damn near
anything is better than nothing for inadvertent or emergency IMC.
I think nobody will disagree on this.
Stefan
Old August 27th 05, 05:39 AM
bumper
Stefan,
Again, no argument with regard to the conclusions drawn in the accident
report you cite. BTW, that is one incredibly long and detailed accident
report! I think in the US, only a Kennedy could garner that much attention.
Anyway, with regard to the Trutrak versus western style horizons, the
depiction is the same, i.e. the aircraft silhouette remains stationary with
the host aircraft while the "outside" sky/earth turns within the instrument
to depict bank angle. Thus, someone who has trained on western instruments
should have no problem adapting to the Trutrak. Much easier and more
intuitive than a needle and ball - - at least for me as I trained w/ a turn
coordinator. All you gotta remember is there's no pitch info. In a glider,
that isn't too tough as if you go too fast, the wings get swept back.
bumper
"Stefan" wrote in message
bumper wrote:
While I respect your opinion, I'd like to know what data you're basing it
on.
the same but have a different meaning. It will work fine as long as there
is no stress present, but the moment there is additional stress, chances
are that the human system breaks down. For illustration, read the accident
report at http://www.bfu.admin.ch/common/pdf/1781_e, especially paragraph
1.18.2.
Old September 3rd 05, 04:58 AM
Ramy Yanetz
In absence of more suitable instrument and/or rating, couldn't a GPS or PDA
with moving map be used to descend through clouds in emergency by zooming in
and noting if and what direction the glider is turning?
Ramy
"Bill Daniels" wrote in message
There are several PDA based 'glass cockpit' software packages that appear
to
work well. They derive bank attitude from TAS (or GS if TAS is not
available) and the rate of change of ground track. Pitch data is derived
from the rate of change of airspeed. 'Heading' is actually ground track
but
that is good enough.
Since many glider pilots already have a PDA in the cockpit, these might be
good enough for an emergency. Simply have the 'glass cockpit' running in
the background and switch to it if the need arises. The beauty is that no
additional hardware is needed beyond what is already in the glider.
FWIW, I tried a simulated 'blind let down' using only the wet compass in
back seat of a G103. With the glider on a southerly heading, I used the
southerly leading error to keep the wings level and hold the heading. I
was
able to do this for about 10 minutes under the 'hood' without outside
reference.
For those readers not aware of this trick, a magnetic compass senses not
only the N-S magnet field but also the 'dip' angle. While on a southerly
heading in mid northern latitudes, the magnetic compass will indicate a
turn
as soon as a wing is down and before a turn actually starts. Banking the
glider left and right as needed to keep the compass on S will keep the
wings
level. This is very tricky in a fast airplane but surprisingly easy in a
slow glider as long as the air isn't very turbulent. (For out friends in
the Southern Hemisphere this trick requires a north heading.)
Bill Daniels
"Martin Gregorie" wrote in message
news
On Thu, 25 Aug 2005 20:53:43 -0700, rhpf wrote:
Martin,
I have flown with this instrument, it works well. It will tumble after
several minutes of extreme bank angles. Even higher priced instrument
in
the $3000 to $5000 range have a cage function for acrobatic maneuvers
or
This instrument group is one that I'd almost never use during normal XC:
the reason I'm looking is that when/if I do some wave flying I'd like to
have these displays onboard in case of canopy icing and/or finding
the slot slammed shut below me. Would you trust it for that? I'm asking
because I've heard stories that continuous circling would tumble it.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 3rd 05, 08:26 AM
bumper
"Ramy Yanetz" wrote in message
m...
PDA with moving map be used to descend through clouds in emergency by
zooming in and noting if and what direction the glider is turning?
Ramy
Ramy,
Many GPS have a "HSI" page or at least a track derived "compass". These
would probably be easier use that watching the bread-crumb track on a
zoomed-in map. Besides, the track update rate may be much lower than the GPS
update rate in order to conserve internal track memory, though this is
usually user selectable.
Best of all, IMO, is the "panel page" on the Garmin 196 / 296 / 396.
bumper
Old September 4th 05, 07:55 AM
Tom
I, once, had to do a real descent thru the clouds after being trapped
on top while wave flying. At the time I had no instrument training and
had to come up with a plan of action on very short notice. I selected a
westerly heading since there would be no turning error on the compass.
I lowered the gear and pulled the dive brakes and flew at a high speed
to maximize descent rate. I reasoned that if the compass isn't changing
you aren't turning. I ended up descending 7000 ft thru the clouds with
the wings perfectly level on exit.
The only thing I would do differently would be to fly at a slower
speed.
I have tried the benign spiral trick with no luck (for those unfamiliar
with this you lower the landing gear, set landing flap position if you
are flapped, and take your hands off the controls).
Also, I read the accident report sited by Stephan and found no possible
connection to the T&B mentioned earlier. The report mentions the
differences between Russian and Western AI, not the pilot confusing a
T&B for an AI. I see no possibility for confusion for a glider pilot
who has this as his only inertial instrument.
Tom
Old September 4th 05, 03:05 PM
Martin Gregorie
with this you lower the landing gear, set landing flap position if you are
Don't try it with an ASW-20. It has no benign spiral with the flaps in
neutral: I checked with gear down, brakes and no brakes.
However, its probably OK on a fixed heading: clean, with zero flap, hands
off but feet used to keep straight, its stable with a 25 second +/- 5 kt
phugoid.
org |
Old September 4th 05, 07:33 PM
Stefan
Tom wrote:
I selected a
The idea of setting the course 180 *is* exactly the turning error! Every
tendency to bank will immediately be displayed by the compass, even
before the plane begins to actually turn. It actually works very much
like the "turn coordinator". (BTW, this works as well on course 0, of
course. But because the compass will react in the wrong direction, a
correct reaction would require a very high level of abstraction.)
The conection is that you have an instrument in front of you which
reacts differently than you expect. When you're trained with and used to
an artificial horizon, then that trutrak thing looks ecactly like one.
So I expect it to display pitch information which it doesn't. And when
you've learnt to rely on a horizon as your primary reference for
attitude, then the issue is no more minor, but may become that last
straw which breaks the camel's back.
I stay with my statement: Something which looks exactly like a well
known and widespread instrument but works differently is a possible
source of confusion and a very bad idea, especially when it comes to
such an unforgiving thing as flying in clouds.
Stefan
Old September 4th 05, 07:54 PM
Tom
Stefan wrote:
Tom wrote:
I selected a
OK, have you actually done this in a REAL emergency? I have, and it
worked. And that was without ANY prior training. Having - guaranteed -
no turning error was critical. I wasn't about to guess at which
direction gave the turning error in the same direction.
My rational is real simple: if the compass isn't moving you aren't
turning; if it is moving you turn - gradually - in the opposite
direction. The goal isn't to follow a particular heading, it is to stay
level and in control.
Again, I think you are overlly concerned about a non-issue. I believe
that any pilot who has had instrument training will have no problem
with the Truetrak, and those that have not can't possibly be confused
about something about which they know nothing. Actually, I think the
later will be able to use the Truetrak more effectively because it IS
more intuitive.
Tom
BTW: Your accident pilot was on unauthorized drugs (Russian
tranquillizer), which was the most likely cause of the accident.
Old September 4th 05, 08:16 PM
Stefan
No, and I'm not planning to do so. Our club gliders are all equipped
with needle/ball, and I would be very reluctant to fly over a föhn gap
without.
I have, and it worked.
I've understood this and am glad you succeeded. Just gave you the reason
why course 180 is "recommended". BTW: I don't believe that such a decent
would be successfull in gusty air, at least not reliably so.
I really hope you are correct and I am wrong. I'm not convinced, though.
Knowing the involved company first hand, I'm pretty sure it was a lack
of conversion training.
Stefan
Old September 5th 05, 01:21 AM
bumper
I stay with my statement: Something which looks exactly like a well known
and widespread instrument but works differently is a possible source of
confusion and a very bad idea, especially when it comes to such an
Stefan
Well let's see, yup my Trutrack in my glider does sort of look a bit like
the horizon in my Mooney, it has the blue sky over brown earth anyway. Then
there's that little airplane thingy - - that's similar. Ah, but there's no
vertical scale to show pitch. Hmmm, what's that little sign above the
airplane right on the face of the instrument? "N-O P-I-T-C-H" is what it
says. Damn, that's confusing!
face of the instrument he
http://www.trutrakflightsystems.com/...struments.html
I'm not connected with Trutrack in any way.
bumper
(who's very happy with the Trutrack and not likely to get confused enough to
remove it and throw it away :c)
Craggy Aero Electronic Flight Recorder Calibration Services RHP Soaring 0 August 29th 04 06:42 PM
Stars and Stripes Offers Free Electronic Newspaper, By Sgt. 1st Class Doug Sample, USA Otis Willie Naval Aviation 0 April 30th 04 10:45 PM
Stars and Stripes Offers Free Electronic Newspaper, By Sgt. 1st Class Doug Sample, USA Otis Willie Military Aviation 0 April 30th 04 10:45 PM
Future Electronic Attack Aircraft Mike P. Military Aviation 1 April 22nd 04 02:30 AM
Electronic Ignition Andre Home Built 1 September 5th 03 07:15 PM
