Garmin 396 'installation' in the Maule
Old August 26th 05, 09:04 PM
Maule Driver
George, it's always a pleasure getting some Maule-specific advice.
Thanks, several times.
That's the question, will it work thru the fabric?
George Patterson wrote:
Try tucking it up between the headliner and the fabric top of the
fuselage. I had my MBR antenna under the floor boards and it worked well
through the fabric. IIRC, M. Powell has a gps antenna mounted over the
headliner in this way. If it works, you can clamp a mounting plate to
the frame tubes up there.
Old August 27th 05, 12:36 AM
Maule Driver
It seems to work just fine up there thru fabric and insulation -
perfect! I can get as far away from the compass as the cable allows.
Looks like the magnet naturally finds a crotch a in the tubing to
magnetize itself too.
well through the fabric. IIRC, M. Powell has a gps antenna mounted
over the headliner in this way. If it works, you can clamp a mounting
plate to the frame tubes up there.
Old August 27th 05, 04:19 AM
George Patterson
Great! Just keep it away from the aileron cables.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old August 30th 05, 11:41 AM
Maule Driver
Well, it definitely can sit up there in the tubing crotch, well clear of
cables, etc. But it definitely won't be removeable.
I'm now looking at just laying it on the floor in the baggage area and
stringing the cable along the floor. The extension plug will end up
right under my seat. The question I haven't answered yet is whether it
will receive well from there but I think it might given the extensive
composite construction on the Maule (composite = tubing, sheet metal,
fabric, and glass :-) )
George Patterson
Old August 27th 05, 01:00 AM
john smith
Depends upon how much aluminum powder is in the primer.
Old August 26th 05, 07:17 PM
Dave Butler
Maule Driver wrote:
Well, it came yesterday. Great box. Looks like the challenge will be
'mounting' the GXM 30 XM antenna in the Maule.
The thing has a big non-removeable magnet so distance from the compass
is needed. It has an extension cord and mounting screws but needs good
sky exposure... any thoughts are welcome.
Garmin should know better. What were they thinking?
Otherwise, the yoke mount looks fine and the unit itself has me
drooling. NC to FL next week!
Mine came Wednesday, been foolin' around with it in the car. I think I'm going
to like it a lot, but that antenna thing is a definite drawback: the fact that
you have 2 separate antennas with two wires to manage, and the magnet.
Let us know if you come up with an elegant solution.
Dave
Old August 26th 05, 07:47 PM
xyzzy
good sky exposure... any thoughts are welcome.
going to like it a lot, but that antenna thing is a definite drawback:
the fact that you have 2 separate antennas with two wires to manage, and
the magnet.
Dave
They must have just sent out a big shipment, mine came yesterday
(promised ship date of 8/31). I came home to find it then had to leave
immediately for a flight lesson. Since it was a "preparation for
checkride" instrument lesson, playing with the new toy on the flight was
out of the question. Bummer.
I'll be taking it up on Saturday though.
I wonder why the GXM-30 has to have view of the sky? The WxWorx antenna
that comes with the ControlVision solution works fine in the side pocket
of a Cherokee. I may try my GXM-30 there just to see what happens.
And at any rate are we losing a little bit of perspective, complaining
that our W-compass's already marginal accuracy is negatively affected by
our much-more-accurate GPS?
"You can support the troops but not the president"
--Representative Tom Delay (R-TX), during the Kosovo war.
Old August 26th 05, 08:09 PM
Jonathan Goodish
In article , xyzzy
I'm sorry, but I just don't believe that the XM antenna works while
stowed in the side pocket. I have a difficult time getting a good
signal for weather even when it's on the glare shield, unless it's in
just the right spot.
Are you sure that you aren't getting the antenna and receiver confused?
With the Control Vision solution, they are separate, but the receiver
and antenna are integrated into one unit with the 396.
JKG
Old August 26th 05, 09:16 PM
xyzzy
Jonathan Goodish wrote:
In article , xyzzy
You may be right on my having the receiver and antenna confused,I'll
have to double check. I read it in an Aviation Consumer article, plus a
pilot I know who has one told me that, but they may have been referring
to the receiver now that I think about it.
Old August 29th 05, 07:40 PM
xyzzy
antenna that comes with the ControlVision solution works fine in the
side pocket of a Cherokee. I may try my GXM-30 there just to see
what happens.
confused? With the Control Vision solution, they are separate, but
the receiver and antenna are integrated into one unit with the 396.
Btw you were right, I checked with teh guy who had it and he said that
the receiver went in the side pocket and the antenna was a much smaller
piece that he had to put on the glareshield.
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 01:16 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 02:04 AM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
