"HL Falbaum" wrote in message ... At our site (867ft MSL) in hot, humid Georgia we use about 1.5 gal for the average 3000 ft tow. Our 265 hp Pawnee is STC'd for auto gas, which we have used for about the past 5 years or so without difficulty. I just bought some Avgas for a Mooney at 3.85/gal. So worst case 4.00/gal, 2 gal for 4000 ft = $8.00 As always, fuel is the least expensive part of operating an airplane (within certain limits of use), and the fixed costs are the most expensive. -- Hartley Falbaum Mid Georgia Soaring Assn, USA I'd bet that while 1.5 Gal is what the tow itself consumes, the average including warm up taxi and descent will be closer to twice that. We frequently tow for 20 minutes or so to 10 - 12K feet to reach lift over the Rockies so fuel costs are going to hit us harder. Mogas is a good solution if your engine/tug combination has a STC and if you can find it without ethanol. That's getting harder all the time. But, you are basically right that the fuel quantity consumed per tow is not all that large. However, the price of crude will impact every item in the cost of operating an airplane. Over a period of decades, an aero tow has cost about the same as a barrel of oil. That would suggest $70US is likely for now with the dreaded $100 tow right round the corner. Winches are part of the answer. Any winch can do what a tug does for a lot of training flights like pattern tows for landing practice. A better winch can get a glider high enough to find thermal lift while consuming only about a quart of fuel. However, a winch cannot get a glider high into the mountains where the good lift is - you would have to soar your way there. BTW, Denise Layton, Editor of Soaring Magazine, needs some good winch photos to use with a winch article I wrote. If you have any that could be used for publication, send them to her. Bill Daniels |
Actually, our numbers are "block to block" averaged over time. We usually
leave the mixture full rich, and have a Tost internal tow rope winch. Land opposite take off direction, turn around, hook up and go! Might be more for the instance of pulling a tow or two then waiting (or shutting down) while someone else gets ready. We are often able to get off tow at 2000, and some of us get off at 1500. -- Hartley Falbaum "Bill Daniels" wrote in message ... "HL Falbaum" wrote in message ... At our site (867ft MSL) in hot, humid Georgia we use about 1.5 gal for the average 3000 ft tow. Our 265 hp Pawnee is STC'd for auto gas, which we have used for about the past 5 years or so without difficulty. I just bought some Avgas for a Mooney at 3.85/gal. So worst case 4.00/gal, 2 gal for 4000 ft = $8.00 As always, fuel is the least expensive part of operating an airplane (within certain limits of use), and the fixed costs are the most expensive. -- Hartley Falbaum Mid Georgia Soaring Assn, USA I'd bet that while 1.5 Gal is what the tow itself consumes, the average including warm up taxi and descent will be closer to twice that. We frequently tow for 20 minutes or so to 10 - 12K feet to reach lift over the Rockies so fuel costs are going to hit us harder. Mogas is a good solution if your engine/tug combination has a STC and if you can find it without ethanol. That's getting harder all the time. But, you are basically right that the fuel quantity consumed per tow is not all that large. However, the price of crude will impact every item in the cost of operating an airplane. Over a period of decades, an aero tow has cost about the same as a barrel of oil. That would suggest $70US is likely for now with the dreaded $100 tow right round the corner. Winches are part of the answer. Any winch can do what a tug does for a lot of training flights like pattern tows for landing practice. A better winch can get a glider high enough to find thermal lift while consuming only about a quart of fuel. However, a winch cannot get a glider high into the mountains where the good lift is - you would have to soar your way there. BTW, Denise Layton, Editor of Soaring Magazine, needs some good winch photos to use with a winch article I wrote. If you have any that could be used for publication, send them to her. Bill Daniels |
4000' tow? We strongly discourage tows above 2000' during the busy part of
the day. Our 2000' tows haven't yet broken the $20 mark, but I suspect they will when we get our next 3000 gallons..... "Oscar S Alonso" wrote in message news:2005083108281116807%oalonso@NOSPAMmaccom... At my local FBO (Mt. Valley Airport ,California) it cost $68 for a 4,000 ft. to the top of the mountain. With the price of AV Gas going up I wonder when/who will be the first FBO with a $100 4,000 ft. tow? Any comments? Oscar. |
For Example John Smith wrote:
4000' tow? We strongly discourage tows above 2000' during the busy part of the day. Our 2000' tows haven't yet broken the $20 mark, but I suspect they will when we get our next 3000 gallons..... In most of the western US, the airports are in the valleys and the good early lift is in the mountains. When the valley is 8000 feet MSL and the low hills are 11,000 feet MSL, a 4000 foot tow is fairly common. Shawn |
Thank goodness I fly at a place where a 1,500 foot tow is usually more
than enough. |
ditto, or a winch launch;^)
At 21:42 31 August 2005, Hl Falbaum wrote:
Actually, our numbers are 'block to block' averaged over time. We usually leave the mixture full rich, and have a Tost internal tow rope winch. Land opposite take off direction, turn around, hook up and go! Guenther Jacobs at Parowan has refined his technique one step past this...the glider is staged on the active with the second rope hooked to it, pilot strapped in and ready. The towplane lands facing the glider, taxis up and drops it rope on the side of the runway, spins around and is hooked up. Tightens the rope and goes. Hard to waste time on the ground this way. |
Stewart Kissel wrote:
At 21:42 31 August 2005, Hl Falbaum wrote: Guenther Jacobs at Parowan has refined his technique one step past this...the glider is staged on the active with the second rope hooked to it, pilot strapped in and ready. The towplane lands facing the glider, taxis up and drops it rope on the side of the runway, spins around and is hooked up. Tightens the rope and goes. Hard to waste time on the ground this way. He used that technique quite a bit during the contest it seems. But when a group of us flew there a week later, we were a bit more lazy about it. Then again, most of us were taking higher tows anyway. Damned smoke and inversion! Jeremy |
If you have a Pawnee or a Tug with enough grunt why not dual tow?
Guys at my club here in NZ do it on a regular basis on days when a long tow is needed to get away. Split the cost. Paul "Stewart Kissel" wrote in message ... At 21:42 31 August 2005, Hl Falbaum wrote: Actually, our numbers are 'block to block' averaged over time. We usually leave the mixture full rich, and have a Tost internal tow rope winch. Land opposite take off direction, turn around, hook up and go! Guenther Jacobs at Parowan has refined his technique one step past this...the glider is staged on the active with the second rope hooked to it, pilot strapped in and ready. The towplane lands facing the glider, taxis up and drops it rope on the side of the runway, spins around and is hooked up. Tightens the rope and goes. Hard to waste time on the ground this way. |
| Thread Tools | |
| Display Modes | |
| $100 Hamburger question | AJ | Piloting | 3 | October 3rd 05 01:46 AM |
| GOP Kills $100 million relief to GA companies hurt by 9/11 airspace restrictions | Larry Dighera | Piloting | 21 | January 31st 04 03:21 AM |
| FS BF-109G ERICH HARTMANN DESKTOP MODEL $100 SHIPPED | [email protected] | Military Aviation | 0 | August 5th 03 08:20 AM |
| FS B-52D SAC MARKINGS SE ASIA COLORS $100 | Eroplano | Aviation Marketplace | 0 | August 1st 03 11:32 AM |
| FS T-6 TEXAN DESKTOP MODEL $100 | Eroplano | Aviation Marketplace | 0 | August 1st 03 11:26 AM |
