Starting new C172s
Old September 7th 05, 04:33 AM
OP
On Tue, 06 Sep 2005 09:14:49 +0200, Greg Farris
says...
I rent from a Cessna dealer FBO at VNY. The procedure there is:
Throttle - open 1/4 inch
Mixture - Idle Cutoff
Propeller area - Clear
Master Switch - ON
Beacon - ON
Aux Fuel Pump - ON
Mixture - Advance full - 2 to 3 seconds, then return to Idle Cutoff
Aux Fuel Pump - OFF
Ignition - START
Mixture - Advance full, when engine fires
Works every time for me.
BTW... same procedure when the engine is hot - EXCEPT - Mixture -
advance full - 1 second, then return to Idle Cutoff.
Pretty close to the standard method - but why use a "timed" method to
determine fuel flow from the pump, when there is an instrument in front
of you that gives precise information? If you didn't have a fuel flow
guage, or suspected that it wasn't working, this would be a good backup
method - but on the ones I've flown this guage is always working, and
gives a reliable indication for the starting procedure.
G Faris
The reason given by the FBO was that the fuel flow meter in "some"
of the injected 172's is either slow to respond or doesn't read
accurately at the aux fuel pump flow rate. And it is easier to
flood the engine using the fuel flow meter. Don't know how true
that is, but the timed method (using a simple one thousand, two
thousand count) is accurate enough.
I guess if you are flying your own plane or the same one every time,
using the fuel flow meter would be more convenient once you knew
what the fuel flow meter should read to properly start your engine.
The only place I see a problem would be starting a hot engine.
Apparently you don't want as much fuel in there under that
condition. Maybe that would be a lower fuel flow rate.
Ron Kelley
Old September 7th 05, 12:13 PM
Mortimer Schnerd, RN
On a cold fuel injected engine, I've always pushed the mixture and throttle full
forward, hit the boost pump long enough to get needle movement on the fuel flow
or fuel pressure gauge, then retarded the throttle to 1/4" and the mixture to
idle cut off. Crank the engine and when it catchs, push the mixture to full
rich. Always seemed to work.
VE
Old September 7th 05, 01:13 PM
john smith
Tha argument for using the fuel flow meter instead of a timed method is
that you don't know if the pump is primed or not, so the time it takes for
X amount of fuel to be pumped, after you flip the switch, is variable.
The Piper Turbo Arrow IV manual contains a time chart based on OAT for
priming.
Old September 7th 05, 01:14 PM
john smith
full
flow
idle cut off.
Why push the throttle up?
Throttle controls air, mixture controls fuel.
Old September 7th 05, 02:03 PM
Brien K. Meehan
Well, you need both for combustion.
.... but the fact is that on this airplane (and most fuel injected
engines, I believe) the fuel won't flow into the engine unless the
throttle is open.
You can easily test this by turning on the aux fuel pump and advancing
the mixture to rich while keeping the throttle fully closed. You'll
sit there all day without seeing the fuel flow meter move.
Old September 7th 05, 03:07 PM
Newps
I do the same thing with my Bonanza except the mixture stays full rich.
Starts every time, hot or cold. Why pull the mixture out?
Old September 7th 05, 03:08 PM
Newps
full
flow
idle cut off.
Because if you don't the fuel won't get in there.
Starting Prop Engines in FS2002 [email protected] Simulators 3 August 30th 04 02:54 PM
Starting Engine Question (O-320, Warrior) Lisa Piloting 13 April 1st 04 06:45 AM
New A&P: Typical Starting Salary Range ? Robert11 General Aviation 1 February 6th 04 09:02 PM
Hot Starting Fuel Injected Engines Peter Duniho Piloting 23 October 18th 03 02:50 AM
Boeing 307 Starting Up! Jay Honeck Piloting 5 August 8th 03 06:53 PM
