These are not YOUR airplanes - Was: High Cost of Sportplanes
Old September 19th 05, 04:37 AM
Gordon Arnaut
Evan,
I don't want to drag this out, I think some good points ahve been made --
however, I don't see why fiberglass airframe construction is going to be
less labor-intensive.
There is almost zero opportunity for automation in fiberglass construction,
unless you go to specialized processes and tooling that are probably out of
reach for a small firm. Even Cirrus and Adam do a lot of their layups by
hand -- granted using pre-pregs.
Now look at a simple little plane like the Zenith 601. They used to build
one of these in a week at Oshkosh, using volunteers from the crowd. It uses
pull-type rivets rather than bucked, so the structure can be assembled quite
quickly. I think the total time to get to the flying plane was about 300 man
hours.
And I don't think the Zenith kit parts are as automated as they could be --
for instance I don't the they are fully precut and pre-punched etc. like the
Van's kits.
My point is that if you purpose-designed a small aluminum airplane for quick
construction and automated the sheet-metal stamping part of the process, you
could make that airplane very cost-effectively.
Perhaps a fiberglass approach could work just as well, but I think more
ingenuity would be required.
Regards,
Gordon.
"Evan Carew" wrote in message
Gordon,
Unfortunately, I have to disagree with you on your analysis of aluminum
use in commercially built LSA aircraft structures. While it is true that
the aluminum materials costs for an aircraft are lower, the labor costs
(which I have already shown to be the largest cost in building any plane)
are much higher, thus making it a poor choice if you are trying to build
such airplanes for a profit. On the other hand, if you are trying to sell
kit LSA airframes, then the builder assumes the labor costs, thus making a
comparable kit seem less expensive.
Old September 19th 05, 08:47 AM
Roger
On Sun, 18 Sep 2005 23:37:30 -0400, "Gordon Arnaut"
Evan,
Once you have the moulds constructed, fiberglass lends itself well to
making large compound structures as one piece.
That depends on your thinking. Fiberglass composite also lends
itself well to putting pieces together.
hours.
Van's kits.
It would and it would.
However, in the case of the sport plane specifications, the plane
could be constructed of shells that could be fastened together.
They could be composite shells, with the joggle and two aluminum
strips where they would be pop riveted together with cherry max
rivets.
After all they do not under go any where near the stress of a Cirrus,
Lancair, or Glasair III. Staying within those specs makes both the
metal and composite structures much more simple. OTOH you still have
all the insurance costs.
If and I emphasize the IF the market were there to justify true mass
production then airframes, engines and basic avionics could be
produced at considerably less. If you could sell even 20,000 small
displacement engines like the Jabaru they'd become *relatively* less
expensive compared to now.
Let's face it, even at Cessna's best year, that was a specialized
market and peanuts compared to the automobile.
However, first you have to have the market. You aren't going to do a
lot of high profile advertising for a nitch market that may develop.
Once the potential market is there the advertising can increase, and
production will follow.
It's much like the chicken or the egg. The market has to develop
slowly. The faster it develops the more sensitive it is to upsets.
However, I seriously doubt that we will ever see more than about three
times the number of planes currently flying. Beyond that we'd need a
complete now traffic system even if most of it is local.
www.rogerhalstead.com
Regards,
Gordon.
Gordon,
Old September 19th 05, 09:12 AM
On Mon, 19 Sep 2005 03:47:38 -0400, Roger
Evan,
I dunno, Roger. I've been both to the Glastar factory and the Vans factory. At
Vans, a guy feeds a big piece of aluminum into a big CNC machine and
whango-whango-whango out comes a big pile of RV parts. But then I go see the
Glastar's fiberglass fuselage made, and its spray the release agent onto the
mold, then the gelcoat, then cut pieces of fiberglass and lay them into the
mold, then squeegee on some resin, then apply the foam, then apply another layer
of fiberglass and more resin, etc. etc., lather, rinse, repeat, then let the
assembly tie up your every expensive mold while the resin cures.
Looked to me that manufacturing aircraft parts in fiberglass is a *lot* more
effort...though I allow that less-skilled workers can probably be used.
P.S. Wanna hear something *really* scary? My spell checker passed
"whango-whango-whango" but hiccuped on "gelcoat."
Old September 19th 05, 03:37 PM
Gordon Arnaut
Ron,
That's a good comparison. A Glasair or Lancair kit costs about double what a
Van's kit costs and it still takes about the same build time to complete. In
fact even the Van's quick-build costs less than a Glasair slow-build and you
get probably less than half the build time.
And what if the Van's kit were designed to be built with pulled rivets? This
would cut build time dramatically and that slow-build kit could be built in
about the same time it takes to build one of the composite fast-build kits
that cost three times as much.
Look at the Zenith 601, and compare its price to some of the sportplane
composite kits. The composte kits are usually twice as much money.
The conclusion has to be that composites are more expensive because it costs
more to make them. No question about it, composite construction involves
lots of hands-on labor.
Also composite materials are expensive compared to aluminum. So if there is
no advantage in labor costs and material costs are higher, how does
composite make sense for a cheap airplane? It doesn't.
Regards,
Gordon.
"Ron Wanttaja" wrote in message
Evan,
construction,
factory. At
layer
more
Old September 19th 05, 06:38 PM
Michael
Based on my back of the envelope analysis of the theoretical base price
of a 2 place aircraft, I think wishing for a plane costing less than 50K
is nothing more than a pipe dream.
I don't buy it. When I
was in the Keys, I saw a two-seat UL trainer on floats. It was open
cockpit (very open), and had a Rotax engine and Dacron-sailcloth
covered wing, but it was $25K new. Presumably the manufacturer
was making a profit.
I think all your prices are WAY too high. $15K for an engine? A Rotax
retails for half that. That's RETAIL - if you're a manufacturer you
should be able to get a better deal.
$20K for airframe components? You can buy a quickbuild kit for a
pretty advanced (high-speed all-metal RV) for less. Retail. Prebuilt
and predesigned for home assembly.
$4K for instruments? For an IFR panel with certified components,
maybe. For day-VFR, you need a non-sensitive altimeter, an airpeed
indicator, a compass, and some engine gauges. The retail price on all
this (assuming non-certified stuff) is maybe $1K.
I think everyone pretty much expected that when the LSA rules came out,
the UL trainers (2 seat) would be sold as LSA's for about the same
money they cost as UL trainers - about $20K-$30K ready to fly. This
isn't happening. There really are only two possible reasons. Either
the LSA 'certification' process isn't really all that simple or cheap
(meaning that, as with the recreational pilot and VLA, the FAA has
botched the job again) or the manufacturers figure they can skim the
cream at a higher price.
Michael
Old September 19th 05, 07:43 PM
Evan Carew
Ron,
& yet, when that part comes out of the mold, it is essentially flyable.
With the aluminum CNC paradyme, you get predrilled holes in aluminum you
then have to bend, & thousands of rivet holes you have to debur. hours,
hours, & hours of deburring...
Old September 19th 05, 07:48 PM
Evan Carew
Gordon,
All I'm saying is that there's more opportunity to do low labor per
square foot of fuse with fiberglass than with aluminum, ans since we are
talking about commercially built structures, that's all that matters
when you are trying to get a basic airplane out the door for less than
80, or even 60K.
As for using pull type rivets... do you really think any commercial
entity is going to roll out insured airplanes with the equivalent of pop
rivets?
Old September 19th 05, 07:56 PM
Evan Carew
Michael,
I've interspersed my data (gleaned from today's online prices)
throughout your message. Add them up yourself.
We were talking about an enclosed aircraft with a fiberglass or aluminum
body, 4 stroke engine, and 2 seats with a cruse of ~100 knots.
sigh I just went to a common retail website & found that a rotax 912
(the most commonly used for aircraft of the type we are talking about)
lists for between 16 & 22K. The difference being the options & accessories.
On the RV site, they do in fact sell the early model RV for 11.7K,
however, the finished cost is listed at 45K. That would be 10K more than
my fiberglass KIS.
Er, I just bought mine & even my radio cost ~1k. If you would be kind
enough to tell me where you purchase your instruments, I'll start
purchasing mine from your supplier right away!
Michael
Old September 20th 05, 01:02 AM
Jim Carriere
Your spell checker has the Ted Nugent module?
Old September 20th 05, 01:04 AM
Jim Carriere
rivets?
The windshields on the Bell Jetranger helicopter are held on by
pulled rivets. I didn't know that until I saw one being replaced.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
Could it happen he The High Cost of Operating in Europe Larry Dighera Piloting 5 July 14th 03 02:34 AM
