oups.com... What are your thoughts on instrument training at night? Personally I don't fly at night and have only for what was required for my PPSEL. However my goal is to go on to my Commerical and CFI after the Instrument. So, I guess my question comes down to added risk. How much additional risk am I taking by doing some of my Instrument at night? The main thing with flying at night in a single-engine aircraft is that life is less encouraging when it comes to engine failures. This said, though, I can't see that it's really more risky flying on a nice, clear night than, say, flying single-engine in daytime IMC with a low cloud base. The main thing to be sure of is that your instructor is experienced and extremely competent with night flying. Again, no surprises here - if you're doing an IMC course in real IMC you'd want your instructor to have loads of experience. The trick is to be confident that (a) they're sharp enough to stop you getting into trouble; and (b) if, by some misfortune, they were looking at the map while you got yourself into an inverted, screaming descent, they'll be able to get you out of it. I was fortunate in that my IMC instructors were both several-thousand-hours ex-commercial pilots who had thousands of hours of hands-on IMC between them (i.e. none of this namby-pamby auto-land stuff for the ex- Hunter and Fokker 50 pilot, and lots of nice North Sea weather for the helicopter captain :-) Sadly I can only fly at night with an instructor because the CAA thinks I'm too colour-blind, but it's immense fun and the views are awesome. D. |
On 9/20/2005 12:45, xyzzy wrote:
wrote: As far as instrument training at night, there are good things and bad things. The only real bad thing is it may be more difficult to read charts and such over dim and/or colored cockpit lighting. If you're still still learning the intricacies of reading IFR charts and plates, that can add a bit of congestion to your already overloaded head. Yes, I started IFR training in the winter of last year and did a lot of basic manuevers and chartless approaches (talked through it by the instructor) at night. By the time I was doing aproaches and flying with charts, it was light at my usual training time. Now that it's gettting dark earlier, I'm surprised at how hard it is to put together two things I did well independently (maneuver at night under foggles + use charts). I too saw this the first time I did a cross county IFR training flight at night. I had to look at the chart and determine on which bearing I was from various VORs along the route. There is a larger work load when having to point a flashlight at the chart, then at the panel to scan the instruments, then back to the chart, etc. It would have been easier if my light had been brighter, but there's a cost associated with that (in reduced night adaptation). On the plus side, lots of the subtle visual cues that you get while wearing foggles aren't there. The small peripheral vision leaks out the side of the foggles, the sun changing angles on the instrument panels, etc.... those are pretty much gone at night. You'll have a more realistic environment to train for true "lack of outside references." I disagree with this. When at night under the foggles, when you fly over towns or cities, the glow from the ground is really noticeable in your peripherial vision. Because of this I feel like at night I'm actually getting more visual cues than I should when under the foggles. I agree with this as well. While training, I used to try to ignore all the visual cues (and was able to get disoriented from time to time) - flying at night didn't make this any easier... but I was flying over the valley between Oakland and Sacramento - not the darkest part of the planet to be sure. IMO the best VFR conditions for hood training are hazy southeastern afternoons. Of course, as others have said - nothing beats actual IMC for giving you respect for IMC ;-) If any pilot (or prospective pilot) hasn't experienced it yet, they should grab an instructor and go do it; regardless of their Instrument Rating aspirations. It will really open your eyes - Especially if you think "How hard can it be?" ;-) -- Mark Hansen, PP-ASEL, Instrument Airplane Sacramento, CA |
: It would have been easier if my light had been brighter, but there's
: a cost associated with that (in reduced night adaptation). Just for the record, I have made (IMO) the perfect chart light for night flying. I took a regular minimag flashlight (2-AA type) and replaced the bulb with a single green LED. The smaller one (3/4 T or something... don't remember the size packages of LEDs offhand) is almost the same size as the original light bulb. I had to rig in a resistor (47 Ohm IIRC) in between the two AA's to limit the current. Anyway, bottom line is that it's just enough light to read the features of the chart easily, but not too much to destroy your night vision. Useless as a regular flashlight, but it's perfect for charts and it'll last almost forever on a single set of batteries. : I agree with this as well. While training, I used to try to ignore all : the visual cues (and was able to get disoriented from time to time) - : flying at night didn't make this any easier... but I was flying over : the valley between Oakland and Sacramento - not the darkest part of : the planet to be sure. I'm a bit skewed. Here in the mountains southwest Virginia, there aren't all that many lights. Certainly little "glow from below". You'd have to see the lights out of your peripheral vision to get references from them. I found daylight shadows moving (and my fixed-pitch prop loading/unloading the engine) the most irritating "cheats" to simulated IMC. : : IMO the best VFR conditions for hood training are hazy southeastern : afternoons. : : Of course, as others have said - nothing beats actual IMC for giving : you respect for IMC ;-) If any pilot (or prospective pilot) hasn't : experienced it yet, they should grab an instructor and go do it; regardless : of their Instrument Rating aspirations. It will really open your eyes - : Especially if you think "How hard can it be?" ;-) Absolutely agree. My instructor had me do actual for some of my instrument work for my private. It was a nice, February high overcast chilly day... spent about 20 minutes 500' up in a solid overcast (but above MEA for the area). It felt like 20 hours and I never knew I could sweat so quickly. Here I am... probably about 30 hours total, flying in solid soup using 98% of my brainpower to keep the shiny side up. Instructor leans over and points at the windshield saying, "See that? That's airframe ice." Anyway... enough to instantly instill respect for IMC and icing. Good experience to have under controlled circumstances so you don't blunder into it yourself. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
oups.com... I am getting ready to start of Instrument training. I plan on training during the day on the weekends and 1 or 2 nights during the week. What are your thoughts on instrument training at night? Personally I don't fly at night and have only for what was required for my PPSEL. However my goal is to go on to my Commerical and CFI after the Instrument. I know I will have to get proficient at night flying to teach the PPSEL, but not while IFR. So, I guess my question comes down to added risk. How much additional risk am I taking by doing some of my Instrument at night? As an instrument instructor, I prefer teaching instruments at night. Here's why: 1) It's more realistic to simulate instrument conditions in VMC at night. 2) Most airports seem to be less busy so busting into the pattern from a practice approach is less problematic. 3) In my area, ATC tends to be less busy so controllers tend to be more patient with my students 4) The air is smoother (although sometimes its *too* smooth) 5) the night environment forces good cockpit management habits. Fishing around for a chart is harder at night when they all look alike in the dark. There are challenges and risks though... 1) I tend not to do aggressive unusual attitudes or stalls at night. At night a stall is an instrument manuever for both the student and the instructor, especially on a dark night with no moon. 2) Some fields do not allow practice approachs later in the evening. My local class C doesn't allow them after 10pm, presumably for noise abatement. 3) Airports services are less likely to be available...locked FBOs, no fuel truck, empty vending machines, etc. 4) Greater potential for ground fog...must watch the temperature dewpoint spread. 5) less options available for forced or precautionary landings. Highways and parking lots become viable options. 6) night generally occurs at the end of the day, so stress and rest are factors for both the student and the instructor. An IMSAFE audit is real important. I will fly in IMC at night in a single provided: 1) I am familiar with the aircraft. While engine failure can occur anytime to any engine, the probability is much less on a well maintained aircraft. 2) We are over flat terrain. I will fly over mountains (east coast mountains, that is) at night in VMC provided we have enough visibility, altitude and options below us (i.e. valleys, highways, etc.) 3) We have a GPS with an independent electrical source. This is my rule for day IMC as well. |
I did half of my IFR training at night. If it is VFR go for it. I do not
recommend training in actual at night. Flying IMC at night is some of the hardest flying you will do especially if there is turbulence. Michelle wrote: I am getting ready to start of Instrument training. I plan on training during the day on the weekends and 1 or 2 nights during the week. What are your thoughts on instrument training at night? Personally I don't fly at night and have only for what was required for my PPSEL. However my goal is to go on to my Commerical and CFI after the Instrument. I know I will have to get proficient at night flying to teach the PPSEL, but not while IFR. So, I guess my question comes down to added risk. How much additional risk am I taking by doing some of my Instrument at night? |
Most definitely do some instrument training at night. As others have said,
you do not want your first encounter to be real IMC when it is real dark. Having said that, I add the following: Do some night IFR simulated in VMC with a competent instructor Do some night IFR in ACTUAL IMC, but with good enough visibiity and high enough ceilings to provide an 'out' if you need it (I would vote for a 4-5000 ceiling and 5-8 vis.). These are my personal minimums for night IFR. I scared the crap out of myself with a night flight in actual, with family aboard, and about 1000/3. Will not do it again. wrote in message oups.com... I am getting ready to start of Instrument training. I plan on training during the day on the weekends and 1 or 2 nights during the week. What are your thoughts on instrument training at night? Personally I don't fly at night and have only for what was required for my PPSEL. However my goal is to go on to my Commerical and CFI after the Instrument. I know I will have to get proficient at night flying to teach the PPSEL, but not while IFR. So, I guess my question comes down to added risk. How much additional risk am I taking by doing some of my Instrument at night? |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
Student night solo? | Peter MacPherson | Piloting | 50 | November 10th 04 01:51 AM |
Why was the Fokker D VII A Good Plane? | Matthew G. Saroff | Military Aviation | 111 | May 4th 04 05:34 PM |
CFI logging instrument time | Barry | Instrument Flight Rules | 21 | November 11th 03 12:23 AM |
