#11
Anything of interest heard on Live ATC? I can't connect. Too busy.
Mostly routine, along with a few questions to ATC about how much longer until 292 tries to land and everybody can get back to their regularly scheduled lives. Sounds like airport ops are continuing normally until they're ready to land. |
Another bit of info is that there are about 140 passengers aboard. Poor
passengers, had to ride for about 3 hrs, must be so stressful. |
Kev wrote:
Aha. Thanks so much! It never hit me that dumping fuel would be related to a climb requirement. Can you explain to a layperson how the climb requirement factors into whether it is necessary to have a fuel dump function? Couldn't quite understand the rule. |
"Zulu" wrote in news:IknYe.21672$h02.17700
@tornado.texas.rr.com: Anything of interest heard on Live ATC? I can't connect. Too busy. Mostly routine, along with a few questions to ATC about how much longer until 292 tries to land and everybody can get back to their regularly scheduled lives. Sounds like airport ops are continuing normally until they're ready to land. Thank you. I might try to grab the archives later on. Brian -- http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html Sed quis custodiet ipsos Custodes? |
On Thu, 22 Sep 2005 00:50:48 -0000, Skywise
wrote in :: Anything of interest heard on Live ATC? I can't connect. I'll bet the Aircraft Communication Addressing & Reporting System (ACARS) traffic is more interesting. |
![]() "Bucky" wrote in message ups.com... Kev wrote: Aha. Thanks so much! It never hit me that dumping fuel would be related to a climb requirement. Can you explain to a layperson how the climb requirement factors into whether it is necessary to have a fuel dump function? Couldn't quite understand the rule. Sure. If the aircraft loses an engine immediately following takeoff, it still needs to meet minimum climb performance standards so it can clear whatever obstacles it may encounter near the the airport. It is conceivable that if an airplane (particularly a twin engine aircraft) loses an engine, it may need to reduce weight to meet climb standards. Dumping fuel is the easiest way to quickly reduce weight... |
Yay!
Beautiful job of holding off the gear as long as possible. The fire was a surprise, although it shouldn't have been. MSNBC had a pilot on, who'd had the same problem on a different airplane, and his also skidded down the runway, but he didn't mention flames. Some mention of the fact that the pilot pretty much kept the airliner on the centerline... which of course probably doesn't please LAX's runway maintenance guy grin, who might have to repaint it. |
"I just want to let you know.....We're all counting on you."
oups.com... "I just want to let you know.....We're all counting on you." "Surely you must be joking..." |
Yet another alternator problem | Chris Kennedy | Owning | 7 | July 16th 04 04:28 PM |
Nose gear failure | Greg Esres | Owning | 12 | April 20th 04 11:03 PM |
Garmin fixes moving waypoint problem -- almost | Jon Woellhaf | Instrument Flight Rules | 6 | November 28th 03 05:29 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
Landing gear door operation | Elliot Wilen | Naval Aviation | 11 | July 7th 03 03:47 PM |
