Landing with one spoiler
Old September 23rd 05, 04:13 AM
Bill Daniels
"CindyASK" wrote in message
We do practice that here.
But many places do not practice for this.
Full spoilers deployed ( to achieve symmetry) through approach, from
the point of unlocking through flare/round out and touchdown. The
typical error we find made by pilots in this configuration is the
tendency to "hurry" on approach, with extra airspeed, and not
understand how it will affect their glide slope.
It should be much less of a handling worry to make the glider
symmetrical, and control the approach in a regular configuration, than
to begin to think of all the "different" things you could do to
accommodate the asymmetry.
Just because there are several stories reported here of pilots who
either "didn't notice" their configuration issues, or handled
them with aplomb, remember that this is frequently Not The Case for
just as many others.
We also practice/teach approaches with spoilers completely closed, but
that is a different thread.
Cindy B
Caracole Soaring
Good thoughts. Good also to keep in mind that many gliders will have the
wheel brake fully applied with full spoiler deployment making the touchdown
'interesting'.
Once, long ago, I tested the effect of asymmetrical spoiler deployment to
find out if it would make a suitable roll control. I found that I could
twist around in the seat of a 1-26 just enough to pull one of the spoiler
cables behind the spar box. I was surprised to find that the roll/yaw
effect was small - at least at normal approach airspeeds.
As long as the airspeed is not too high, asymmetrical spoiler can be
controlled with rudder and aileron. Of course, at higher speeds, the yaw
from an open spoiler will overpower the rudder because drag is proportional
to the square of the airspeed. Somehow, rudder authority doesn't increase
at the same rate.
Bill Daniels
Old September 22nd 05, 04:42 PM
Chris Rollings
At 15:06 22 September 2005, Andreas Maurer wrote:
On 21 Sep 2005 21:16:29 -0700, 'Andy' wrote:
You did better than a very experienced local club member
who had the
same problem many years ago in a DG300. He had one
air brake open on
tow, released early instead of gaining altitude and
time, misjudged the
approach and rolled it up in a ball.
Hmmm... the DG-300 has fully automatic control hookups
for the flaps.
How could that happen?
Bye
Andreas
The last DG300 I flew was standard Class, what flaps?
Old September 22nd 05, 08:52 PM
Andreas Maurer
On 22 Sep 2005 15:42:44 GMT, Chris Rollings
Ahhh.. sorry: I meant airbrakes.
Bye
Andreas
Old September 23rd 05, 01:00 AM
Chris Rollings wrote:
I recollect once watching someone land an ASW20 with
only one brake deployed. The pilot didn't even notice
there was a problem, just wondered why one wing dropped
a little earlier than usual. Lucky, I would agree.
I too did an incomplete check and one brake on my ASW-20 came full open on tow. Though controllable it was easier to open both (the other) brake to balance the yaw force. After climbing to a suitable altitude I released and landed successfully using the "both" brakes method. As one can see there is a difference how to handle the case of one brake that won't deploy versus the case where the one brake stays deployed. Rudy Allemann
Old September 22nd 05, 06:23 PM
Peter Harvey
I landed our ASW22A with one brake deployed. It had
been flown previously that day by my syndicate partner,
without problem. Luckily I usually pop the brakes on
the downwind or base leg just to check all is well.
In this instance (at Dunstable) after a bang, the
LHS brake deployed OK, but the RHS stayed down. There
was a roll and yaw. I shut the brake(s) quickly looked
again and the RHS was now open and LHS closed, with
the opposite affect. Gulp, panic at thought of landing
Open class without brakes, etc. Landing was just OK
with a slight groundloop (stick forward and lots of
brake (tail lifts, so no probs).
The Hotelier for the brake had popped off after a previous
flight. We used safetys after that with no further
problems.
1) I still pop the brakes to check on base or final
(and often just after settled into first climb). Cheap
insurance.
2) On the assembly, I always give the Hoteliers a good
tug to ensure they're WELL AND TRUELY connected.
Stay safe.
Pete.
At 04:12 22 September 2005, wrote:
I committed one of the worst errors - an incomplete
preflight check.
I did not check the hotelier locks to the spoiler rods
with enough care
before takeoff. Coming into the pattern I extended
the spoilers and
noticed immediately that something was wrong. The glider
(SparrowHawk)
was pulling to one side and the rate of descent was
not as much as I
expected. However the glider was easily controllable.
A few seconds and
I saw that the right spoiler was not deploying. What
to do? A couple of
attempts to close and open the spoilers did not actuate
the right
spoiler. Then, oh well, lets check and see the effect
of landing with
only one spoiler. The situation was less dramatic than
expected.
Maximum sink rate was halved and the SparrowHawk needed
some cross
control to fly straight but no problem. The landing
was easy and
controllable. The lessons to be learnt from this are
2 fold: 1) landing
a glider with only one spoiler should be easy for most
pilots and 2) do
a serious preflight inspection especially after assembly.
Dave
Old September 22nd 05, 06:33 PM
David Salmon
Guess I'm just unlucky as I've had this twice.
Many years ago in a Kestrel 19 the brake drive in one
wing failed. Didn't even notice till I'd landed and
saw one brake out and one in.
Second time was test flying a club Grob Acro after
C of A and rigging. It had some cosmetic work done
on the brake slots. On the ground everything worked
perfectly, it had a rigging check, DI, and 2 pre flights
because we initially had a ground run cable break.
On approach the brakes would not open, but did so after
applying quite alot of pressure. In fact one opened
and the other side wing pushrod bent.
After repairs we tried again, after first getting a
lot of people pushing up on the wings, the brakes were
OK. Top of the launch, they would not open until we
pushed over for some reduced G.
It turned out that the cosmetic repairs had closed
up the end gap which the caps need to move about 3
mm tipwise before opening, and the caps were jamming.
It needed a lot of removal before they worked properly.
The point is that there were no control problems whatsoever
with one brake in and one out.
Dave Salmon
preflight check.
with enough care
the spoilers and
(SparrowHawk)
not as much as I
A few seconds and
to do? A couple of
the right
of landing with
expected.
some cross
was easy and
2 fold: 1) landing
pilots and 2) do
Dave
Old September 23rd 05, 01:01 AM
Bruce Hoult
Note to self: if brakes won't open, try a pushover to unload the wings.
Bruce | 41.1670S | \ spoken | -+-
Hoult | 174.8263E | /\ here. | ----------O----------
Old September 23rd 05, 12:54 AM
COLIN LAMB
If one spoiler deploys and the other one does not, and it will not retract,
and it significantly affects landing, I expect that a forward slip, with the
fuselage blocking the deployed spoiler (or flap) would be an alternative to
try.
At a time like that, you are glad you do not have barn door spoilers.
Colin
Old September 23rd 05, 12:57 PM
Ray Hart
In 2001 I was sadly involved with the aftermath of
an accident to an SZD
Junior. The BGA/AAIB inquiry found evidence that one
airbrake had
deployed (over-ranging and a broken drive gear) - the
result was a spiral
dive into the ground. Moves to test a Junior rigged
so that only one
brake deployed were vetoed (non-airworthy, so uninsured).
A test pilot study of a range of glider types with
one brake deployed
would, no doubt, make interesting reading though.
It is always worth visually checking the brakes if
the glider develops
asymetry during flight. It is also worth trying the
occasional full brake
landing, just in case. I wouldn't recommend practising
no-brake landings
though.
Ray
At 03:12 23 September 2005, Bill Daniels wrote:
'CindyASK' wrote in message
approach,
from
touchdown. The
is the
tendency to 'hurry' on approach, with extra airspeed,
and not
the glider
configuration,
than
to begin to think of all the 'different' things you
could do to
of pilots who
either 'didn't notice' their configuration issues,
or handled
Not The Case for
closed,
but
Cindy B
Caracole Soaring
gliders will have
making the
touchdown
'interesting'.
spoiler deployment
to
one of the spoiler
that the roll/yaw
spoiler can be
higher speeds, the
yaw
drag is
proportional
doesn't
increase
at the same rate.
Bill Daniels
Cuban Missle Crisis - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 09:14 PM
