Overhaul 14 year old prop?
Old September 24th 05, 03:20 AM
karl gruber
That's what I said. The guerrilla with the grinder takes off so much
material that it can only be "overhauled" three times. Even with
perfect rock chip free blades.
The other problem is the grinding is done without templates, completely
by guerrilla eye. The blades NEVER come out as good as new.
Old September 24th 05, 03:30 AM
George Patterson
Twice. Overhaul at 5 years, again at 10 years, and at 15, they're too small to redo.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old September 24th 05, 03:36 PM
Roger
On Sat, 24 Sep 2005 02:30:11 GMT, George Patterson
If they need seals, but the blades are in spec why run them through
the grinder?
Mine get a yearly, or when ever needed polishing with 200 grit and
crocus(sp?) cloth to smooth and shine the leading edge. Other than
looking like they need painting after a years flying they rarely ever
need dressing. OTOH you do have to be careful about winter flying with
snow and slush.
When I replaced the 20 some year old, 2-blade prop with a 3-blade the
old one was still well within spec. I don't recall as it had ever been
reshaped, but it had been through several overhauls where the seals
were replaced.
www.rogerhalstead.com
George Patterson
Old September 25th 05, 02:13 AM
Hmmm. Once upon a time I maintained a bunch of Pt 135 (mandatory
propeller/engine overhaul) airplanes with "Brand H" (5 years BTW for
the ones I am familiar with has changed to 6 years since they started
painting the inside of the hub) compact-hub props.
Blade's leading edges and faces dressed & painted EVERY 100 hours (or
at 50 if they looked really scabby), overhauled every 4-5 years
(happens when you put 400-500 hrs on per year).
Only "new" blades that I had scrapped after repeated o-haul were for
not meeting the min. OD of the blade shank. This shank is required to
be mechanically rolled (reducing the OD) and the roll marks
mechanically removed (reducing the OD further) at each overhaul on
many compact-hub props.
As you've indicated, this occurred typically at the third overhaul,
but technically has nothing to do with somebody randomly grinding
material off of the blades.
Blade grinding is more art than science, and a decent grinder can eval
and remove a minimal amount of material from a blade that has been
properly maintained and repaired. FOD, including repeated operations
from unimproved surfaces (or "hard" water on floatplanes), and
corrosion from improper conversion coating/painting (or not
maintaining the paint/conversion coating) can drastically reduce
blade life (by requiring more material to be removed). But that is NOT
the fault of the guy doing the grinding.
BTW, after one of my employers purchased the prop shop that had been
doing 90% of my propeller work over the years, I gained a lot more
insight into the whole overhaul procedure.
As Mr. Weir had mentioned repeatedly, an AP/IA cannot ground an
aircraft, but this alleged AP/IA could/can/does choose not to perform
an annual inspection on a constant-speed propeller that hadn't been
torn-down, corrosion-inspected, and re-sealed within a 10 year period.
BTW, that practice was in place many years before I had access to a
"company" prop shop.
Regards;
TC
snip
Old September 24th 05, 08:56 PM
Juan Jimenez
You seem to be implying that blades should somehow be overhauled to come out
as new, as if they were engines being overhauled to factory specs. On what
do you base this? I've attended seminars given by prop shops with decades of
experience explaining, with ample documentation, both visual and written,
all the things a prop goes through in flight and on the ground, the stresses
it withstands, etc. I've also seen firsthand what a prop blade failure can
do to an engine and aircraft. Why anyone would want to cut corners on prop
overhauls and maintenance on the basis of statements such as "guerrilla eye"
is beyond me.
"karl gruber" wrote in message
Old September 26th 05, 04:51 AM
karl gruber
eye"
is beyond me.
Juan, most aviation related topics ARE beyond you comprehension. Glad
you finally recognised that. Why don't you go out squeeze in your BD-5
with your god Jim Bede.
Old September 25th 05, 12:38 AM
Flyingmonk
Life is boring Jay. Just keep running it till it looses a blade and
rattle the engine off the mount (this might shift your C/G to WAYYY
aft).
Take note off how many hours it took to get to that point and report
back. : ^).
It's been a boring day...
Bryan "The Monk" Chaisone
Old September 25th 05, 07:56 AM
Roger
aft).
back. : ^).
Why grind the blade is there is nothing wrong other than the leanding
edge needs polishing. I've seen very old blades that were in great
shape (of course they need to be torn down and inspected), but I've
seen 100 hour blades that had been flown off water, or our Michigan
slush that I figured were beyond dressing out.
Old September 25th 05, 03:52 PM
George Patterson
Paint could be hiding cracks.
George Patterson
Old September 26th 05, 06:23 AM
Roger
On Sun, 25 Sep 2005 14:52:10 GMT, George Patterson
You have paint on the leading edges of your prop? :-))
It stayed on mine for all of a couple of weeks and I fly off a paved
strip.
They should be able to polish the leading edge to check it and remove
the paint without grinding to check the rest.
"Grinding" sounds like a harsh way to check for cracks, but there may
be something I'm missing.
I can understand grinding deep enough to relieve stresses, but I'd
think there'd be little if the prop never had to be dressed. OTOH
I've seen some pretty nasty stuff "dressed" out of props and I would
expect there to be stress from some of those going too deep to be
ground out, but without any visible cracks to show in dye penetrant
testing.
So, I'd still expect them to be able to overhaul and inspect a good
many props without having to do a real grind job. All I'd expect would
be a fast lap with 200 grit, a dye check, and a polish followed by a
coat of paint for those that check good
If it has even hair line cracks they'll show without having to grind
deeply. If none and no dressing out show there shouldn't be any real
reason to take off a lot of metal. I would think stress being ground
out had to be caused by something that either left a mark or was
dressed out. Both would show, visibly or with dye.
George Patterson
Roger
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
A Rec.Aviation FRS Channel @ Oshkosh this year? Bob Chilcoat Piloting 10 June 19th 05 03:32 PM
my ignorance LCT Paintball Home Built 25 April 9th 05 06:54 PM
Instrument overhaul - Are all overhauls created equal? RonLee Home Built 1 February 7th 05 06:35 PM
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
