Morgans wrote:
Diesel is still cheaper than jet fuel. Or isn't it? I've been too afraid to go to the pump the past few days One thing I have to ask, is if that engine is rated to use Jet A? From what I have read, many are not, because some injector pumps need the lubrication that diesel provides, that Jet A does not have. If the pump is not able to handle the Jet A, it will quit in fairly short order. Not if you mix in 2% biodiesel. That replaces the lubrosity lost by eliminating the sulfides in the diesel fuel. AP |
Philippe Vessaire wrote:
wrote: It _is_ pretty impressive technology. Though the European-ness of it is really isn't that big of a deal. All the car companies are pan-global entities these days. Diesel is still cheaper than jet fuel. Or isn't it? Jet A1 is a little bit cheaper, but it need oil addition (2 strokes oil is good but normal oil would be ok) for high pressure pump. I've been too afraid to go to the pump the past few days :-) At current prices biodiesel does become cost effective if one could find a suitable anti-gel agent. No anti-froze agent needed, just an fuel/water heat exchange and the whole tank become warmer when the engine is runnig. For pure biodiesel, the car choice is an exhaust/fuel heat exchange. I just wait for a new design from daihatsu: a 2 cylinder, 2 strokes superchared, turbocharged 85HP. I'm waiting for weight info, the 2 strokes only may achieve same weight than mogas engine. By -- Pub: http://www.slowfood.fr/france Philippe Vessaire =D2=BF=D3=AC Have you heard of anyone cutting Jet A like your describing? I would expect those engines are quite sensative. I'd be really nervous about fuel/oil ratios doing that! Interesting thought on plumbing the coolant to the fuel tanks. Have you heard of anybody doing this on an aircraft? (I know the car guys do it all the time) That might make aircraft designed with header tanks more appropriate for diesels. (Easier to build the heat sink) It might even be possible to just ignore the radiator completely and turn the skin of the aircraft into the heat sink. Basically you'd route several flows of 3/8" aluminum tubing strategically about the airplane. You could end up with a deicing system instead of a radiator! It would probably take more line/water than was in the radiator, but it might make up for it in aerodynamics. (No radiator hanging in the breeze) I'd have to crunch the numbers, it probably isn't feasable, but it's a thought.=20 -Matt |
No anti-froze agent needed, just an fuel/water heat exchange and the whole tank become warmer when the engine is runnig. For pure biodiesel, the car choice is an exhaust/fuel heat exchange. I've never seen this. All of the biodiesel/vegoil cars I've seen have used coolant/fuel heat exchangers. AP |
Can't find any info regarding weight, but in my new VW 1.9 TDI PD the
performance is very good. David wrote in message ups.com... Anybody know anything about that CH701 on Zenairs site that has a mercedes smart Diesel in it? It got me to poking around on some european website. I found the specs for the ford 1.4 litre diesel sold over there. Not sure how the figures size up to gas engines currently in use. Any Opinions? http://www.histomobile.com/histomob/tech/2/112.htm -Matt |
![]() "dje" wrote in message ... Can't find any info regarding weight, but in my new VW 1.9 TDI PD the performance is very good. You have a "Mercedes" diesel in you VW? -- Jim in NC |
a écrit:
It got me to poking around on some european website. I found the specs for the ford 1.4 litre diesel sold over there. Not sure how the figures size up to gas engines currently in use. Any Opinions? These engines are "Light weight" only for automotive use. The 1l4 is a Peugeot design, you may choose a 1l6 (DV6 TED4) with the same weigt and power up to 110HP@4000rpm. http://minilien.com/?krjU8zHgIx I am not sure, but I read "around" 100kg for the engine. You still kneed a PSRU. I think you may have a 110HP engine for 120-130kg minimum. It is still heavier than mogas engine. Just for fun: with this type of engine, you may got 50mpg on car like Toyota Corolla. By -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
Just a point. On one 700 mile trip in my VW Jetta TDI, holding the speed to
between 55 and 60mph, I got 55mpg. Normal use is 45mpg or better. -- Kathy Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 (760) 408-9747 general and layout cell (760) 608-1299 technical and advertising cell www.vkss.com www.experimentalhelo.com "Philippe Vessaire" wrote in message ... a écrit: It got me to poking around on some european website. I found the specs for the ford 1.4 litre diesel sold over there. Not sure how the figures size up to gas engines currently in use. Any Opinions? These engines are "Light weight" only for automotive use. The 1l4 is a Peugeot design, you may choose a 1l6 (DV6 TED4) with the same weigt and power up to 110HP@4000rpm. http://minilien.com/?krjU8zHgIx I am not sure, but I read "around" 100kg for the engine. You still kneed a PSRU. I think you may have a 110HP engine for 120-130kg minimum. It is still heavier than mogas engine. Just for fun: with this type of engine, you may got 50mpg on car like Toyota Corolla. By -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
Stuart & Kathryn Fields wrote:
Just a point. On one 700 mile trip in my VW Jetta TDI, holding the speed to between 55 and 60mph, I got 55mpg. Normal use is 45mpg or better. just googlise that: diesel "2CDDI-II" and you will see that http://www.daihatsu.com/motorshow/frankfurt05/pdf/e.pdf The most désirable diesel for light aircraft may be hide in the 2CDDI-II name. Just wait more news about weight. By. -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
Here is the VW tdi as an industrial engine.
Given the application I would expect there is a big honkin flywheel on this thing that would be removed for aviation purposes. Then after replacing the the alternator etc etc. It would still be heavy, but potentially doable. http://www.maesco.com/products/vwp/v...dieselpto.html Anyway, it's something interesting to look at. -Matt |
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB | Mal | Soaring | 59 | October 4th 05 05:39 AM |
The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 12:07 PM |
New Military Aviation Books from Germany | ArtKramr | Military Aviation | 0 | November 23rd 03 11:43 PM |
New Military Aviation Books from Germany | ArtKramr | Military Aviation | 0 | October 29th 03 02:33 AM |
New WWII books from Germany | ArtKramr | Military Aviation | 0 | October 13th 03 12:54 AM |
