I am looking for a US source for a rechargeable (preferably gel or
sealed lead-acid) for the fin battery box of a Schempp-Hirth. I need the extra power as well as the tail weight! Dimensions are approximately 10 inches long, 4 inches wide and 1-1/2 inches deep. I've found a few single-cell solutions that I could make work but wondered if there was an off-the shelf item that would fit? Thanks.... Mike |
Mouser has a large selection of sealed lead acid batteries.
http://www.mouser.com At 02:36 26 September 2005, Mike The Strike wrote: I am looking for a US source for a rechargeable (preferably gel or sealed lead-acid) for the fin battery box of a Schempp-Hirth. I need the extra power as well as the tail weight! Dimensions are approximately 10 inches long, 4 inches wide and 1-1/2 inches deep. I've found a few single-cell solutions that I could make work but wondered if there was an off-the shelf item that would fit? Thanks.... Mike |
Mike the Strike wrote:
I am looking for a US source for a rechargeable (preferably gel or sealed lead-acid) for the fin battery box of a Schempp-Hirth. I need the extra power as well as the tail weight! Dimensions are approximately 10 inches long, 4 inches wide and 1-1/2 inches deep. I've found a few single-cell solutions that I could make work but wondered if there was an off-the shelf item that would fit? Thanks.... Mike That 1 1/2 inch depth constraint really limits your options. Feel fortunate if you can make up your own solution from single cells, or find a battery shop to do it for you. -Dave |
Well it does limit the options, your right. However, ELK products does have
a nice little 6 volt 7.5 amp hour that could be connect in series (2) for a 12 volt 7.5 amp hour pack, or series parallel (4) for a 12 volt 15 amp hour pack, and would fit (at least two of 'em would) as the smallest dimension is 1.34 inches. These are sealed lead acid AGM batteries - - - bumper ELK-0675 6 Volts, 7.5 Ah ELK Sealed Lead Acid Batteries are excellent for the following applications with regard to size, Amp hour rating, and proper terminal connections: battery backup (for Access Control Systems, Fire Alarm Systems, and Security Alarm Systems), emergency lights, lighted exit signs, and uninterruptible power supplies. SPECIFICATIONS: . Nominal Voltage: . Rated Capacity: . Length: . Width: . Height: . Total Height w/ terminals: . Weight: . Terminals: 6 Volts 7.5 AH (20 hour rate) 5.91" (150mm) 1.34" (34mm) 3.70 (94mm) 3.90" (99mm) 3.08 lbs (1.4kg) F1-Faston Tab No. 187 "David Kinsell" wrote in message . .. Mike the Strike wrote: I am looking for a US source for a rechargeable (preferably gel or sealed lead-acid) for the fin battery box of a Schempp-Hirth. I need the extra power as well as the tail weight! Dimensions are approximately 10 inches long, 4 inches wide and 1-1/2 inches deep. I've found a few single-cell solutions that I could make work but wondered if there was an off-the shelf item that would fit? Thanks.... Mike That 1 1/2 inch depth constraint really limits your options. Feel fortunate if you can make up your own solution from single cells, or find a battery shop to do it for you. -Dave |
"David Kinsell" wrote in message . .. Mike the Strike wrote: I am looking for a US source for a rechargeable (preferably gel or sealed lead-acid) for the fin battery box of a Schempp-Hirth. I need the extra power as well as the tail weight! Dimensions are approximately 10 inches long, 4 inches wide and 1-1/2 inches deep. I've found a few single-cell solutions that I could make work but wondered if there was an off-the shelf item that would fit? Thanks.... Mike That 1 1/2 inch depth constraint really limits your options. Feel fortunate if you can make up your own solution from single cells, or find a battery shop to do it for you. -Dave bumper wrote: Well it does limit the options, your right. However, ELK products does have a nice little 6 volt 7.5 amp hour that could be connect in series (2) for a 12 volt 7.5 amp hour pack, or series parallel (4) for a 12 volt 15 amp hour pack, and would fit (at least two of 'em would) as the smallest dimension is 1.34 inches. These are sealed lead acid AGM batteries - - - bumper ELK-0675 6 Volts, 7.5 Ah ELK Sealed Lead Acid Batteries are excellent for the following applications with regard to size, Amp hour rating, and proper terminal connections: battery backup (for Access Control Systems, Fire Alarm Systems, and Security Alarm Systems), emergency lights, lighted exit signs, and uninterruptible power supplies. SPECIFICATIONS: . Nominal Voltage: 6 Volts . Rated Capacity: 7.5 AH (20 hour rate) . Length: 5.91" (150mm) . Width: 1.34" (34mm) . Height: 3.70" (94mm) . Total Height w/ terminals: 3.90" (99mm) . Weight: 3.08 lbs (1.4kg) . Terminals: F1-Faston Tab No. 187 Top posting mistake corrected, and formatting problems fixed. Please folks, no top posting, it screws up the readability when you do that. Particularly when the correct bottom-posting has been established. It's like joining a thermal in the wrong direction, but in this case, there's only one right way to circle. Back to the battery. Each battery has a length of almost 6 inches, so you can't fit even two of them in the 10 inches provided. Four would take a real trash-masher to squeeze them in. Plus, you'd end up with a 12 volt battery trying to power a 14 volt radio, so you'd get about half the rated capacity before the transmitter craps out. But that's a little too technical for this crowd. -Dave |
David Kinsell wrote:
"David Kinsell" wrote in message . .. Mike the Strike wrote: I am looking for a US source for a rechargeable (preferably gel or sealed lead-acid) for the fin battery box of a Schempp-Hirth. I need the extra power as well as the tail weight! Dimensions are approximately 10 inches long, 4 inches wide and 1-1/2 inches deep. I've found a few single-cell solutions that I could make work but wondered if there was an off-the shelf item that would fit? Thanks.... Mike That 1 1/2 inch depth constraint really limits your options. Feel fortunate if you can make up your own solution from single cells, or find a battery shop to do it for you. -Dave bumper wrote: Well it does limit the options, your right. However, ELK products does have a nice little 6 volt 7.5 amp hour that could be connect in series (2) for a 12 volt 7.5 amp hour pack, or series parallel (4) for a 12 volt 15 amp hour pack, and would fit (at least two of 'em would) as the smallest dimension is 1.34 inches. These are sealed lead acid AGM batteries - - - bumper ELK-0675 6 Volts, 7.5 Ah ELK Sealed Lead Acid Batteries are excellent for the following applications with regard to size, Amp hour rating, and proper terminal connections: battery backup (for Access Control Systems, Fire Alarm Systems, and Security Alarm Systems), emergency lights, lighted exit signs, and uninterruptible power supplies. SPECIFICATIONS: . Nominal Voltage: 6 Volts . Rated Capacity: 7.5 AH (20 hour rate) . Length: 5.91" (150mm) . Width: 1.34" (34mm) . Height: 3.70" (94mm) . Total Height w/ terminals: 3.90" (99mm) . Weight: 3.08 lbs (1.4kg) . Terminals: F1-Faston Tab No. 187 Top posting mistake corrected, I'd call it a preference instead of a mistake, but I also prefer bottom posting. and formatting problems fixed. Please folks, no top posting, it screws up the readability when you do that. Particularly when the correct bottom-posting has been established. It's like joining a thermal in the wrong direction, but in this case, there's only one right way to circle. Back to the battery. Each battery has a length of almost 6 inches, so you can't fit even two of them in the 10 inches provided. Four would take a real trash-masher to squeeze them in. Plus, you'd end up with a 12 volt battery trying to power a 14 volt radio, so you'd get about half the rated capacity before the transmitter craps out. But that's a little too technical for this crowd. Now, now, Dave, Mike didn't indicate it was for a 14 volt radio, or even that it was for a radio at all. Maybe it's to back up his logger and vario. And, 14 volts might not be compatible with his other battery(s). Before prescribing solutions, the volt doctor should determine the problem! -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Eric Greenwell wrote:
David Kinsell wrote: "David Kinsell" wrote in message . .. Mike the Strike wrote: I am looking for a US source for a rechargeable (preferably gel or sealed lead-acid) for the fin battery box of a Schempp-Hirth. I need the extra power as well as the tail weight! Dimensions are approximately 10 inches long, 4 inches wide and 1-1/2 inches deep. I've found a few single-cell solutions that I could make work but wondered if there was an off-the shelf item that would fit? Thanks.... Mike That 1 1/2 inch depth constraint really limits your options. Feel fortunate if you can make up your own solution from single cells, or find a battery shop to do it for you. -Dave bumper wrote: Well it does limit the options, your right. However, ELK products does have a nice little 6 volt 7.5 amp hour that could be connect in series (2) for a 12 volt 7.5 amp hour pack, or series parallel (4) for a 12 volt 15 amp hour pack, and would fit (at least two of 'em would) as the smallest dimension is 1.34 inches. These are sealed lead acid AGM batteries - - - bumper ELK-0675 6 Volts, 7.5 Ah ELK Sealed Lead Acid Batteries are excellent for the following applications with regard to size, Amp hour rating, and proper terminal connections: battery backup (for Access Control Systems, Fire AlarmSystems, and Security Alarm Systems), emergency lights, lighted exitsigns, and uninterruptible power supplies. SPECIFICATIONS: . Nominal Voltage: 6 Volts . Rated Capacity: 7.5 AH (20 hour rate) . Length: 5.91" (150mm) . Width: 1.34" (34mm) . Height: 3.70" (94mm) . Total Height w/ terminals: 3.90" (99mm) . Weight: 3.08 lbs (1.4kg) . Terminals: F1-Faston Tab No. 187 Top posting mistake corrected, I'd call it a preference instead of a mistake, but I also prefer bottom posting. Doing top-posting after bottom posting had been initiated in a string is a mistake by any reasonable definition. A: Because it messes up the order in which people normally read text. Q: Why is top-posting such a bad thing? A: Top-posting. Q: What's the most annoying thing on Usenet and in email? http://www.caliburn.nl/topposting.html and formatting problems fixed. Please folks, no top posting, it screws up the readability when you do that. Particularly when the correct bottom-posting has been established. It's like joining a thermal in the wrong direction, but in this case, there's only one right way to circle. Back to the battery. Each battery has a length of almost 6 inches, so you can't fit even two of them in the 10 inches provided. Four would take a real trash-masher to squeeze them in. Plus, you'd end up with a 12 volt battery trying to power a 14 volt radio, so you'd get about half the rated capacity before the transmitter craps out. But that's a little too technical for this crowd. Now, now, Dave, Mike didn't indicate it was for a 14 volt radio, or even that it was for a radio at all. And what radio do you suppose he's using if it's not a 14 volt radio? Maybe it's to back up his logger and vario. Both of which would work better on 14 volts. You do know it's been the standard for small aircraft electrical systems for what, 50, 75 years now?? A bunch of cheap-ass glider pilots aren't about to change that fact, are they? And, 14 volts might not be compatible with his other battery(s). You don't think he's going to actually hook the batteries together do you? That would blow the tail clean off the glider, if you believe what you read in RAS!! Before prescribing solutions, the volt doctor should determine the problem! It's not real hard to divine the problem with most electrical systems. Not enough volts, too many pounds of dead weight in improper batteries. Not a hard diagnosis at all. -Dave |
| Thread Tools | |
| Display Modes | |
| Battery Question | [email protected] | Soaring | 19 | September 15th 05 02:38 AM |
| Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 05:30 PM |
| 14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 02:37 AM |
| Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 02:29 PM |
| Battery life...how to test? | Jim Kelly | Soaring | 2 | July 11th 03 10:12 PM |
