Shotgun Starts
Old October 3rd 05, 09:04 PM
Bret Ludwig
Orval Fairbairn wrote:
snip
Canberra was a twin-engined British design for a high-altitude bomber.
The Martin Co. modified the Canberra into the B-57; the special
reconnaisance aircraft was the "RB-57D/E," which looked somewhat like
the B-57, but with much longer wings and different engines.
That's because it was a B-57 with much longer wings and different
engines. Actually there were two variants: one had four engines, two
monsters and two auxilliary engines IIRC.
Old October 4th 05, 02:22 PM
jmk
First off, you are right. Don't know where I got THAT confused. We
worked on a TR-3 NASA aircraft (nothing to do with the "new" TR-3
triangle aircraft). back in the late 70's, which was also a variant.
FWIW, did find a picture of a Canberra starting up.
http://www.ramm.shacknet.nu/robant/a...to%20leave.JPG
Old October 4th 05, 07:46 PM
Dan, U.S. Air Force, retired
The first time I ever saw a cart start up close was an F-4E in a tab
V shelter, I never could remember what tab V stood for, and was quite
impressed. Just before start we vacated the tab V and watched from
outside. A jet of flame and smoke appeared under the left engine and
within a couple of seconds the shelter filled up with dense black smoke
which obscured everything from the cockpits on back. When the engine was
up and running the smoke cleared in a couple of seconds.
One thing I wish I could see would be a B-52 cart starting all eight
engines at once.
Old October 5th 05, 02:24 AM
Big John
Lakeview Bill
Yep.
37mm.
Used to have one as a desk ornament.
I rode the training tower at Willie using these shells. All the jet
Pilots and students had to ride tahe ejection training tower.
Big John
On Fri, 30 Sep 2005 21:35:40 GMT, "Lakeview Bill"
From what I have read, the output of the firing mechanism, which was really
only a large column of moving air, was fed directly into one of the existing
cylinders.
If you can get your hands on a copy of the original version of "The Flight
of the Phoenix", there's a scene where Jimmy Stewart (who had been a B-24
bomber pilot in WWII), is trying to start a cobbled-together aircraft with a
shotgun starter. He only has a limited number of shells; naturally, it
starts on the last one.
BTW: Did you know that ejection seats were once powered by cannon shells?
"Dick" wrote in message
et...
Was talking with some WW2 guys who remembered the use of 10 gauge shotgun
shells to start an aircraft engine. I've seen several movies showing
something but my question is how did it work? shell in seperate cylinder
from pistons and how push crank over, etc??
Toronto Area Glider Pilot Ground School Starts Thu. February 24, 2005 Ulf Soaring 0 February 3rd 05 06:16 PM
EAA Airventure 2005 Starts on a Monday Fitzair4 Home Built 9 September 21st 04 03:04 AM
Air Force Raptor fighter starts operational trials, By John J. Lumpkin Otis Willie Military Aviation 0 May 1st 04 10:18 PM
Training starts with aerospace physiology Otis Willie Military Aviation 2 December 4th 03 11:03 AM
Toronto Area Glider Pilot Ground School Starts Wed. November 19 Ulf Soaring 0 November 1st 03 11:09 AM
