#11
Matt Barrow wrote:
I believe that's a Turbo Alley turbonormalizer, not a Turbo "supercharger". If not, I suspect the STC might require some "beefing up" of certain parts. According to the article, it's a RCM turbonormalization package which contains a turbocharger. The turbocharger is made by Kelly Aerospace. They say they have over 1600 hours on one Commander with it. This unit keeps the manifold pressure at or below 28 PSI. I take it you were describing systems that do not have this limitation. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
"George Patterson" wrote in message news Um0f.35172$wb3.22707@trndny03...Matt Barrow wrote: I believe that's a Turbo Alley turbonormalizer, not a Turbo "supercharger". If not, I suspect the STC might require some "beefing up" of certain parts. According to the article, it's a RCM turbonormalization package which contains a turbocharger. That sounds like being "sorta pregnant". A TN system has a TC, but the popoff keeps it from running beyonf normal sea level pressure internally. The turbocharger is made by Kelly Aerospace. They say they have over 1600 hours on one Commander with it. This unit keeps the manifold pressure at or below 28 PSI. That's about typical for a TN system. Mine keeps MP at or below 31.5 inches. I take it you were describing systems that do not have this limitation. A TN system will been a TC Lite :~) -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
Right. A turbonormalized engine never sees any more pressure than one
that is normally aspirated - it just sees it up to a high altitude. Cooling (at high altitudes) may be an issue, but not cylinder pressure. |
jmk wrote:
: Right. A turbonormalized engine never sees any more pressure than one : that is normally aspirated - it just sees it up to a high altitude. : Cooling (at high altitudes) may be an issue, but not cylinder pressure. Actually, technically speaking, running the same MP at higher altitudes will produce a little more power than at lower altitudes. The lower ambient pressure reduces backpressure on the exhaust, so there's more scavanging and a bigger intake air/fuel charge for the same MP. I saw that in the performance specs on a friend's normally-aspirated PA-24-250. Something like equal power is between 1-2" different MP at 12000' vs. sea level (RPM constant). I don't remember the exact numbers, but that's in the ballpark. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
wrote in message ... jmk wrote: : Right. A turbonormalized engine never sees any more pressure than one : that is normally aspirated - it just sees it up to a high altitude. : Cooling (at high altitudes) may be an issue, but not cylinder pressure. Actually, technically speaking, running the same MP at higher altitudes will produce a little more power than at lower altitudes. The lower ambient pressure reduces backpressure on the exhaust, so there's more scavanging and a bigger intake air/fuel charge for the same MP. I saw that in the performance specs on a friend's normally-aspirated PA-24-250. Something like equal power is between 1-2" different MP at 12000' vs. sea level (RPM constant). I don't remember the exact numbers, but that's in the ballpark. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** It doesn't work that way with a turbocharged engine since the ingested air is heated by compression. Mike MU-2 |
Mike Rapoport wrote:
: It doesn't work that way with a turbocharged engine since the ingested air : is heated by compression. I would argue that it still works that way. In addition, however, the heating of the intake air reduces the effective mass on the intake charge. Whether one or the other dominates or they cancel each other out depends on lots of factors... in particular an intercooler. I'm not being argumentative... just sharing info that I'd never thought of before. It doesn't make a huge difference, but it does make a difference. Running 24/24 doesn't *always* make the same power or burn the same fuel. Altitude and mixture both have 10-20% adjustment fudge factors in there.... throw in a turbo with heating and there's another 10-20% in the mix as well. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
... Mike Rapoport wrote: : It doesn't work that way with a turbocharged engine since the ingested air : is heated by compression. I would argue that it still works that way. In addition, however, the heating of the intake air reduces the effective mass on the intake charge. Whether one or the other dominates or they cancel each other out depends on lots of factors... in particular an intercooler. I'm not being argumentative... just sharing info that I'd never thought of before. It doesn't make a huge difference, but it does make a difference. Running 24/24 doesn't *always* make the same power or burn the same fuel. Altitude and mixture both have 10-20% adjustment fudge factors in there.... throw in a turbo with heating and there's another 10-20% in the mix as well. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** The heating of the intake and the consequent reduction in density is the reason that I think it will take more MP to produce the same HP at higher altitudes with a turbocharged engine. At the same MP/RPM a tubocharged engine is effectively running at a higher density altitude than a normally aspirated one. The turbocharged engine is also running at a higher density altitude as altitude increases at the same PM becasue there is more compression required, therefore more heating. The intake air is heated *substantially* and its density is reduced substantially. Natually, the effect is strongest at high manifold pressures and high altitudes. I agree that reduced pressure at the exhaust helps and an intercooler certainly helps too. I don't have a flight manual for a turbocharged airplane here but hopefully somebody here does. Mike MU-2 |
: The heating of the intake and the consequent reduction in density is the
: reason that I think it will take more MP to produce the same HP at higher : altitudes with a turbocharged engine. At the same MP/RPM a tubocharged : engine is effectively running at a higher density altitude than a normally : aspirated one. The turbocharged engine is also running at a higher density : altitude as altitude increases at the same PM becasue there is more : compression required, therefore more heating. The intake air is heated : *substantially* and its density is reduced substantially. Natually, the : effect is strongest at high manifold pressures and high altitudes. I agree : that reduced pressure at the exhaust helps and an intercooler certainly : helps too. : I don't have a flight manual for a turbocharged airplane here but hopefully : somebody here does. I agree completely. The heating can be quite substantial from what I've read. If there's no intercooler, I suspect that you probably always lose the added scavanging HP to lower density incoming air at the elevated temperature as you suggest. If there's an intercooler, things might trade off differently and equiv MP/RPM combination at altitude might be less than, more than, or equal sea-level power at the same MP/RPM combination. Between the (substantially) higher inlet air temperature, decreased cooling due to thinner air flow over the cylinders, and the ability to maintain very long, high-power climbs, it's no wonder turbo'd engines eat cylinders routinely. The stock turbo Arrow system is particularly bad... throttling full boost at the inlet? Pretty stupid to compress the intake only to throw away most of it. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
This is sort of OT, but the new Aviation Consumer this month has an
article on an SMA diesel installed in a C182. The SMA diesel uses 85" MP on takeoff and pretty much stays there for the entire flight. |
sort of OT?
"Paul kgyy" wrote in message ups.com... This is sort of OT, but the new Aviation Consumer this month has an article on an SMA diesel installed in a C182. The SMA diesel uses 85" MP on takeoff and pretty much stays there for the entire flight. |
| Thread Tools | |
| Display Modes | |
| Ram Conversion Performance Specs? | O. Sami Saydjari | Owning | 2 | May 29th 05 05:37 PM |
| Why turbo normalizer? | Robert M. Gary | Piloting | 61 | May 20th 05 05:33 PM |
| Performance World Class design proposal | iPilot | Soaring | 85 | September 9th 04 10:11 PM |
| Kitfox 7/Rotax 914 Performance Questions | Jim Carriere | Home Built | 2 | January 22nd 04 05:55 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
