Why are non precision approaches not lined up?
Old October 6th 05, 10:04 PM
Steven P. McNicoll
"Matt Whiting" wrote in message
news
No, the VOR is not on the runway centerline. It is several hundred feet
off to the side of the runway. Why they didn't use the runway heading for
this approach I don't know, but it could be for noise abatement,
obstruction clearance, or other reasons.
If they did that the MAP would be several hundred feet off to the side of
the runway.
Old October 7th 05, 12:25 AM
Matt Whiting
news
the runway.
True, but the MDA at ITH is something like 700' so you'd still be a long
way from the runway when you broke out. I doubt that a couple of
hundred feet of offset would be a big deal. That may be the reason, but
I'm guessing there are other factors in play as well.
Matt
Steven P. McNicoll
"Greg Farris" wrote in message
Nope - Look at the VOR 14 approach to ITH (Ithaca New York - Just
grabbed the book and picked that one by chance). The VOR is on the
centerline, the runwya heading is 144.6° and the VOR approach is 133°.
When you break out, you have to turn 11.6° right to land. I don't see why
they
couldn't have published it right on the 145° radial.
You're apparently looking at the wrong airport. If you look at the plate
for the VOR RWY 14 approach at ITH you'll see that the VOR is not on the
extended runway centerline. Here's a link to the plate:
http://www.myairplane.com/databases/.../00779VG14.PDF
Old October 8th 05, 12:59 PM
Paul Lynch
Sure are a lot of micrometers measuring something that is cut with a
chainsaw. If you consider the maximum allowable error that is allowed for
VOR receivers and then plot that allowable error plus some safety factor you
would most likely see an obstacle that the approach designer has to
consider. It is even worse for NDBs.
Paul
In article . net,
says...
Because the navaid is not on the extended runway centerline.
When
you break out, you have to turn 11.6° right to land. I don't see why they
GF
Old October 6th 05, 08:16 PM
John R. Copeland
"Steven P. McNicoll" wrote in message =
ink.net...
=20
"Greg Farris" wrote in message=20
The title just about says it - I've always wondered WHY many
non-precision approaches (not talking about LOC only here, but VOR,
VOR/DME, NDB etc) are not lined up with the runway heading. Sometimes =
it
looks as though the approach desginers have gone out of their way to
make sure the non-precision approach is just a few degrees off - as =
if
to say - "look stupid - this is not a precision approach . . ." But =
if
this were so, then we would have to wonder why SOME of these =
approaches
ARE lined up and straight-in. I'm surev there's a simple explanation
that will be pointed out here.
=20
Because the navaid is not on the extended runway centerline.=20
=20
Furthermore, those alignments usually are not to the airport reference =
point,
but instead cross that centerline somewhere near the approach end of the =
runway,
just far enough out to turn and land if the runway environment comes =
into view.
Old October 6th 05, 08:07 PM
Brad Zeigler
VOR/DME, NDB etc) are not lined up with the runway heading. Sometimes it
make sure the non-precision approach is just a few degrees off - as if
to say - "look stupid - this is not a precision approach . . ." But if
this were so, then we would have to wonder why SOME of these approaches
thanks,
G Faris
There are numerous reasons. Off field navaids often serve serveral roles in
both the enroute and approach environment for several airports. On field
navaids may not be straight in as the approach coarse must lead to the
runway, and unless the navaid is at the end of a runway, the course would
either be parallel to the extended centerline of the runway, or offset to
intersect with the runway or runway threshold. Finally, obstructions along
the approach path or missed approach may be a fact in offsetting the
approach course. Lastly, air traffic considerations may be a factor,
especially with smaller airports situated close to busy airports.
Old October 6th 05, 08:13 PM
Mark Hansen
thanks,
G Faris
I can think of a couple reasons. First, as other have said, the VOR
will not always be lined-up with the runway.
Secondly, it may be that the approach path has to come in at an
angle to avoid something, like high terrain, housing communities,
etc. (so they may have placed the VOR off center to facilitate
that).
Also, you shouldn't think of the difference between precision and
non-precision approaches as being lined-up or not with the runway.
Precision approaches are those that provide vertical guidance. Non-
precision approaches do not. That's the difference.
The fact that the typical precision approach uses a localizer which
is lined up with the runway (because the antenna is situated at the
field) does not make the approach 'precision' - the fact that it
provides vertical guidance does.
Mark Hansen, PP-ASEL, Instrument Airplane
Sacramento, CA
Old October 6th 05, 08:27 PM
Stan Gosnell
Greg Farris wrote in
it looks as though the approach desginers have gone out of their way
to make sure the non-precision approach is just a few degrees off - as
if to say - "look stupid - this is not a precision approach . . ." But
if this were so, then we would have to wonder why SOME of these
approaches ARE lined up and straight-in. I'm surev there's a simple
explanation that will be pointed out here.
The term 'precision approach' refers to having vertical guidance (a
glideslope), not to the runway alignment. A precision approach does
have to be aligned relatively closely, but not precisely. I can't
recall the exact number of degrees off the top of my head, but it's not
exact. Even if a non-precision approach is perfectly aligned with the
runway, it's still a non-precision approach, because there is no
glideslope. An ILS without a glideslope, which becomes a localizer
approach, is a non-precision approach.
Regards,
Stan
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." B. Franklin
Old October 6th 05, 10:18 PM
Dave Butler
exact.
Here's an example of a precision approach that's not aligned with the runway,
the LDA Rwy 6 at ROA, Roanoke, VA. Terrain appears to be the motivation for the
misalignment.
http://www.myairplane.com/databases/.../00349LDA6.PDF
GPS/WAAS VNAV approaches and runway length Nathan Young Instrument Flight Rules 8 October 25th 04 06:16 PM
Closest SDF, LDA and LOC-BC Approaches Andrew Sarangan Instrument Flight Rules 17 June 5th 04 03:06 PM
The new Instrument Rating PTS C J Campbell Instrument Flight Rules 7 May 27th 04 12:35 AM
FS2004 approaches, ATC etc henri Arsenault Simulators 14 September 27th 03 12:48 PM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 01:43 PM
