Eric:
My glider uses three 12V 7 amp/hr batteries. At least two, and usually all three, have to be recharged after every flight. (One of the three operates the transponder alone.) I often don't have the time to charge each battery one at a time between flights on consecutive days. (And at contests I will have 6, if not 9, batteries!) I wanted to find out if I can charge them three at a time before I invested in two more chargers. -ted/2NO |
I would only charge SLA batteries in parallel if they were also
discharged in parallel. Otherwise you run the risk of substantial currents flowing from the battery with a higher to charge to the other. You could use 3 lamp timers so you didn't have to attend the things. Tom Seim 2D DG-400 |
Ack! Thanks everyone. Very informative.
Now if I can figure out why my water pump slows from 2 gallons a minute on startup to a quarter gallon a minute a short time later ... ~ted/2NO |
Eric Greenwell wrote:
wrote: Can I charge 2 or more batteries simultaneously, connected in parallel? (Assuming all batteries are the same type and approximately the same age.) What situation prompted you to ask this question? A better answer can be provided with that knowlege. I know that this is an old thread but I thought that I would pose this question. First some history: the longest lasting glider battery that I ever had was 6 years and I only replaced it because I believed that it HAD to quit any minute due to its age. It was a 14 volt SLA that I built from two 2.0 volt 4AH batteries in parallel and one 7AH battery in series with the pair. The charger was a 12 volt gel cell charger. I never charged for a period longer than overnight. Now the question...is it possible that undercharging e.g. charging a 14 volt battery with a 12 volt charger is responsible for the longevity of the battery? BTW, I built another, same way, 4 years ago and it is doing fine. Paul |
P. Corbett wrote:
Eric Greenwell wrote: wrote: Can I charge 2 or more batteries simultaneously, connected in parallel? (Assuming all batteries are the same type and approximately the same age.) What situation prompted you to ask this question? A better answer can be provided with that knowlege. I know that this is an old thread but I thought that I would pose this question. First some history: the longest lasting glider battery that I ever had was 6 years and I only replaced it because I believed that it HAD to quit any minute due to its age. It was a 14 volt SLA that I built from two 2.0 volt 4AH batteries in parallel and one 7AH battery in series with the pair. The charger was a 12 volt gel cell charger. I never charged for a period longer than overnight. Now the question...is it possible that undercharging e.g. charging a 14 volt battery with a 12 volt charger is responsible for the longevity of the battery? BTW, I built another, same way, 4 years ago and it is doing fine. Generally, undercharging lead acid batteries leads to shorter life, not longer. Six years is not uncommon for a SLA battery, though it's capacity will be diminished. If it's reduced capacity was still adequate for your flights, you wouldn't know how good it was unless you tested it for it's actual capacity. Now, I have to ask: why are you using a 14 volt battery? If it's for your radio, what radio do you have? You may not need 14 volts at all. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
P. Corbett wrote: Eric Greenwell wrote: wrote: Can I charge 2 or more batteries simultaneously, connected in parallel? (Assuming all batteries are the same type and approximately the same age.) What situation prompted you to ask this question? A better answer can be provided with that knowlege. I know that this is an old thread but I thought that I would pose this question. First some history: the longest lasting glider battery that I ever had was 6 years and I only replaced it because I believed that it HAD to quit any minute due to its age. It was a 14 volt SLA that I built from two 2.0 volt 4AH batteries in parallel and one 7AH battery in series with the pair. The charger was a 12 volt gel cell charger. I never charged for a period longer than overnight. Now the question...is it possible that undercharging e.g. charging a 14 volt battery with a 12 volt charger is responsible for the longevity of the battery? BTW, I built another, same way, 4 years ago and it is doing fine. Generally, undercharging lead acid batteries leads to shorter life, not longer. Six years is not uncommon for a SLA battery, though it's capacity will be diminished. If it's reduced capacity was still adequate for your flights, you wouldn't know how good it was unless you tested it for it's actual capacity. Now, I have to ask: why are you using a 14 volt battery? If it's for your radio, what radio do you have? You may not need 14 volts at all. Eric I have a Terra 720 and the manual states that the radio wants 13.75 VDC. Ironically, I don't talk on the radio much because the many conversations going on are distracting to me so I leave it off most of the time. On a typical flight, it sees a 25% duty cycle. But if I need it, I want it to work well, thus the 14 VDC. Overkill? What do you think? Paul |
These battery threads are almost as entertaining as the PW 6/2-33
threads. How about addressing the "memory" issue? Myth or reality? Thank god the season is upon us here in the NE USA. I'm looking forward to trying out my newly purchased gizmos (PDA GPS etc). I just hope the batteries work. Mike |
P. Corbett wrote:
Eric Greenwell wrote: Now, I have to ask: why are you using a 14 volt battery? If it's for your radio, what radio do you have? You may not need 14 volts at all. Eric I have a Terra 720 and the manual states that the radio wants 13.75 VDC. Ironically, I don't talk on the radio much because the many conversations going on are distracting to me so I leave it off most of the time. On a typical flight, it sees a 25% duty cycle. But if I need it, I want it to work well, thus the 14 VDC. Overkill? What do you think? Paul That radio is old enough that 14 volts might be a reasonable strategy. The TPX 720 handheld I'm familiar with works well on 12 volts, but I don't know if that would apply to the panel mount 720. Maybe some pilots out there have experience with a 720 on 12 volts and can tell us how well it worked. -- Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA www.motorglider.org - Download "A Guide to Self-launching Sailplane Operation" |
Battery Question | [email protected] | Soaring | 19 | September 15th 05 01:38 AM |
New Battery -- thanks for the recommendation | Jay Honeck | Owning | 28 | July 10th 05 07:20 PM |
RG Battery Charger by Jim Weir in Kitplanes | Kevin O'Brien | Home Built | 4 | January 6th 05 01:19 AM |
