#11
![]() "Wayne Paul" wrote in message ... "Vaughn" wrote in message ... "COLIN LAMB" wrote in message nk.net... 3. If I am in a glider connected to an airplane by a rope, and the pilot ot the airplane controls where I go... I would really like to put you in the front seat of a glider and let you try it. You will instantly find that the "pilot ot the airplane controls" does NOT control where the glider goes. The glider does not willingly and automatically follow the tow plane like a trailer follows a car. The experience is much the same as formation flying, if you wish to remain connected to the airplane, you must very precisely coordinate stick and rudder to follow. As a glider instructor, I have watched many an experienced airplane pilot sweat as they try it for the first time. Like riding a bicycle, once the skill is learned it becomes automatic. Vaughn If flying on tow isn't a big enough challenge, landing on tow should be a lot of fun!! The procedure has been discussed on rec.aviation.soaring in the unlikely event that both the tow plane and the glider have release failures. Some believe that we should actually practice doing it. Wayne HP-14 N990 "6F" http://www.soaridaho.com/ Heh. I actually did a touch and go under tow as a student pilot with an instructor. It was a weird feeling, making a much longer, much flatter approach than usual. Not much I could do about it. Dropped to low tow on final, touched down first, waited for the towplane to touch down, Then he added power and we did another pattern tow, where I actually released. Tim Ward |
Wayne Paul wrote:
If flying on tow isn't a big enough challenge, landing on tow should be a lot of fun!! The procedure has been discussed on rec.aviation.soaring in the unlikely event that both the tow plane and the glider have release failures. Some believe that we should actually practice doing it. I, for one, believe we should actually practice doing it. I was trained to do it, I've done it 3 times, and I don't see a problem. Yes, I did it all 3 times with less than 25 hours in gliders and less than 100 hours in airplanes... and I am certainly NOT God's gift to aviation... they taught me and I learned! I would MUCH rather land on tow than attempt to break the rope after a double release failure AND a double weak link failure (which is one way to get into this situation). Landing on tow was a non-event. Best regards, Jer/ "Flight instruction and mountain flying are my vocation!" Eberhard -- Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO CELL 970 231-6325 EMAIL jer'at'frii.com WEB http://users.frii.com/jer/ C-206 N9513G, CFII Airplane&Glider, FAA-DEN Aviation Safety Counselor CAP-CO Mission&Aircraft CheckPilot, BM218 HAM N0FZD, 234 Young Eagles! |
In article .com,
"Bret Ludwig" wrote: There were plans in Popular Mechanix for floating primary gliders in the old days, the big attraction was you could "fly" with no license. It was illegal to pull the release except in an emergency, but since neither the nonaircraft nor the nonpilot were licensed, no one including the FAA much cared. I think you mean this one; http://vulatalk.zdwebhosting.com/pic...aqua/Page.html The "bigosh" was a tow behind a pickup land version; http://vulatalk.zdwebhosting.com/pic...ders/Page.html DocFont |
I read a story about bush flying in a Cub, where the pilot would lower
a bucket out the window on a rope. He would then go into a constant tight banked turn, with one wing of the Cub pointed at the bucket. He could spiral down, and place the bucket stationary on the ground, so a person on the ground could drop off or retrieve small objects. By extension, with a long enough rope you should be able to fasten a rope to the ground, take off, and then fly in circles around the end of the rope. Repeat until you get dizzy and crash. I don't want to try it. But I want to watch. Dave www.davewilson.cc |
Matt Whiting wrote:
wrote: I read a story about bush flying in a Cub, where the pilot would lower a bucket out the window on a rope. He would then go into a constant tight banked turn, with one wing of the Cub pointed at the bucket. He could spiral down, and place the bucket stationary on the ground, so a person on the ground could drop off or retrieve small objects. I've heard some pretty wild urban legends, but this has to be one of the best. Matt It's not an urban legend. It's been done for decades. The bucket never reaches the ground, but a man can drop someing in or take something out when it gets to shoulder height. There's a picture of it being done in a mid 1960s National Geographic. There was a discussion about it in rec.aviation.military a year or two ago. Dan, U.S. Air Force, retired |
In article 14h3f.1550$vE5.742@lakeread03,
"Dan, U.S. Air Force, retired" wrote: Matt Whiting wrote: wrote: I read a story about bush flying in a Cub, where the pilot would lower a bucket out the window on a rope. He would then go into a constant tight banked turn, with one wing of the Cub pointed at the bucket. He could spiral down, and place the bucket stationary on the ground, so a person on the ground could drop off or retrieve small objects. I've heard some pretty wild urban legends, but this has to be one of the best. Matt It's not an urban legend. It's been done for decades. The bucket never reaches the ground, but a man can drop someing in or take something out when it gets to shoulder height. There's a picture of it being done in a mid 1960s National Geographic. There was a discussion about it in rec.aviation.military a year or two ago. Dan, U.S. Air Force, retired It is also the principle of gunships, which do the same thing, only with guns pointed out the side of the plane. The early gunships used a crude sight taped or painted on the side window. |
("Matt Whiting" wrote)
I read a story about bush flying in a Cub, where the pilot would lower a bucket out the window on a rope. He would then go into a constant tight banked turn, with one wing of the Cub pointed at the bucket. He could spiral down, and place the bucket stationary on the ground, so a person on the ground could drop off or retrieve small objects. I've heard some pretty wild urban legends, but this has to be one of the best. Interesting rope and bucket discussions in rec.aviation.student (2001). http://makeashorterlink.com/?M3D8128FB #1 (same link as below ...wait for it) http://makeashorterlink.com/?L3F8138FB #2 (same link as below ...wait for it) http://groups.google.com/group/rec.aviation.student/browse_frm/thread/1f9d8990c6ae73b2/b9eece1a17758fd5?q=rope+%2B+bucket&rnum=2&hl=en#b9 eece1a17758fd5 http://groups.google.com/group/rec.aviation.student/browse_frm/thread/70991ad51db474e9/4c185d49d884a830?q=rope+%2B+bucket&rnum=3&hl=en#4c 185d49d884a830 Montblack |
Dan, U.S. Air Force, retired wrote:
Matt Whiting wrote: wrote: I read a story about bush flying in a Cub, where the pilot would lower a bucket out the window on a rope. He would then go into a constant tight banked turn, with one wing of the Cub pointed at the bucket. He could spiral down, and place the bucket stationary on the ground, so a person on the ground could drop off or retrieve small objects. I've heard some pretty wild urban legends, but this has to be one of the best. Matt It's not an urban legend. It's been done for decades. The bucket never reaches the ground, but a man can drop someing in or take something out when it gets to shoulder height. There's a picture of it being done in a mid 1960s National Geographic. There was a discussion about it in rec.aviation.military a year or two ago. Maybe I'm not getting the full picture here, but it seems at first blush that this would require the Cub to be able to fly a zero radius turn. Matt |
Orval Fairbairn wrote:
In article 14h3f.1550$vE5.742@lakeread03, "Dan, U.S. Air Force, retired" wrote: Matt Whiting wrote: wrote: I read a story about bush flying in a Cub, where the pilot would lower a bucket out the window on a rope. He would then go into a constant tight banked turn, with one wing of the Cub pointed at the bucket. He could spiral down, and place the bucket stationary on the ground, so a person on the ground could drop off or retrieve small objects. I've heard some pretty wild urban legends, but this has to be one of the best. Matt It's not an urban legend. It's been done for decades. The bucket never reaches the ground, but a man can drop someing in or take something out when it gets to shoulder height. There's a picture of it being done in a mid 1960s National Geographic. There was a discussion about it in rec.aviation.military a year or two ago. Dan, U.S. Air Force, retired It is also the principle of gunships, which do the same thing, only with guns pointed out the side of the plane. The early gunships used a crude sight taped or painted on the side window. Not, not the same at all. The bullets aren't going straight down, they are going at some angle to the ground and landing well away from the airplane. How do you get the bucket and rope to stay at an angle to the airplane and follow the same path the bullets would follow. I'm still not getting the physics of how this would work. Matt |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
The Vietnam Memorial Wall | Ed Rasimus | Military Aviation | 40 | June 29th 04 12:27 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
A wall that cages justice | Bill | Military Aviation | 2 | February 23rd 04 10:36 PM |
