New Version of Tasman Variometer Firmware Available
Old October 13th 05, 07:25 PM
Martin Gregorie
On Thu, 13 Oct 2005 14:21:50 +0000, Paul Remde wrote:
Hi Paul,
Here's what I find confusing:
- the PK312 aux. power supply still doesn't appear on the mfr's web site
other than as a block on the installation diagram. No web site, not even
yours, has any details of its internal functions, battery type or price.
- the specs. refer to different 'battery low' alarm points: as the PK312
apparently connects to the vario by the same two wires as the main battery
I'd like to know just how the Vario knows which battery it is being
supplied by.
I very much like the idea of a solid state device without a mechanical
display; I just wish I knew more about the PK312.
Hi Martin,
The use of a 9 V battery for backup power for the Tasman is shown in the
installation manual he
http://www.tasmaninstruments.com/doc...allation_b.PDF
I have recently asked the manufacturer to verify as what voltage the
audio stops functioning. That point is a little unclear in the manuals.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"Martin Gregorie" wrote in message
news
On Thu, 13 Oct 2005 11:54:22 +0200, Bruce wrote:
We looked at the B40 vs Tasman recently for our club ships. In the end
we decided on the Tasman because it has no moving parts, and has the
built in
averager.
I've flown with a Tasmin once and liked it: the new vario down noise
sounds like an improvement.
The major advantage of the B.40 is its backup 9v battery: I think its
really important that a backup vario can operate with a dead main
battery. The Tasman literature mentions the possibility of using a
backup battery too, but its either well-hidden or absent from the
installation and user manual. I couldn't find a clear reference in the
price list either despite it being quoted as an option.
Do you use backup batteries with your Tasmans?
BTW, I have an SDI C4 that I intend to retain as my main vario.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
org |
Old October 13th 05, 09:57 PM
Paul Remde
Hi Martin,
Those are very good questions. Your timing is impeccable. Just this
morning I e-mailed similar questions to the manufacturer, added the PK312
power pack to my web site, and ordered some of the units for my stock. I'll
know more about it soon and will respond to this better at that time.
It is my understanding that the PK312 is a battery box for a single 9V
alkaline battery. I'm assuming that it must connect to the vario using a
different + wire than is used for the 12V battery. A single 4-wire phone
style cable is used for 12V power and common, 9V power and the speaker. If
they didn't use separate wires for 9V and 12V power the 9V battery would be
damaged by 12+ volts.
The biggest question I have is at what voltage the audio stops functioning.
It is unclear to me in the manual.
The Tasman has been a very popular product. I have not received any
complaints about the units I've sold. I also like that it has an averager
display on the face of the unit.
Good Soaring,
Paul Remde
news
Hi Paul,
supplied by.
Hi Martin,
Good Soaring,
Paul Remde
news
built in
averager.
org |
org |
Old October 14th 05, 03:45 AM
Mike Borgelt
Hi Martin
We looked at the B40 vs Tasman recently for our club ships. In the end we
decided on the Tasman because it has no moving parts, and has the built in
averager.
The B40 has always had a built in averager. Just push the button on
the front. The button even has a remote circuit you can use to to
mount it on the stick etc. Digital averager also available and you can
put that up close to your line of sight or just above the ASI.
So far we are extremely happy with the Tasmans, and I can recommend them and
their service. They contacted us directly about the firmware upgrades, and
shipped the chips to us at their cost to upgrade the varios we have.
The Borgelts are also outstanding instruments, and I may consider moving up to a
B50 in my single seater. For now the V1000M gives me such good information I
doubt I would benefit from the B50. If I ever get my PDA installed this might
change.
Just to clear up any confusion , the B50 and Tasman are not
comparable. The B40 and Tasman are somewhat comparable as neither has
an airspeed sensor, unlike the B50 which does.
Having an airspeed sensor lets you compute the expected sink rate at
any given airspeed for display of netto(airmass) vario or relative
netto (see our website for article on Basic Sailplane Instruments
which explains these terms for anyone not familiar with them and tells
you why they are advantageous) as well as Macready speed to fly
information in simplified "fly faster/fly slower" format and also
provides True Air Speed(TAS) information to glide computers which
gives useful information like real time wind component when used with
the GPS groundspeed.
I am surprised that the Tasman audio was the way it was for so long.
We had that in the B10 vario in 1978 and changed it at customer
request within a few months to the present system and have kept that
ever since for climb/sink mode.
For now my setup is a winter mechanical vario - no power needed to soar.
Given the proliferation of electronic equipment in sailplane
cockpits(computers/GPS/loggers, electronic varios) you really want an
assured 12 volt power supply anyway. This is easy to achieve with two
batteries used intelligently and for the paranoid a back up supply for
the standby vario. (it isn't bad to be paranoid about this)
Putting capacity flasks and mechanical vane type varios in the TE
system is a bad idea for many reasons particularly the effect on
responses of any electronic pressure sensor based instruments. These
effects can be mitigated by splitting the TE line back at the back of
the seat pan or further aft and running two TE lines to the instrument
panel. I still see installations where this has not been done. The
only time you can do without this is with two pressure sensor type
instruments. Getting rid of mechanical instruments makes installation
easier. I haven't had a mechanical vario since 1979 or a capacity
flask since 1983. I've never run out of vario (except when I've had to
pull mine out of the panel to sell to someone in a hurry - one B40
lasted exactly 30 minutes after installation).
V1000M set to rapid response + 20s average. It is worth having just for the
average. No problems with legibility on the LCD screen, in bright sunlight, and
with/without polarising glasses.
We looked at this for the planned B30 system in 1986. That never got
beyond the planning stage. as I considered a display resolution for
the vario pointer of 0.4 knots was just too terrible. The Tasman has 1
knot I believe.
LCD's do make for a cheap display though.
The automotive industry has come to our aid with the stepper motor
driven pointer. These are used in all the BMW's, Rolls Royce etc cars.
Interesting that the auto industry hasn't embraced LCD pointers.
By the way - the firmware upgrades are one of the things that decided us on the
Tasman rather than the B40. You get an instrument with virtually unlimited
development capability. No mechanical stuff you can't change.
You are very restricted by the crude resolution of the display and the
lack of airspeed sensor. The Tasman, like the B40, is just a simple
TE vario with audio and averager. There isn't really much you can do
with that which is why we have continued that in to the new B400 which
is shorter than the B40 it replaces, uses a stepper driven pointer
with extremely high resolution, has the same kind of averager as the
B40 with remote push button and optional remotely mounted full time
digital averager display now available in two sizes and a new optional
"competition " climb audio (you can still select classic B40 style)
and a green LED to tell you when you are climbing faster than the
current running average i.e. "things are getting better" which is also
given by the audio in "competition" mode.
We expect to ship the first B400's next week.
The B50 has been replaced by the B500 which is now shipping in small
quantities (and many thanks to our beta testers for your faith and
patience) and we're ramping up the production rate.
The B500 is an advanced vario system with airspeed sensor and has
plenty of room for later expansion as it was designed that way.
Software upgrades will be by download from our website and
customisation is by hooking it to a PC.
Check it out (and the Basic Instruments article and others) on the
website.
www.borgeltinstruments.com
Mike Borgelt
Old October 14th 05, 06:25 AM
Bruce
From unfortunate personal experience the audio cuts out at around 9.5V, and the
whole plot dies somewhere 8V. Quite outstanding - my .
Note to self - NEVER fly with a suspect battery again.
Cheers
Bruce
Paul Remde wrote:
Hi Martin,
I have recently asked the manufacturer to verify as what voltage the audio
Good Soaring,
Paul Remde
news
in
averager.
really important that a backup vario can operate with a dead main battery.
The Tasman literature mentions the possibility of using a backup battery
too, but its either well-hidden or absent from the installation and user
manual. I couldn't find a clear reference in the price list either despite
org |
Bruce Greeff
Std Cirrus #57
I'm no-T at the address above.
Old October 14th 05, 07:38 AM
Bruce
Hi Mike
I have the highest respect for your knowledge and the products you make. My
apologies if I was not clear in my explanation of our reasoning.
Hi Martin
averager.
No argument, we just like the always on averager. And that we can thus see both
instantaneous and average. This is particularly useful with the second seat
repeater. (With the Tasman we know that both pilots are seeing the same
information) Also had a safety consideration , in that there is no need to get a
finger on a remote button - therefore less time with eyes in the cockpit.
change.
My apologies if I was unclear. The B50 is clearly in a different class - and
provides things that the Tasman cannot. I did consider the two for my own
installation, and decided on the Tasman for the sake of simplicity and
commonality with the club trainer.
Conversely, having just flown a contest for the first time I can see the
advantage of a more advanced vario like the B50. The reason I would probably not
benefit from the more advanced instrument is due to lack of ability to exploit it.
Second thing we did with the Tasman's was to turn the "down" sound off...
I agree it is not ideal, but with my TE pipes seperated under the seat the
Tasman and Winter work very well together.
knot I believe.
LCD Pointers no - but LCD information panels are popular. For the obvious
reasons, flexibility (what you display), economy, reliability and low
maintenance. The only serious restriction in the Tasman's design to me is that
there is no USB connector. Standardising on USB for power and data in glider
cockpits would be really good. The simplicity of operation and flexibility would
be outstanding. To my knowledge only LX Navigation have done this so far.
Now that is an interesting one - I also find the coarse visual resolution of the
Tasman less useful than the winter's precise sweep needle. However, we actually
chose this intentionally as we wanted to teach the student to stop looking at
the needle. The audio is set to 1/10 m/s discrimination, and that works - look
out and listen - a glance at the average every now and again is all you need.
website.
Mike Borgelt
As I commented, which instrument you choose is partly personal prefference,
partly the use you would want to put it to. As a primary vario for training use
the Tasman works very well and we anticipate many years of solid state
reliability. Now that my single seater is getting to do some more serious cross
country work, the appropriate instrumentation may change. At the moment I simply
use what the Tasman and LX20 are telling me to make decisions on how fast to
fly. Great to hear about the B500 - more options.
Bruce Greeff
Std Cirrus #57
Old October 17th 05, 06:02 AM
309
Default New Version of Tasman Variometer Firmware Available
Paul,
Thanks for posting the availability of the new firmware...I'm not sure
I would have discovered it otherwise, and I do intend to perform the
upgrade.
I also appreciate the informative thread that was inspired by your
post, despite the protestations of the evangelists. I believe I've
learned a limitation of my relatively new Tasman vario, but am pleased
with it nonetheless (not a paid endoresement...and I bought my Tasman
from someplace other than Cumulus, Craggy, or W&W, so there! BTW, I AM
a customer of all three...I share my wealth, just ask the tow pilots).
I think the Tasman IS an improvement over my Cambridge Mk II (which
works, and I'd ship it to the highest bidder...oops, that's not
allowed, is it???).
I will say -- at the risk of inviting a serious flaming -- keep up the
good work! ;-)
-Pete
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
