#11
![]() Anthony W wrote: wrote: What about the 3rd option from the Tony Bengals books, covering the wing with thin fiber glass cloth and resin? Just in case anyone wants to find his books its _Tony Bingelis. Fiberglass wings are not fabric wings. You might as well say, hey, why not cover them with aluminum sheet metal. Also, I _think_ fiberglass wings will be heavier. I may have spelled his name wrong but from your answer, I don't think you've read his books or at least this part. I have four of his books, and have read parts of each. Which one are your thinking of? Meaning no disrespect to Mr Bingelis, it remains the case that fiberglass wings are not fabric wings. -- FF |
On Thu, 13 Oct 2005 09:13:37 -0700, Smitty Two
wrote: In article , Stealth Pilot wrote: btw dont be beguiled by the semantics. the glue strength doesnt change with the glue area since it is a force per unit area measurement. the glue area directly changes the amount of total force that the rib fabric join can stand. a pound per square inch strength applied to a square inch can hold a pound a pound per square inch strength applied over a square foot can hold one hundred and fourty four pounds. Stealth Pilot Australia I'll bite into this topic from an intellectual curiosity perspective. What are the forces acting on a rag plane that would tug against the rib bond? Source? Direction? Magnitude? How common are such bond failures? What is the cause? Poor surface prep or other application shortcomings? Deterioration of the glue or fabric over time? Other? I'll reply for the other guys benefit. I dont know what you'll read into this :-) glue bonds fail over time from the stress rise at the edge of the joint. air pressure will create a force perpendicular to the surface. have a look in a text at one of the manometer photos of a wing section under test to get an idea of the pressure distribution. the predominant cause of failure in fabric bonds is the reversing loads created by turbulence from the slipstream off the prop. outside of the slipstream competently bonded fabric seldom fails. the fabric bond fails from the edge and slowly the failure creeps inward across the joint. ribstitching in the area of the slipstream works to correct the problem because it doesnt have stress risers occurring at the edges of the thread. my method of checking the stits fabric on my tailwind is to look inside the tailcone out in the bright sunlight and pick the areas where the uv opaquing was poorly done. I then make the "bird" with one hand and walk along those areas banging the finger into the fabric as hard as my hand will allow. If I ever get a puncture I'll initially repair it. If I get areas of punctures then it is in for a refabric. I've wanted to refabric the aircraft for a few years now but the stits seems to have an infinite life. I cant detect any deterioration other than in the visual appearance of the paint. not a complete disertation but then the other guy wasnt asking much. Stealth Pilot |
![]() Stealth Pilot wrote: On 13 Oct 2005 20:26:10 -0700, wrote: Anthony W wrote: wrote: What about the 3rd option from the Tony Bengals books, covering the wing with thin fiber glass cloth and resin? Just in case anyone wants to find his books its _Tony Bingelis. Fiberglass wings are not fabric wings. You might as well say, hey, why not cover them with aluminum sheet metal. Also, I _think_ fiberglass wings will be heavier. I may have spelled his name wrong but from your answer, I don't think you've read his books or at least this part. I have four of his books, and have read parts of each. Which one are your thinking of? Meaning no disrespect to Mr Bingelis, it remains the case that fiberglass wings are not fabric wings. are you sure? razorback is a fabric system that uses fibreglass. Stealth Pilot Thanks. With a little googling I learned that Razorback is fiberglass cloth filled with butyrate dope. I daresay that is significanlty differant from fiberglass cloth filled with epoxy or polyester resin. Whether or not that makes a razorback wing a fiberglass wing or a fabric wing would seem to be a matter of interpretation. I guess I'd call it a hybrid. Like Anthony W, I have not built a plane. Last night I went through Bingelis' books and found that the fiberglass section of the yellow book (Sportplane Construction Techniques is the title IIRC) dealt with gas tanks, wheel pants, cowls and such. He didn't really address wing covering in that book. In his blue book (Sportplane Builder) he has a Chapter near the end on Dacron, but Chapter 5 is 'Fiberglass Tips' and has a section 'Fiberglass Your Bird'. This discusses using lightweight fiberglass cloth and resin to cover a plywood fuselage, similar to light boat construction. (BTW, there is a boatbuilding technique called 'stich and glue' which looks to be adaptable to stressed skin construction.) He says he first used the material to cover the tailfeathers of an Emeraude, are those skinned with plywood? Looking at photos on the net it appears that some rudders are, and some aren't. I would not rely on the book covers being the same color with each printing, nor on my searching late last night being thorough. But I don't think he suggests fiberglass cloth and resin over ribs with nothing else underneath. ISTM that the cloth would sag between the ribs and unlike the dope in the razorback system, the curing resin would not draw it tight, unless you found a resin that would shrink. Hmm, doesn't some poylester resin shrink when it cures? -- FF |
![]() wrote: On 12 Oct 2005 14:33:47 -0700, wrote: I was reading some information on Fisher Celebrity builders websites and saw that one builder did not like the idea of glueing the fabric to the ribs as per the plans. The ribs on the Celebrity are very thin and he didn't think there was enough glue area for a satisfactory bond, so he rib stitched. The Celebrity is a biplane with a top speed of 95 mph, right? Has it been a problem? Have any of the Celebrity's that had the fabric glued had the fabric come unstuck? Ever? I vaguely remember reading in the FAA/NTSB archive about such an incident. It was a while ago, so I may be a bit off. What I remember was that the pilot was killed on impact and apparently he was aware of some minor seperation and continued to fly the aircraft until it failed catastrophically. Might have been another bird, but I think it was a celebrity. I'm not 100% sure though. You might try searching the accident database for the celebrity if you haven't already. -Matt If not, why should it be considered an issue? On the other hand, if the guy just cannot live with attaching the fabric with glue, even if nothing bad has ever happened, he can certainly rib stitch. It won't hurt anything but his wallet, a bit, and add to the length of time building. Corky Scott |
![]() wrote: wrote: On 12 Oct 2005 14:33:47 -0700, wrote: I was reading some information on Fisher Celebrity builders websites and saw that one builder did not like the idea of glueing the fabric to the ribs as per the plans. The ribs on the Celebrity are very thin and he didn't think there was enough glue area for a satisfactory bond, so he rib stitched. The Celebrity is a biplane with a top speed of 95 mph, right? Has it been a problem? Have any of the Celebrity's that had the fabric glued had the fabric come unstuck? Ever? I vaguely remember reading in the FAA/NTSB archive about such an incident. It was a while ago, so I may be a bit off. What I remember was that the pilot was killed on impact and apparently he was aware of some minor seperation and continued to fly the aircraft until it failed catastrophically. Might have been another bird, but I think it was a celebrity. I'm not 100% sure though. You might try searching the accident database for the celebrity if you haven't already. That sounds pretty much like what happened to Steve Wittman. He put off fixing the problem until after he got to Oshkosh. -- FF |
![]() wrote I vaguely remember reading in the FAA/NTSB archive about such an incident. It was a while ago, so I may be a bit off. What I remember was that the pilot was killed on impact and apparently he was aware of some minor seperation and continued to fly the aircraft until it failed catastrophically. Might have been another bird, but I think it was a celebrity. I'm not 100% sure though. You might try searching the accident database for the celebrity if you haven't already. I am not an authority on the facts, so I didn't bring up the name of the incident that I was thinking of, but since nobody else with all of the facts has, I will. Steve Whitman(sp?), namesake of the OSH airport, racer, and designer of the Tailwind (among others) was killed in such an unbonding incident. I don't recall the details, but I recall that he did something wrong, or against other's recommendations. The planes he designed were much higher performance crafts than what the OP was asking about. I'm sure he can google the details. -- Jim in NC |
Any Info on Hipec? No Rib Stitching? | bling bling | Home Built | 5 | November 19th 03 09:24 PM |
