carb ice experience
Old October 25th 05, 02:36 AM
Tony
Default carb ice experience
I had one experience that suggests carb ice makes the mixture too rich.
It was in a Mooney Ranger, I flying a VOR approach, pulled on the carb
heat knob and the damned thing just kept pulling out of the panel. It
broke! (Yes, I tested carb heat on the run up, it was fine.)
As luck would have it was to an uncontrolled airport in snow. The
second hand on the clock said look out and see the airport. I looked
and couldn't see a damned thing. Pushed the throttle in to fly the
miss, not much happened. I tried everything to get power back. Landing
light didn't help, raising the gear didn't, neither did prayers. The
one thing left to yank on was the mixture. I leaned it and the engine
began developing a little power, enough to limp to a nearby airport
with an ILS and get down. So leaning helped, which made me think the
mixture was too rich with carb ice.
By the way, if ever you want to overcontrol an airplane, fly down the
glide slope knowing you HAVE to get down, there wasn't enough power to
do anything else. I'm writing this story, so obviously I was able to
keep the needles crossed and got down. Those mountains in eastern PA
have been known to eat airplanes.
I remember that clearly even though it was 40 years ago. I wonder why?
Old October 25th 05, 06:38 AM
Morgans
You remember trying to pull the seat cusion out of your butt crack,
afterwards? g
Old October 23rd 05, 04:27 PM
Dan
Application of carb heat causes a change in rpm's because it changes
the fuel/air ratio.....NOT because there is carb ice. If carb ice is
present, the heated air will hopefully melt the ice and it will then
cause the engine top stutter a little as it goes thru the combustion
process.
If you have carb ice conditions, you can run with full heat on to avoid
the ice formation. However, on the ground, this will by-pass any
filters and you can suck dust into your carb with the dirty air and a
potential for serious engine problems.
In severe low temps, sometimes it requires full carb heat just to get a
close to useable air density for decent fuel/air ratios.
Another trick to stick in your pilots bag of magic is to use the primer
knob if your engine gets starved for carb ice and stops. The primer
system on most carbureted engines bypasses the carb and goes directly
to the intake manifold. Your fuel schematic should show you that. I've
used it a couple of times to keep the engine runing in severe
conditions around the country. The engine will run for a few seconds
then die again so you keep stroking the primer knob to keep it running
until hopefully the heat will come up enough to become effective again.
The addition of a carb heat gauge is worthwhile for most aircraft
(normal aspirated). A periodic carb heat check in the air doesn't hurt
either.
Discuss the situation with your local mechanic and he can explain it
better. If he can't, find a more experienced mechanic!
Cheers and safe flying
Old October 24th 05, 06:31 PM
Brian
What typically happens, and often under the exact conditions you
describe cold humid morning with frost on the ground is that as you
taxi out ice builds up in the carb reducing the RPM. You wil
subconsously keep adding power to keep it running like you want/need to
taxi. Then when you add power for the run up you will position the
throttle farther open than normal to get the 1500 RPM that you need
since the carb is partially iced up. When you add the Carb heat it will
typically drop a bit and then back up to a higher RPM. The RPM Surge
you saw was simple the result of having more ice that you are used to
I see this quite often in the Champs I Fly and even Cessna/pipers
occasionally.
Brian
CFIIG/ASEL
Old October 23rd 05, 04:36 PM
George Patterson
Cub Driver wrote:
Now what was the difference between that experience and the ordinary
one where the rpms drop, then rise back to 1500?
Sounds like you had a lean mixture for some reason. When you hit the heat, the
mix got richer.
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Old October 23rd 05, 04:54 PM
George Patterson
The Selway Kid just mentioned that carb heat application also bypasses the air
filter in most aircraft. IMO, the most likely problem here is a clogged filter.
George Patterson
Old October 23rd 05, 06:51 PM
On cold mornings, using summer mogas (which will have a lower vapor
pressure), the fuel doesn't vaporize as easily in the manifold.
Applying carb heat can sometimes improve this and the RPM will rise a
bit. I use the heat on my A-65 on such mornings.
Dan
Have you ever experienced carb ice with an injector carb? flybynightkarmarepair Home Built 1 January 31st 05 01:48 AM
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Use of Carb Heat John Kirksey Piloting 4 November 30th 04 07:26 PM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
Carb Temperature Gauge fly_the_skies Home Built 6 January 14th 04 03:32 PM
