JRC JHP500 handheld transceiver
Old February 1st 06, 07:20 PM posted to rec.aviation.owning
Default JRC JHP500 handheld transceiver
On Mon, 30 Jan 2006, Greg Copeland wrote:
Be careful when switching to alternate battery technologies. NiCads are
designed to be charged at rates up to 3C while most NiMH are
typically designed to be charged no faster than 1 to 1.2C.
Can you back this up with some documentation? I'm not an expert, just a
relatively well informed user, but this runs counter to everything I've
read. The rule of thumb for most common battery chemistries is C/10 (1/10
the amp-hour rating) for 12 hours. As far as I'm aware there's no way to
safely (that is, without damaging the cells) speed that up significantly
without microprocessor controlled chargers and special waveforms. Even
with those things I doubt it's possible to charge NiCd's or NiMH's
anywhere near as fast as you suggest (20 min. to 1 hour) without severely
shortening their lifespan. Take care of your batteries, and you might
actually get the 1000 charges the manufacturers advertise; abuse them, and
you might get only a dozen or so charges.
In short, get an extra set or two of batteries, charge them slowly, don't
ever overcharge them, and they'll live a lot longer.
Long of the short, if you change battery technologies, make sure you
change chargers too! Otherwise, you may be in for a surprise including
very short battery life, batteries which never hold a full charge, and
maybe even fires.
To the contrary, all information I've ever come across indicates the
charge cycles are identical for NiCd and NiMH. In other words, they're
completely interchangeable, assuming of course that one accounts for the
different capacity when charging. NiCd's are lower capacity (usually
_much_ lower), so generally, NiMH's can be safely charged in chargers
designed for NiCd, but the reverse isn't necessarily true.
For some years I've been using NiMH's in cordless phones designed for
NiCd's, with absolutely no problems. Battery life between charges is much
longer with NiMH's, and lifespan is also much greater because of NiCd's
memory effect.
-Dan
Old October 28th 05, 08:20 PM
Dan Youngquist
On Tue, 25 Oct 2005, Robert M. Gary wrote:
I also have the same unit. Is there any reasonable way to replace the
original rechargable battery?
The battery packs from my Cherokee handheld CB's fit my JHP-520. When
those are worn out, I have AA battery packs that I'll use with NiMH cells.
That seems to me like a much better idea than dedicated battery packs that
are difficult and/or expensive to fix -- individual cells are easily &
cheaply replaceable when they die, and they're interchangeable with GPS,
flashlights, etc.
-Dan
HANDHELD RADIO [email protected] Soaring 22 March 17th 16 03:16 PM
STS AV7600 VOR Handheld aviation transceiver Fastglasair Home Built 1 May 29th 04 12:16 AM
CFI's who use a transceiver or handheld GPS? BoDEAN Piloting 10 April 9th 04 03:03 AM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
