ILS DME strength?
Old November 2nd 05, 11:10 PM
Gerry Caron
Default ILS DME strength?
I haven't checked thru the detail, but FAA Flight Inspection publishes its
data sheets online. You can search for the navaid and display the data from
the last inspection.
http://avnwww.jccbi.gov/datasheet/
Gerry
I have noticed very similar issues with the ILS DME at APA. I either
get nor reading or it bounces all over the spectrum until I get quite
close. Switching over to several other VOR frequencies in the vicinity
creates no such problems. I can only assume that DMEs co-located with
ILSs are significantly less strong.
Garmin 430 and Comm Strength - Solved! Marco Leon Owning 0 December 17th 04 05:15 PM
Garmin 430 and Comm Strength - Solved! Marco Leon Piloting 0 December 17th 04 05:15 PM
If I make it stronger Jdandy Home Built 9 August 30th 04 08:22 PM
Bomber Command strength Drazen Kramaric Military Aviation 2 July 22nd 04 07:09 AM
Tubing strength Ernest Christley Home Built 0 January 16th 04 11:43 PM
