#11
Peter,
You're doing well on your costs on your Bonanza. Around here individual owners are figuring about $150-$200 per hour for their Bonanzas (various versions), although one couple has a 1953 with the 225 hp engine that they manage to run for about $130 per hour. All the best, Rick |
You're doing well on your costs on your Bonanza. Around here individual owners are figuring about $150-$200 per hour for their Bonanzas (various versions), although one couple has a 1953 with the 225 hp engine that they manage to run for about $130 per hour. Rick, in your opinion what accounts for the difference between my costs and the costs that the other owners (excluding the 1953 model) are incurring? -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
My drive would be 2:10 door to door, my flight 1:10 door to door each way.
Michelle Well, don't you commute =to= an airport? That certainly helps. ![]() Joes -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
Thanks.
Flying is just expensive. The Bonanza just flys so nice. "Peter R." wrote in message ... Aluckyguess wrote: I thinking of buying a Bonanaza (currently own a P28-180) How did you come up with the $150 hour cost to fly? My Bonanza burns about 16 gallons of fuel per hour at $4.50 per gallon (average in the northeast US) = $72. Oil consumption right now is negligible, perhaps one quart every 40 hours. My Bonanza is equipped with a turbonormalized IO-520 engine with a 1,700 hour TBO. Having just replaced the over-TBO engine with a factory rebuilt and rebuilt turbo components, I came up with a parts and labor per hour engine reserve of about $21. Insurance is about $3,000/year for a $180k hull (aircraft has TKS system, young engine, new avionics, tip tanks, new paint) and my 300 hours of time in type. Thus, if I fly about 250 hours per year (higher than average given the cruise speed), this works out to $12/hour. Hangar costs me $260/month, which is $12/hour. So what is that so far? $105 per hour. Oil changes, routine maintenance, and annuals have been running about $5000 per year, which is another $20/hour. I don't do much of my own maintenance (oil changes, etc.) yet since time with my family right now is more important than the $200 or so it costs me to have the mech. do it every 40 hours or so. Avionics have been costing me about $2500/year right now (my Garmin GNS430 went TU twice in 14 months, naturally out of warranty both times, for a total cost of around $1200 to have it repaired by Garmin). That works out to $10./hr so now up to $135/hr. It is worth noting that I have only owned the aircraft for about 1 1/2 years so I don't have a lot of data by which to base my maintenance and avionics costs just yet. And finally, as an owner of an aging aircraft, I am facing some of the long term preventative maintenance items since my airframe has about 3900 hours on it, such as replacement of the landing gear braces, aux fuel pump, fuel bladders, etc. I have no idea of the per hour for this, but you can see I am really close to $150 without even factoring in all of these costs. Someone who flies less would easily hit the $150/hour mark, assuming comparable insurance, hangar fees, and annual costs. -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
Peter,
Don't know for sure other than the folks with the older airplane do a lot of the work themselves under the supervision of their mechanic and its fuel burn is less; plus they haven't had too many avionic problems. I keep hearing the others bemoaning various and sundry ills, fuel controllers, avionics, just unsceduled maintenance to the tune of $500 or so each month. All the best, Rick |
Yes I do fly "for a Living" So one door is an airport.
One of the people come into College park which has a Metro stop right off the end of the runway. The other keep an airport car at one end. Michelle Sylvain wrote: Michelle P wrote: Ok so it is getting late. One commutes in a Cessna 150, One in a Cessna 182 and the last in a but you do fly for a living, don't you? i.e., the door to door scenario in your case involves an airport at one end, right? so in that case I can see how it can definitely be advantageous; not sure it works as well for someone who somehow has still to commute to the airport at one end (unless you live in an airport community...), and find a way from the airport to work at the other end... --Sylvain |
I think a big part of the equation is you have to "want" to do it.
Many of the planes we fly today were designed, if not built, at a time when freeways were few and average road speed was probably 35MPH - less in remote areas. Airplane speeds of 110KT were a huge gain, and 180Kt was just phenomenal. The speed of powerful piston singles and twins at the time rivaled that of the day's airliners (DC-3's). People also did shorter pre-flight preparation and accepted risk differently (sounds strange - some will disagree - but I believe this to be true). The extra cost was easily justified because the time savings, even on 100nm trips was prodigious. Today, you'll find many mission statements that "sort of" work. If you've got just the right distance, airplane, weather scenario etc, and poor enough alternative transportation between your destination points you may have an argument. Southern Calif is a contender for this, because of the traffic situation, and certainly it is the spot on the planet with the greatest number of "personal" air commuters. Few mission statements today can honestly argue cost savings - and not that many even amount to much time saved. Factor-in the hassle of not having your car when you get where you're going, plus the fact that weather can ground you at either end (and every incremental step at overcoming this doubles your operating cost) and what you come down to is - for those who do it, there's a whole lot more enjoyment and satisfaction involved in getting somewhere in your plane than in crawling along studying someone else's bumber stickers for a few hours. G Faris |
(answering, in true, egocentric fashion to his own post). . .
there's a whole lot more enjoyment and satisfaction involved in getting somewhere in your plane than in crawling along studying someone else's bumber stickers for a few hours. Or sitting in a crowded airport lounge listening to them make up excuses for why your plane will be delayed another two hours, and wondering if those screaming babies will be in the seat behind you. . . I know many people who say "Flying is work. It tires you out when you're fresh - why would you want, at the end of the day, after being beaten up in meetings, to have to do all that work just to get home, when you can simply board an airliner, get a drink, then a taxi home. . ." It's all about the satisfaction. To me anyway - the satisfaction of the successfully completed return flight cancels out the frustration and boredom of the endless meetings, budgets, schedules etc. The flight itself forces you to push all that crap out of your mind, and concentrate on what you're doing. When I fly others I try to enforce a "no shop talk" environment - from the time the engines start, we only talk about the flight. G Faris |
![]() Michelle P wrote: Ok so it is getting late. One commutes in a Cessna 150, One in a Cessna 182 and the last in a Maule M-7. Michelle Well, don't forget to wave to all us frustrated commuters down below you wondering who's flying on a nice work morning. grin (Or perhaps there's people who LIKE commuting, but I've never met one.) At least I've got a Prius now! -Malcolm |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
