#11
Roy Smith wrote:
Ron Rosenfeld wrote: If the TRACON is issuing radar vectors off the ground, then, as I quoted from the AIM, that would supersede any ODP. But ATC is then responsible for obstacle clearance, of course. How can they issue radar vectors before you're in radar contact? They know they will have radar contact within a "reasonable" period of time after takeoff. KMRY is the same way with the radar site several miles from the airport. It's all a matter of how the region and the facility determine what will work for their radar coverage and airspace. |
On Tue, 08 Nov 2005 23:01:05 -0500, Roy Smith wrote:
Ron Rosenfeld wrote: If the TRACON is issuing radar vectors off the ground, then, as I quoted from the AIM, that would supersede any ODP. But ATC is then responsible for obstacle clearance, of course. How can they issue radar vectors before you're in radar contact? This has come up before. If SMO is Class E surface area when the tower is closed (and it probably is), then the heading to fly after takeoff can be specified by ATC. Maybe there is a DVA. "After takeoff", of course, refers to leaving 400' AGL on runway heading. In previous discussions, there has been some confusion as to how the pilot knows that the vector should be considered a "radar vector" and I don't think there's been a real clear-cut answer. Certainly happens at big city airports; and it wouldn't surprise me if that was in effect at SMO in the shadow of LAX. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
On Tue, 08 Nov 2005 23:01:05 -0500, Roy Smith wrote: This has come up before. If SMO is Class E surface area when the tower is closed (and it probably is), then the heading to fly after takeoff can be specified by ATC. Maybe there is a DVA. "After takeoff", of course, refers to leaving 400' AGL on runway heading. SMO is Class E at 700 feet agl when the tower is closed. So far as I know there are no DVAs other than at some USAF facilities. SMO would be "de facto" DVA to the west because of the ocean. To the east, there are tall buildings and some mountains although the mountains are easily avoided with a vector. |
On Wed, 09 Nov 2005 03:44:39 -0800, Tim wrote:
Yes, but...there are many worse locations where they vector below the MVA and do not, in fact, assure any obstacle clearance below MVA. It is a very obscure area. Obscure? 7110.65 5-6-1c and 5-6-3 seem pretty clear on when radar vectors below MVA are allowed. At which facilities is ATC issuing vectors and NOT assuring obstacle clearance? How are they communicating to the pilot that these vectors do not assure obstacle clearance? If, in fact, they are issuing vectors without assuring obstacle clearance, or without actively soliciting the pilot concurrence with these vectors, then this seems to me to be a dangerous practice, and not in accord with ATC published procedures. It should be corrected. ============================= You've mentioned this a few times. What are those specific instructions when departing IFR from SMO with the tower closed? I don't know. I know the airspace constraints of that location but, as I said in a previous post, I have not flown IFR out of KSMO. It seems to me that you're just guessing at what might be going on. You may well be correct, but the information I have gleaned from your posts does not seem to me to be terribly useful. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() "Dan Thompson" wrote in message om... I've forgotten what the airspace classification is for a Class D airport with the tower closed that underlies Class B space. Does it revert to E or what? Is it controlled airpace to the ground? Class D airspace can become Class E or Class G when the tower is closed. A surface area requires: 1.) Communications. Communications capability with aircraft which normally operate within the surface area must exist down to the runway surface of the primary airport. This communications may be either direct from the ATC facility having jurisdiction over the surface area or by rapid relay through other communications facilities which are acceptable to that ATC facility, such as a FSS. 2.) Weather Observations. Weather observations must be taken at the surface area's primary airport during the times the surface area is designated. The weather observation can be taken by a Federally certificated weather observer and/or by a Federally commissioned weather observing system. If the tower is responsible for taking weather observations, then when the tower closes the airspace must become Class G. If the tower serves as the rapid communications relay for the ATC facility having jurisdiction over the surface area, then the airspace must again become Class G when the tower closes, even if weather observations are still taken by another entity, such as an AWOS or ASOS. If communications still exist and weather observations are still taken after the tower closes, then the airspace can become Class E or Class G. It will become Class E if necessary to accommodate instrument procedures if such action is justified and/or in the public interest. The following factors are among those that are considered: 1. Type of procedure including decision height or minimum descent altitude. 2. The actual use to be made of the procedure, including whether it is used by a certificated air carrier or an air taxi/commuter operator providing service to the general public. 3. The operational and economic advantage offered by the procedure, including the importance and interest to the commerce and welfare of the community derived by the procedure. 4. Any other factors considered appropriate. |
![]() "Tim" wrote in message news:KRJbf.3346$zu6.1726@fed1read04... SoCal TRACON maintains very tight control over that airspace. Although I have never flown IFR out of KSMO, I am sure they would assign a heading to maintain for radar vectors. If I am correct, that would supercede the ODP. SMO does not have a surface area when the tower is closed, ATC cannot specify direction of takeoff or turn after takeoff. If it is necessary to specify an initial heading to be flown after takeoff, it must be issued so as to apply only within controlled airspace. An assigned heading does not supersede the ODP, compliance with an ODP is the pilot's prerogative. |
![]() "Roy Smith" wrote in message ... How can they issue radar vectors before you're in radar contact? Why not? The aircraft's position is known to a high degree of accuracy. |
Steven P. McNicoll wrote:
"Tim" wrote in message news:KRJbf.3346$zu6.1726@fed1read04... SoCal TRACON maintains very tight control over that airspace. Although I have never flown IFR out of KSMO, I am sure they would assign a heading to maintain for radar vectors. If I am correct, that would supercede the ODP. SMO does not have a surface area when the tower is closed, ATC cannot specify direction of takeoff or turn after takeoff. If it is necessary to specify an initial heading to be flown after takeoff, it must be issued so as to apply only within controlled airspace. An assigned heading does not supersede the ODP, compliance with an ODP is the pilot's prerogative. As I said, I haven't done it. I suspect, though, if someone started off on something other than the assigned heading SoCal would be all over them as soon as they saw any deviation. By that time, the departure would almost certainly be above 700 feet, agl, and SoCal would have absolute control. LA Airport has two ASRs, north and south. The north side sees secondary targets well below 700 feet, agl, near SMO. |
![]() wrote in message news ![]() As I said, I haven't done it. I suspect, though, if someone started off on something other than the assigned heading SoCal would be all over them as soon as they saw any deviation. By that time, the departure would almost certainly be above 700 feet, agl, and SoCal would have absolute control. No they wouldn't. If a published IFR departure procedure is not included in an ATC clearance, compliance with such a procedure is the pilot's prerogative. |
wrote in message news ![]() As I said, I haven't done it. I suspect, though, if someone started off on something other than the assigned heading SoCal would be all over them as soon as they saw any deviation. By that time, the departure would almost certainly be above 700 feet, agl, and SoCal would have absolute control. No they wouldn't. If a published IFR departure procedure is not included in an ATC clearance, compliance with such a procedure is the pilot's prerogative. I accept that, for sake of discussion. But, once the aircraft enters Class E airspace, and the TRACON sees it on radar, are you telling me that the TRACON does not have absolute control over the aircraft at that point in time? |
Should you tell Tower you're departing IFR | John Clonts | Instrument Flight Rules | 75 | October 4th 05 04:56 PM |
Los Angeles radio tower crash kills 2 | Paul Hirose | Piloting | 178 | August 6th 05 03:46 PM |
New Oshkosh Tower | Jay Honeck | Piloting | 20 | November 25th 03 05:35 PM |
Oshkosh Get together Roster - Sign in, please! | Bruce E. Butts | Home Built | 4 | July 26th 03 11:34 AM |
Oshkosh Get together Roster - Sign in, please! | Jay Honeck | Owning | 2 | July 24th 03 09:11 PM |
