#11
Michael Horowitz wrote:
As I understand it, you can grind a scored shaft once and install oversized bearings, but that's the limit of grinding, then you need a replacement. I believe I"ve seen (sometime in the distant past) cranks offered for sale, but I may be mistaken. Are they getting hard to find? As the A-65 is no longer made, what does this mean for the fleet of A-65 owners? Do they swap it out for an engine that is still supported? - Mike You could likely have a crank custom made for an experimental, but I'm guessing the cost would be high even by aircraft standards. Matt |
Most airboaters up here use Lycomings of the O-320 and O-360 variety.
What's wrong with 1930's technology? It's time proven. I'm not saying there isn't room for improvements, but look at all the horsing around people have had to do to get an auto engine into an airframe. Blow a (water) hose and you're cooked...In aviation, there is something to be said for simplicity. My A-65 or my C-85-8 never had an alternator or starter fail to date. Top that with ANY modern auto engine ![]() Lights and radios don't make airplanes fly... Bret Ludwig wrote: Scott wrote: Because they're TOO GOOD to waste them in a genset, irrigation pump or welder. ROTFLMAO!!!!! Actually I'm having you on. Continentals were used in many military gensets and GPUs. There was a flat twin using C-85 jugs that was produced in large numbers for a dedicated Army radio genset giving B+ and heater voltages for a specific transmitter truck and a O-470 derivative used in a genset used by MASH units. Lycs were used in lots of ground ramp applications and in an airdroppable rescue boat. They were all pains in the ass and Uncle Sugar got rid of them forthwith. Liquid cooled en-bloc engines were far more reliable and that's why split crankcases and bolt on one piece jugs left general purpose engine design circa 1925 or so. Why do you say the C-85 should be reproduced rather than the A-65? Lots of restored "antiques" used the A-65...Luscombe, Aeronca, Taylorcraft, Piper, etc. If you were "going to build a homebuilt" as you say, which indicates to me you haven't or aren't planning to build a homebuilt, why are you hanging around a homebuilt newsgroup, offering advice on something you have no experience with? Ever fly behind an A-65 (or in front of one if it's a pusher)? I think I soloed behind a 75 that started out as a 65. I worked in FBO's and once for about three weeks in the Cessna Pawnee Ave. plant. I quit because I literally couldn't take the heat-there was no A/C and it was August in Wichita. Wichita was the most depressing piece of **** fundamentalist-ridden town I have ever lived in my life, besides, no one flies. 90% of the production staff not only weren't pilots, they had never been up in the plane they built and had no desire to do so. Most of the aircraft with 65s originally later got upgrades and many got electrical systems and engins with generator and starter pads. Then people got stupid and tore out the wiring, and reconverted them to the original configuration so they lost lights and radios and could fly around like an ultralight. If the airframe is certificated or STC'd to take the 85 you are dumb to forfeit the additional horsepower, unless you have a source for cheap "white gas" the 65 would burn and the later ones wouldn't. As you know the 65, 75, 85 and up are largely the same engine. I think the 65 has lower compression pistons. Some airplanes are really best off with this engine, but designing a new one around one today is no more sensible than using an OX-5, or a Gnome-Rhone rotary radial, or even the pretty reliable six cylinder Ranger. Do you drive a Model A flathead four powered car to work every day? Are the airboat guys still running these Continentals? |
"Scott" wrote Blow a (water) hose and you're cooked Bull. Replace your hoses every five years, and you will never blow a hose. Even if you do, you can make enough power to do and emergency landing. You may have cooked the engine, but they will run for quite a while without water. I don't see auto engines blowing a jug, or breaking a rod, or hanging a valve at low hours, like lycosauruses. There is no reason for all of the engine out situations that airplane engines have, IMO. -- Jim in NC |
My point was simplicity. It doesn't get much simpler than an A-65.
I've heard of auto engines blowing rods through the block...I've heard of auto engines burning off a valve head (equivalent of blowing a jug)...I've heard of stuck valves...yes, changing things like hoses and belts can prevent a failure down the road, but face it, **** happens to airplane engines and auto engines. If you fly or drive long enough, I bet either has an equal chance to leave you walking at some time in your career. Morgans wrote: "Scott" wrote Blow a (water) hose and you're cooked Bull. Replace your hoses every five years, and you will never blow a hose. Even if you do, you can make enough power to do and emergency landing. You may have cooked the engine, but they will run for quite a while without water. I don't see auto engines blowing a jug, or breaking a rod, or hanging a valve at low hours, like lycosauruses. There is no reason for all of the engine out situations that airplane engines have, IMO. |
"Scott" wrote in message ... My point was simplicity. It doesn't get much simpler than an A-65. I've heard of auto engines blowing rods through the block...I've heard of auto engines burning off a valve head (equivalent of blowing a jug)...I've heard of stuck valves...yes, changing things like hoses and belts can prevent a failure down the road, but face it, **** happens to airplane engines and auto engines. If you fly or drive long enough, I bet either has an equal chance to leave you walking at some time in your career. If you have heard of these things happening, I would ask at how many miles, and what abuse had been given to the engine, like no oil, not enough oil changes, over revving, and what kind of engine? -- Jim in NC |
http://www.datatown.com/chrysler/
"Some of these engines [BMW] failed catastrophically, with punctured blocks and huge clouds of burnt oil and coolant pouring from the engine compartment. Based on my careful reading of the one-hundred failures to date, at least 13% of documented failures posed a serious hazard." as read on the following website: http://yoy.com/yoy/auto/m3_failwhat.shtml "Buyers should stay away from bargain-priced new and used minivans that require frequent and costly repairs. Chief among these are Chrysler minivans, Ford Windstars, GM front-drives, and the Mercury Villager/Nissan Quest. Chrysler models had engine, drivetrain, electrical and fuel system, AC, brake, and body deficiencies galore. Windstars are noted for engine, automatic transmission, brake, steering, suspension, and fuel system failures. The newest Quests are selling poorly and use many failure-prone Altima/Maxima parts. VW Campers are a good idea poorly executed. These minivans are nicely laid-out, but they aren't reliable and servicing is practically non-existent. Plus, they are costly." from: http://www.lemonaidcars.com/update.htm If I'm reading you correctly, are you saying that poor maintenance is the cause of all or most auto engine failures and that airplane engine failures are caused by engine design problems? Morgans wrote: "Scott" wrote in message ... My point was simplicity. It doesn't get much simpler than an A-65. I've heard of auto engines blowing rods through the block...I've heard of auto engines burning off a valve head (equivalent of blowing a jug)...I've heard of stuck valves...yes, changing things like hoses and belts can prevent a failure down the road, but face it, **** happens to airplane engines and auto engines. If you fly or drive long enough, I bet either has an equal chance to leave you walking at some time in your career. If you have heard of these things happening, I would ask at how many miles, and what abuse had been given to the engine, like no oil, not enough oil changes, over revving, and what kind of engine? |
valve at low hours, like lycosauruses. There is no reason for all of the engine out situations that airplane engines have, IMO. I see way more cars at the side of the road than I hear of airplanes having engine failures, even with making allowance for the many times more cars than airplanes in operation. Aircraft engines fail mostly for the following reasons: 1. Out of gas. Not an engine fault, is it? 2. Carb ice. That's a pilot's mistake, not the engine's. 3. Low oil pressure. Usually due to running out of oil, either because it wasn't checked and topped up, or because the engine wasn't looked after and it leaked out through the same leaks it had been leaking from for several years, or through a blown oil hose that had been in service for 28 years. They are 5-year items. 4. Mechanical failure. This come is a wide variety of expensive noises, and most of them have to do with poor maintenance, or infrequent flying, which causes corrosion internally that leads to the failure. Mechanical failure is actually relatively rare. It's the first three causes above that bring most airplanes down where engines are concerned. Remember that most crashes are weather or pilot induced and have nothing to do with the engine at all. As far as blowing jugs or breaking rods or hanging valves: Try making an auto conversion run at 75 power for a few hours and see what begins to happen. They weren't designed for that, and the guys who successfuly convert and run them for several hundred hours have had to get around a LOT of problems. Dan (Aircraft Maintenance Engineer, homebuilder, and Flight instructor, with installing a Soob in GlaStar experience) |
Dan Thomas wrote:
I don't see auto engines blowing a jug, or breaking a rod, or hanging a valve at low hours, like lycosauruses. There is no reason for all of the engine out situations that airplane engines have, IMO. As far as blowing jugs or breaking rods or hanging valves: Try making an auto conversion run at 75 power for a few hours and see what begins to happen. They weren't designed for that, and the guys who successfuly convert and run them for several hundred hours have had to get around a LOT of problems. For what it's worth regarding catastrophic auto engine failure, in May of this year I got to experience it first hand in my car. Driving down the freeway at 70mph, I heard a God awful noise and realized it was my car. I managed to nurse it across 3 or 4 lanes of the freeway to the shoulder. As I coasted to a stop and turned off the engine, steam started pouring out. I popped the hood (yes, a very dumb idea in hindsight given the potentially scalding coolant that was loose) and saw that the engine was so hot it had melted through a rubber emissions control hose containing fuel/air and ignited. There were also flames down at my engine block. I was able to get them out without hosting a car-b-que on the 91 freeway. What happened? The engine threw a rod which punched a quarter sized hole in the side front of my engine, donating all of my oil to the freeway below. Perhaps some of it sprayed up on the hot exhaust manifold and caught fire - I'm not sure what the source of fuel for the fire was. I didn't especially care at the time. The failure also caused my radiator fan to throw a blade (plastic) into my radiator, cracking it open. This was in my 1991 Geo Prizm. (Ooooh...ahhhh!) It had 156,000+ miles on it and had been used since '91 to drive LA freeways and side streets on a daily basis. The last two years of its life were spent going from my house to my college 35 miles away 5 days a week on freeways. So obviously, it was pushing the end of its useful life and had been driven hard. It was meant to be an economy car. Maybe the failure was a fluke, maybe it was perfectly reasonable given the car's life. But when I hear about Geo conversions for homebuilts now, I tend to look the other way. Sure it can be done, but it was enough to keep me away from them. -Tony Goetz |
"Scott" wrote If I'm reading you correctly, are you saying that poor maintenance is the cause of all or most auto engine failures and that airplane engine failures are caused by engine design problems? Long to short, Yes. That said, there are many engines that have a much better track record for reliability. The Chevy 4.3, Chevy 5.7, ford V-6, with 4.2, (or something like that) Ford 351 come to mind, off the top of my head. When these engines get 80,000 miles, (or perhaps 1500 hours would be close) the possibility of catastrophic failure begins to rise. Time for a cheap, simple overhaul, when compared to the lycosarus and it's ilk. That said, I realize the devil is in the details, with the PRSU, and other systems having problems, without good engineering. The Lycosarus has problems, IMHO, because of it's ultra emphasis on light weight, and many other problems due to faulty parts. (seems like there is always a bolt, or crankshaft, or something with an AD on it) Add on, the ever present problems of finding truly qualified people to work on them. On the "old reliable" airplane engines,carbs freeze up without precise procedures being followed, magnetos fail, heads get too hot and cause valve problems, or warped or cracked heads, detonation destroys pistons, jugs blow off. Modern auto engines don't have these problems, due to (IMHO) the fact that they are produced in such large numbers, and some are raced. With a backup ignition and electrical system, they keep running. Don't even start with the old "auto engines are not built to run that hard" stuff, because on boats, and airboats, and some airplanes, they do, without catastrophic engine failures. It is time for people to get modern engine's installation details worked out, and use them. Design a system; buy some of it, and engineer the rest. Test the hell out of it while on the ground. Put it in a plane and fly it. Some are doing this, with varied results, but usually the engine itself failing is not the problem. Such an undertaking is not for everyone. I hope I get a chance to do it. Soapbox off. g -- Jim in NC |
| Thread Tools | |
| Display Modes | |
| Death toll now 10 times 9/11 | X98 | Military Aviation | 9 | June 11th 04 06:23 AM |
| ~ US JOINS CHINA & IRAN AS TOP DEATH PENALTY USERS ~ | Matt Wiser | Military Aviation | 0 | April 8th 04 03:55 PM |
| About death threats and other Usenet potpourri :-) | Dudley Henriques | Military Aviation | 4 | December 23rd 03 08:16 AM |
| "Air Force rules out death in spy case" | Mike Yared | Military Aviation | 5 | November 10th 03 08:24 AM |
