#11
Don Tuite wrote:
Ok I'm trying to visualize a winch sucking up cable at 88 feet/second (60 mph) and 2000 feet of cable accelerating toward the ground at 32 ft/sec^2. And I'm thinking of my experience fishing with cheap bait-casting reels. Does it ever get interesting? you bet. Cable breaks are something quite interesting to start with (especially if you were tempted to pull to a steep climb too early -- 45 degrees nose up, no engine, and low, is what I'd called interesting); that's why it is a part of the training which is emphasized; I have known of accidents that involved bad ground handling as well: in a place with a multiple drums winch: only one cable winched at a time, but multiple cables can be made ready to increase the rate of launches; the guy I knew got into trouble when the cable he used got entangled with another cable laying on the ground... --Sylvain |
I was watching a guy launch his R/C sailplane using a winch.
He got a little aggressive and pulled the wings off. G -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
On Mon, 14 Nov 2005 16:15:01 -0000, Dylan Smith
wrote in :: At our glider club, we can either use the tow plane or the winch to get the gliders in the air. Not many power pilots have come across the idea of flinging an aircraft airborne on the best part of a mile of steel piano wire, but we do this crazy thing. [Power pilots - whenever you see the glider port symbol on your chart, remember that there may be a winch there. They are less common in the US than over here, but they are used in the US, and the 1/8th inch steel cable will not be kind to you if you run into it. Never directly overfly gliderports below 3000' without talking to their radio operator]. We (the Southern California Soaring Society) used to auto-tow gliders off the dry lake north of El Mirage field in the Mojave Desert with a 1,500' wire attached to an old Buick. There was a lot of other sport activity taking place on the dry lake at the same time, sand-sailors, motorcycles, gyrocopters, ... One day a fellow and his girlfriend in an Aircoup ran into the steel tow wire. The wire imbedded itself in the wing leading edge up to the spar, and broke, fortunately. The pilot landed on the field, and inspected the damage, then took off. |
Larry Dighera wrote:
an Aircoup ran into the steel tow wire. The wire imbedded itself in the wing leading edge up to the spar, and broke, fortunately. The pilot landed on the field, and inspected the damage, then took off. Ah, they still exist, the real men! Stefan |
On 2005-11-14, Don Tuite wrote:
Ok I'm trying to visualize a winch sucking up cable at 88 feet/second (60 mph) and 2000 feet of cable accelerating toward the ground at 32 ft/sec^2. And I'm thinking of my experience fishing with cheap bait-casting reels. Does it ever get interesting? Anybody on the ground ever lose significant body parts? Well, there is a small parachute that retards its descent. The cable doesn't really accelerate much at all when the glider releases - the speedo on the winch shows about 30mph when we reel it in (but I don't know what that translates to on cable speed, 30mph would be what the engine/transmission would be propelling the donor Jaguar XJ6 at!) It *does* get interesting especially when the cable breaks. Being pitched up at 45 degrees nose up and perhaps 55 knots indicated and maybe only 200ft AGL is not a naturally tenable location for a glider when the power abruptly ceases. It involves a zero-g pushover, then a dive towards the very terror firma to regain flying speed, psychologically difficult when all of a sudden you can see every blade of grass rushing up to smite you. But generally, so long as you don't 'pole' it too early, you recover with plenty of time to get your breath back and land. But there have been incidents where pilots haven't waited for a safe height to pitch the glider fully up, with a similar outcome to a power plane climbing out at Vx and losing the motor at 50 feet. Other interesting things are just with the operation of the winch and cable. Since we are on a hard surfaced runway (in fairly poor condition) we use piano wire. A release under tension can create a 'birds nest' - the wire snarls up on itself, and it's a real bugger to get it untangled. It's very stiff. Usually we have to resort to cutting the cable in a couple of strategic places, then tying it (we have tools to make knots in the cable). The cable also has a weak link so you don't overstress the glider and pull the wings off. The Slingsby Swallow, for example, has a different weak link to the Blanik, being a much lighter ship. Occasionally, a weak link will get broken when someone gets a bit aggressive on the launch. There's also a guillotine that chops the cable in case the glider can't release. Just like pilots are taught a 200-ft turn back to the runway when being towed by a plane, we also teach launch failures. At sites with stranded cable or synthetic, the instructor pulls the release handle on a launch. With piano wire, we simulate it by doing a dive and a pull up and then the instructor shouts 'BANG!' because when it breaks, it goes with a bang. (releasing for real on piano wire tends to cause a birds nest so we avoid it unless we have to!) How is the behavior of synthetic rope going to differ from metal cable? It's a fraction of the weight. The synthetic winch cable for our run (we have about a mile of cable) weighs something like 25kg, wheras the steel piano wire probably weighs around 80-100kg. The weight saving translates into a good couple of hundred extra feet on the launch. Trials at other clubs shows it's longer lasting than steel (although we have to see how it goes with our hard surfaced runway) and unlike the piano wire we use now, it won't snarl up. Of course, when we get the new winch cable, we're moving from the carburetted, mechanical points and condenser ignition 6 cylinder engine to an electronic ignition/electronic fuel injection V12 engine too... -- Dylan Smith, Port St Mary, Isle of Man Flying: http://www.dylansmith.net Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de Frontier Elite Universe: http://www.alioth.net |
On 2005-11-14, T o d d P a t t i s t wrote:
Dale wrote: I was watching a guy launch his R/C sailplane using a winch. He got a little aggressive and pulled the wings off. G You might find it interesting to know that the gliders have a winching limit to prevent pulling the wings off when a human is aboard. And there's also a weak link on the glider end of the cable in case the pilot forgets about this limit! -- Dylan Smith, Port St Mary, Isle of Man Flying: http://www.dylansmith.net Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de Frontier Elite Universe: http://www.alioth.net |
Dylan Smith wrote: Never directly overfly gliderports below 3000' without talking to their radio operator]. I trust that gliders always announce take-offs... -- Bob Noel no one likes an educated mule |
Our next winch....... will also be powered by an electronic fuel injected Jaguar
V12 engine which came courtesy of last year's hurricane force storm which collapsed a garage on top of the donor car, completely flattening the roof and cabin area of the car, but leaving all the running gear completely intact :-) A HA! An Ill wind that blew good! vince norris |
On 2005-11-15, Bob Noel wrote:
Never directly overfly gliderports below 3000' without talking to their radio operator]. I trust that gliders always announce take-offs... More importantly, the ground crew give a good look around the sky before giving the take up slack signal. The rate of climb is phenomenal - we don't want to launch if it looks like anyone's about to fly over, it'd be like the Space Shuttle making a take off call just before blindly launching into whatever might be overflying the field. But sometimes mistakes are made, or a plane blends into the sky or... so really, it's best not to directly overfly the field. -- Dylan Smith, Port St Mary, Isle of Man Flying: http://www.dylansmith.net Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de Frontier Elite Universe: http://www.alioth.net |
Bob Noel wrote:
I trust that gliders always announce take-offs... Credo #1 in safty seminars: "Never assume!" Stefan |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
