Textbook Belly landing at PDK
Old November 17th 05, 05:15 PM posted to rec.aviation.piloting
Default Textbook Belly landing at PDK
And as usual, the media- esse tried to hype it, but the reporter from
the copter really did a good job explaining.
The pilot skimmed it in just perfect. No problem.
Oh, this was live TV...
~D
Old November 17th 05, 06:19 PM posted to rec.aviation.piloting
Dave wrote on 11/17/05 09:15:
Yeah, must be a slow news day when CNN covers a gear problem and belly landing
of a King Air live...
-Joe
Old November 17th 05, 06:40 PM posted to rec.aviation.piloting
If they have the video, CNN would cover ditch diggers on a slow news
day.
"Joe Feise" wrote in message
from
landing
-Joe
Old November 17th 05, 07:49 PM posted to rec.aviation.piloting
It wasn't just CNN, FOX and MSNBC were also covering it. Sure was a
smooth landing. Seemed to hang a bit though, I guess ground effect is
pretty huge when the wing is only a foot off the ground.
Chris W
KE5GIX
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
Old November 17th 05, 11:05 PM posted to rec.aviation.piloting
"Chris W" wrote in message
news:m95ff.11794$ih5.10682@dukeread11...
landing
Chris W
KE5GIX
He was carrying extra speed to fly it onto the runway, which he did
perfectly.
The REAL smooth job of flying with this incident wasn't really the landing,
but rather the earlier touch and go on the left main. He had to hold up the
right wing as he tried to get a little bounce on the left main trying to jar
the right side retaining latches loose. That's a mean trick, and takes a
good stick to pull it off without dropping the wing down far enough to catch
the prop tips. It didn't work, but he got through the try without dinging
it.
He did a good job all around I would say.
Dudley Henriques
Old November 19th 05, 08:49 PM posted to rec.aviation.piloting
Dudley
Did you notice he had at least the port engine shut down. Couldn't
tell from camera angle but may not have gotten the prop(s).
In ny event, Good job.
Big John
On Thu, 17 Nov 2005 23:05:08 GMT, "Dudley Henriques"
landing
Chris W
KE5GIX
perfectly.
it.
Dudley Henriques
Old November 19th 05, 09:25 PM posted to rec.aviation.piloting
Hi BJ;
Hope all has been well with you and yours.
I just sort of caught this whole thing on the fly, as we were going out the
door as it was happening :-)
Are you referring to the gear bounce pass or the final belly in John? I did
catch a short replay later on that evening.
On the final landing it looked like he went to idle cut off on both fans
going into the flare but from the view angle it was hard to tell. I'm
assuming he caught at least two blades out of the four on each side as he
settled in but the camera angle was quartering rear which hid everything
under the plane after the slide.
On the bounce pass, I was just assuming he had both fans up. Did he have the
left engine zeroed? Wasn't the port side the side with the gear down?
Why would he zero the port engine?
It looked like the bounce pass was done above the blue line anyway, but I
sure wouldn't have tried that pass with the left engine down......of course
it wasn't my call, but to me that would seem strange??????
Dudley
"Big John" wrote in message
Dudley
Big John
landing
Chris W
KE5GIX
perfectly.
landing,
jar
catch
it.
Dudley Henriques
Old November 20th 05, 12:24 PM posted to rec.aviation.piloting
On Sat, 19 Nov 2005 14:49:32 -0600, Big John
Dudley
Big John
On the shot I saw, pilot/pilots definitely had both props fully
feathered prior to scrapage. They really really looked like
four-bladers, would pretty much had to drag a couple on each side.
Would guess that they killed the engines while feathering the props.
Looked like two crew to me. Have in the past secured engines prior to
landing with questionable gear when I had another crew member to share
the task with. Has never happened to me flying solo, but I doubt if I
would screw with it (trying to secure prior to touchdown).
TC
Old November 17th 05, 08:29 PM posted to rec.aviation.piloting
Actually was at Fulton County (Brown Field) - KFTY. PDK & FTY are the
two big GA airports in Atlanta.
Cuban Missle Crisis - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 09:14 PM
World War II-era B-17 makes belly landing THE ASSOCIATED PRESS Otis Willie Military Aviation 0 May 7th 04 03:02 AM
