OK, Thinking-Cap Time...
Old November 18th 05, 05:13 AM posted to rec.aviation.owning
Default OK, Thinking-Cap Time...
nrp wrote:
Jay - If you get desperate, you might be able to create this problem on
the ground using a hand held or jury rigged electric motor to spin the
alternator rather than having to run the engine. This would allow
better diagnostic capability using an oscilloscope.
If you try this, keep a fan blowing on the alternator. Even in cold
temperatures, it will need cooling air.
George Patterson
If a tank is out of ammunition, what you have is a sixty ton portable
radio.
Old November 18th 05, 12:25 PM posted to rec.aviation.owning
Jay Honeck wrote:
last week seems to point to the all-to-common "mechanic-induced" squawk.
It's not just mechanics. Any good troubleshooter knows you always look
"where the human being was last".
__!__
http://www2.ari.net/jmasino ! ! !
http://www.OceanCityAirport.com
http://www.oc-Adolfos.com
Old November 18th 05, 03:36 PM posted to rec.aviation.owning
I would check all the grounds in the system. That can cause this
problem. Along with a bad alternator switch. It causes the VR to not
work properly. I had to bread each connection, clean it, then re-do it.
Regards, Ross
C-172F 180HP
KSWI
Jay Honeck wrote:
Of course, we have a new squawk shortly after coming out of the shop.
Perhaps someone here can point me in the right direction?
Here's the scenario with our 1974 Piper Cherokee Pathfinder, with a 530
hour, normally aspirated Lycoming O-540-B4B5 engine:
1) Flying to Janesville, WI today. Extremely cold -- around 15 degrees
Fahrenheit on the surface, near zero at altitude. The first real cold snap
of the year.
2) In steady-state flight, both of us hear a "woo--woo--woo..." softly in
the headphones. It sounds just like strobes that aren't grounded properly.
3) The noise slows down -- or speeds up -- in synch with the prop RPM. At
2300 RPM, it's going a bit faster than once per second -- maybe around three
times every two seconds.
4) I switch our digital voltage/amperage meter to AMPs, and watch as it
oscillates in time with the noise. It's alternating from 5 amps to 10-11
amps, in time with the "woo--woo--woo"... Voltage appears to be pretty
steady at around 13.8-ish volts.
5) Adding load to the system (landing lights, fuel pump, etc.) makes the
noise louder. Adding load to the system and then suddenly turning
everything off makes the noise and amperage oscillation go away -- for about
30 seconds. It then returns.
6) Turning the alternator side of the split master switch ALSO makes the
noise go away. It sometimes stays away when I turn the alternator back on.
Sometimes it doesn't.
7) The battery is new this past summer.
So, we've got a noise and amperage indication that can be corrected by
adding load to the system -- and then suddenly taking it away. The noise
is also fixed -- sometimes -- by cycling the alternator off and on.
The service last week was having the impulse couplings serviced (per service
bulletin), so electrical things have been tinkered with since our last
flight. (This is ALWAYS when some new squawk seems to crop up.)
Any ideas? Loose ground wire somewhere? Alternator failing? Any and all
input is welcomed!
Thanks!
Old November 18th 05, 03:38 PM posted to rec.aviation.owning
OK, lets make that BREAK instead of bread.
Regards, Ross
C-172F 180HP
KSWI
Regards, Ross
C-172F 180HP
KSWI
530 hour, normally aspirated Lycoming O-540-B4B5 engine:
degrees Fahrenheit on the surface, near zero at altitude. The first
real cold snap of the year.
in the headphones. It sounds just like strobes that aren't grounded
properly.
RPM. At 2300 RPM, it's going a bit faster than once per second --
maybe around three times every two seconds.
it oscillates in time with the noise. It's alternating from 5 amps to
10-11 amps, in time with the "woo--woo--woo"... Voltage appears to
be pretty steady at around 13.8-ish volts.
the noise louder. Adding load to the system and then suddenly turning
about 30 seconds. It then returns.
the noise go away. It sometimes stays away when I turn the
alternator back on. Sometimes it doesn't.
noise is also fixed -- sometimes -- by cycling the alternator off and on.
service bulletin), so electrical things have been tinkered with since
our last flight. (This is ALWAYS when some new squawk seems to crop up.)
and all input is welcomed!
Thanks!
Old November 18th 05, 03:57 PM posted to rec.aviation.owning
Does it go away when you turn off the beacon?
Ammeter swings and a similar noise in my plane are due to the beacon's
flasher.
Old November 18th 05, 04:52 PM posted to rec.aviation.owning
So now we are breaking bread over our engines to fix problems?
Old November 18th 05, 06:47 PM posted to rec.aviation.owning
("Darrel Toepfer" wrote)
Is he in a jam or just buttering it over?
What a crumby thing to say :-)
Montwhitebread
Old November 18th 05, 06:56 PM posted to rec.aviation.owning
Hope the alternator itself isn't toast!
"Montblack" wrote in message
Montwhitebread
Old November 18th 05, 07:07 PM posted to rec.aviation.owning
("Jim Burns" wrote)
That's a half-baked assumption.
Like those Capital One ads ...No, No, No.
Any way you slice it, it's always the ground.
....cheaper that way. g
Montblack
Old November 18th 05, 07:16 PM posted to rec.aviation.owning
Dang, I should have read it before I published this....
Regards, Ross
C-172F 180HP
KSWI
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Logging time on a PCATD [email protected] Instrument Flight Rules 3 December 18th 04 05:25 PM
FAA Application -- kinds of time Gary Drescher Instrument Flight Rules 5 November 23rd 04 02:33 PM
FS9 Time Zone Files in BETA Test DDT Simulators 3 April 5th 04 06:06 PM
Retroactive correction of logbook errors Marty Ross Piloting 10 July 31st 03 06:44 AM
