Prop strike effect on resale value?
Old November 23rd 05, 02:36 AM posted to rec.aviation.owning
Default Prop strike effect on resale value?
Ron Natalie wrote:
Mike Spera wrote:
As others have stated, you need to follow the engine manufacturer's
instructions following a prop strike or "sudden engine stoppage".
Usually this calls for inspection of the crank runout at a minimum.
Some call for engine teardown
"Some" includes both Lycoming and Continental.
Ron,
I thought they both had that requirement somewhere, but I was not sure
whether it was binding (via some FAA reg.). Some other fellow posted the
AD for one engine make because of the crank gear. That seems to suggest
that the engine manufacturer's "recommendation" did not have regulatory
weight (or the AD would be unnecessary).
What's up?
Why does a prop ice up so apparently readily? Mike Rapoport Piloting 2 November 8th 05 02:52 PM
my ignorance LCT Paintball Home Built 25 April 9th 05 06:54 PM
Prop Strike Query Dick Home Built 12 November 16th 04 02:20 AM
Prop Strike in Milwaukee Ben Smith Piloting 9 October 1st 04 11:21 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
