On Fri, 02 Dec 2005 20:59:57 -0500, Wizard of Draws
wrote: Enroute, I can't always be sure what would be considered my primary nav source "from an FAA point of view" since I'm using more than one, that's why I started this thread. As I wrote, the FAA doesn't define "primary" in the PC/G and it's not defined in 14 CFR 1.1. If there is a need for you to have a definitive answer, you could try writing the FAA Chief Counsel. But there may be no answer forthcoming unless there is some operational reason to come up with one. And, in the case of a non-commercial Part 91 small aircraft flight, such as it seems you are describing, I don't see an operational reason to answer that question. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
On 12/3/05 8:07 AM, in article ,
"Ron Rosenfeld" wrote: On Fri, 02 Dec 2005 20:59:57 -0500, Wizard of Draws wrote: Enroute, I can't always be sure what would be considered my primary nav source "from an FAA point of view" since I'm using more than one, that's why I started this thread. As I wrote, the FAA doesn't define "primary" in the PC/G and it's not defined in 14 CFR 1.1. If there is a need for you to have a definitive answer, you could try writing the FAA Chief Counsel. But there may be no answer forthcoming unless there is some operational reason to come up with one. And, in the case of a non-commercial Part 91 small aircraft flight, such as it seems you are describing, I don't see an operational reason to answer that question. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) If the FAA says I can't use a VFR GPS as my primary nav source, that indicates to me that they must have a way of defining it, or at least expect me to be able to, although without telling me how. But I guess I'm expecting logic from a government agency. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic http://www.wizardofdraws.com More Cartoons with a Touch of Magic http://www.cartoonclipart.com |
On Sat, 03 Dec 2005 10:20:32 -0500, Wizard of Draws
wrote: ... I guess I'm expecting logic from a government agency. Ah -- there's your error sigh!! "We're from the FAA, and we're not happy until you're not happy!" Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Ron Rosenfeld wrote:
On Fri, 02 Dec 2005 20:59:57 -0500, Wizard of Draws wrote: Enroute, I can't always be sure what would be considered my primary nav source "from an FAA point of view" since I'm using more than one, that's why I started this thread. As I wrote, the FAA doesn't define "primary" in the PC/G and it's not defined in 14 CFR 1.1. If there is a need for you to have a definitive answer, you could try writing the FAA Chief Counsel. But there may be no answer forthcoming unless there is some operational reason to come up with one. And, in the case of a non-commercial Part 91 small aircraft flight, such as it seems you are describing, I don't see an operational reason to answer that question. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) The FAA doesn't need a regultion to set forth policy. The FAA policy remains that VOR is the primary method for domestic en route IFR navigation. This is related to the ICAO definitions of Class I and Class II navigation. |
The recent GPS/IFR discussions here got me to thinking. I generally fly an
Arrow, equipped with a Garmin 430, 2 VORs, Loran, my handheld GPS, my sectionals, low enroute charts, and since I got my IFR ticket, I try to fly under ATC control as often as possible to keep my comm skills up. On cross county flights, I fiddle with the VORs and cross check my location, I set the Loran (if it's working that day), etc. In other words, for navigation, I use everything inside and out the cockpit that is operational. Which one is considered primary? The one providing course guidance on your HSI. If you're not HSI equipped, its the CDI somewhere in the cockpit that you use for course guidance. If you use a bunch of stuff at the same time, then the question doesn't mean anything. |
Y'all,
Consider the latest out of date sectional Gene Whitt |
On Tue, 20 Dec 2005 02:35:41 GMT, "Gene Whitt"
wrote: Y'all, Consider the latest out of date sectional You have them that new? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Gene Whitt |
A Remote Compass- java source | [email protected] | General Aviation | 0 | July 3rd 04 06:39 PM |
Winscore source code now available | Guy Byars | Soaring | 0 | February 5th 04 10:43 AM |
Are handheld GPSes becoming a defacto primary nav source? | Paul Tomblin | Instrument Flight Rules | 44 | September 13th 03 10:36 PM |
OT- north korean nuke weapon plutonium - source? | patrick mitchel | Military Aviation | 11 | August 31st 03 04:01 AM |
Source for copper crush gaskets??? | Jim | Owning | 0 | August 22nd 03 06:31 PM |
