#11
I changed my mind assuming it is a lean stumble. A low float setting
and/or possibly an obstruction in the fuel delivery system would give a low bowl level that could make the mixture go lean enough to stumble from the main jet. In that case it would also be running lean at full power - not a good situation. This still doesn't fit every symptom. The cheapest way out is to get an EGT - and soon.. |
OK..some ideas here are really good thoughts.
More info.. Have EGT, reading normal, can pull mix back 30% (with normal EGT rise) to peak, and the mix operation appears normal. This flight was in the coldest air experienced so far with our "new" Warrior.(we bought it in Aug) DA may have been below SL.. One thing we will check is the fuel delivery. Not too suspect yet as the fuel pressure is good with fuel pump off, plane is hangared, and (so far) no water has ever been sumped. I suspect a lean stumble.. mix was fill rich when it first happened. Tried both tanks...same. RPM at the stumble was about 2000 - 2200 every time, no difficulty in the 1500 range. Smoothly closing the throt (rate of full travel to full idle 3 seconds or more ) - no prob.... quickly closing (not yanking) caused the stumble. Recovery to smooth was 1 second.The rate of throt travel would be about 1.5 seconds to full idle to produce the stumble. Engine starts on 2nd blade with proper prime, smooth and pulls strong, burns a liter oil every 12 hours. Thanks to all who responded! We have several learned pinions to work with. Dave On 5 Dec 2005 06:23:44 -0800, "nrp" wrote: I changed my mind assuming it is a lean stumble. A low float setting and/or possibly an obstruction in the fuel delivery system would give a low bowl level that could make the mixture go lean enough to stumble from the main jet. In that case it would also be running lean at full power - not a good situation. This still doesn't fit every symptom. The cheapest way out is to get an EGT - and soon.. |
I have about 60 hours in a pa28-151 (160hp) that is a rental locally.
It does the same thing. The Mechanic as rebuilt the carb a couple times and still can't figure out what is causing it. Only does it occasionally and doesn't seem to require a fast reduction in power, just a reduction in power. In fact it is more noticable when doing smaller power reductions. It has been doing it for a couple hundred hours now. Would love to know what causes it as would the Mechanic. Brian CFIIG/ASEL |
![]() "Dave" wrote .. quickly closing (not yanking) caused the stumble. Recovery to smooth was 1 second. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Man goes to the doctor and says, "doc, it hurts every time I bend my arm back and forth real quick, like this!" Doc says, "Then, don't do that!" My advise? If everything runs good, in every other way, keep an eye on everything, and "don't do that!" -- Jim in NC |
Dave,
Your problem rings some bells for me since I have experienced such problems with engines before. I have a pretty decent background. So, I offer this. The float level is probably okay. I normally do not see any significant changes onse set. in fact, I have modified such settings for efficiency. Setting the float lean, results in a lean situation (bog) when accelerating or being placed under a heavy load. A rich setting probably would not affect such a situation which you are experiencing. A real real rich setting would be evident by observing wet fuel within the venturi etc. This situation would also be noticed by potent exhaust and would be evident at all times and RPM levels. Thus, I do NOT think it is a float problem. A vent hole plug could be a possibility but idle quality should show this. Based on my experience, I would check for two probable conditions. First, DIRT!!!!! I have found that dirt from fule tanks, corrosion, etc. can develop into such hard to identify gremlins! It has happened too many times! Ultimately, if let go, shall cause a failure. Based on this, I would suggest several things. The carb, really needs to be removed, inspected, and CLEANED! Then the float can be verified (yes). All orificies need to be checked with light and /or inserting a pin or fine wire. The light is good to see fine things like strands of misc. stuck deep in passageways, etc. Then, once cleaned, and checked, it needs to be assembled and adusted properly to spcifications. While performing this function, INSURE that all housing surfaces are FLAT and seal PROPERLY. Once this is complete, the fuel filters should be replaced. You should also then, cut the old filters open, and carefully look for an accumulation. Then, the air inlet and filter assembly should be inspected and replaced if dirty. Once a new filter or existing filter is re-installed, make DARN sure that the intake inlet housing is totally sealed. If dirty air is being drawn past the filter, it shall clog the air bleeds in the idle tube passages. This could then, POSSIBLY cause your condition. If the carb is in good condition, it would probably be more noticeable. Why you ask. Well, as carbs age, performance at idle is usually compensated with just incrasing the idle screw. That's okay, I guess. But on an older carb with some wear, this puts some of the idling onto the main circuit and covers up the problem on the idle circuit! Since the main circuit can feed plenty of fuel, no noticeable problems can be felt! But, if everything is in decent order, and the idle is truly adjusted properly, a problem becomes more evident. I am not talking big extremes here just small changes. Anyway, when everything is adjusted properly, dirt, or some leakage, shows up much more easily ... like idle air bleeds being clogged! If the carb is operating partly off the mains, they are also operating of the main air bleeds also. These bleeds would provide enough air, since they are designed for higher RPM's. And, since the idle air bleeds are so much smaller, they are easily plugged before the main bleeds would be. The second are which needs addressing is a vaccuum leak. During rapid throttle closing, the vaccuum spikes quickly which can expose and pull outside air into the carb which results in a lean stumble! So, all intake gaskets should be visually checked and even sprayed with say WD-40 or carb spray and notice if RPM changes are evident. If they are, then you found the problem! Based on what you have described, you shall have to me quite meticulous in every item which I mentioned here. I think that if you are, you shall find the problem. Additionally, knowing the possibilities, when you find the problem, it shall stick out like a sore thumb! Finally, if the idle air bleeds are obstructed, a can of carb cleaner would clear this up immediately. From there, it would be wise to pull the top of the carb, and check for sediments and dirt. Based on what you find, would determine if the carb had to be pulled. Normally, if you catch a problem early enough (like you described), not too much follow-up is needed other than removing the current problem. Sometimes the simple things create the biggest hardships because they are not always evident. But, you are doing the right thing! You noted something wrong, and are investigating it, and you shall solve it, I'm sure. Most people, would probably just dismiss it or worry about it when it was convenient for them. But, left too long, can create a bad situation! Take Care, and I hope that this information helps! Dave wrote: Hi All! OK, since the collective talent in this group greatly exceeds mine and those around me... ![]() Today the engine in our 151 (O 320-150hp)Warrior stumbled during power reduction, and we were able to repeat the symptom..... Here are details OAT -5 C, 2350 rpm, kinda rough air, pulled back throttle to decend after passing traffic.. I think we hit a bump which caused the throttle to be retarded quicker than normal, engine stumbles for 1 second and resumed operation at the new (lower ) throttle setting. We were able to repeat this several times, carb heat on/off, fuel pump on/off, leaned rich of peak/ full rich, left tank/right tank, rt mag/left mag/both. - as long as we waited a couple of minutes to try again. No evidence of carb icing, dew point was +10C Moving the throttle immediately back to cruise, then sudden retard, no problem. The stumble could be repeated by waiting 2 -3 minutes . Recent maintenance, oil & filter change 1.5 hrs ago. The stumble was like the mixture was momentairly too lean, similar to the lean test during runup... At 3500 ft, lean setting was at 60% of mix lever travel to full rich.. Any thoughts from you engine talents out there? Cheers! Dave |
Brian,
Please read what I just posted for Dave! I think you just answered the question with your observation ... the mechanic has rebuilt the carb several times!!!! I bet he is trying to adjust it to standard specifications with a throttle shaft which bores are egg-shaped! This causes leakage. It also creates proper adjustment problems. If you set it to specifications, a stumble can result. If you set the idle higher, then you are operating a little bit off the main feed system, and then, the problem is covered up! But, then it is not as efficient, and REALLY in fact, out of adjustment! Ideally, the carbs should probably be replaced. but, as always, it comes down to money! YES! Upping the idle is okay in most instances since there really is no down point other than using a bit more fuel at idle. Old engines do not function like new ones YES! But, I think my response to Dave will also give you some good insight in your inspections also. Dirt, buildups, wear, and leakage create many problems and they come in many forms creating many weird gremlins! ANY negligible movement of the throttle shaft affect the idle quality and the functioning of the this fine adjusted system! take Care! Brian wrote: I have about 60 hours in a pa28-151 (160hp) that is a rental locally. It does the same thing. The Mechanic as rebuilt the carb a couple times and still can't figure out what is causing it. Only does it occasionally and doesn't seem to require a fast reduction in power, just a reduction in power. In fact it is more noticable when doing smaller power reductions. It has been doing it for a couple hundred hours now. Would love to know what causes it as would the Mechanic. Brian CFIIG/ASEL |
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
